[3.5.0-rc.1] Premature execution of G54/G55
In some of my files I use
G54
andG55
to move between two different working areas during the job (CNC). When using 3.5.0-rc.1 I noticed that I randomly get target position outside machine limits errors where previously these errors did not occur.
Upon inspection of the files I can see that the G1 commands that are sent are supposed to be in theG55
working space, so this error seems strange considering the commands are preceded by aG55
in the file. When copying this command into the console and running (after the job is cancelled by the error), I get the same machine limits error. If I send aG55
command, and then the "bad" line, it executes without any error.
My guess about the bug here is that there is aG54
command farther down in the file that is getting executed early, so I tried puttingM400
andG4 S0.1
commands in front of these, but the issue persists.Attached here are my config.g, override and a sample file which makes the error happen:
config.g.txt
config-override.g.txt
error_maker.nc.txt
The important thing to note in this sample file is that my machine has Y soft limits from -600 to 0, so a command like G0 Y20 will fail unless it is given in the G55 system.I'm guessing this has something to do with motion planning and queueing, which I know there have been some changes to in 3.5.
Cheers,
T -
@tristanryerparke What version were you using before when this worked ok? What board are you using?
@gloomyandy MB6HC with 4x 1HCL and 1x 1LC, was on 3.4.6 before.
