AI Print Monitoring / Printer Health monitoring
@Peter-Lebiedzinski said in AI Print Monitoring / Printer Health monitoring:
@Gianluca I will create a ZIP installer for your version of DSF. I will get back to you within the hour.
Thank You!!!
Sounds like a really interesting service.
I think it'd be a good investment in terms of the subscription when I'm in production mode, and the free license would be possibly enough for now and then small hobby printers.
https://printpal.io/printwatch/
Definitely going to keep up with developments and give it a try on my printers once they're back together again after the current round of upgrades.
In terms of AI capabilities I guess the ultimate goal would be to recognise any deviation from the STL or gcode file associated with the print.
Perhaps the plugin would build a representative visual model from the gcode and then alarm if the print head deviated...
Interested stuff...
@CNCModeller I cannot say too much, but we have been working with 3D Convolutions and Pointclouds of various CAD models, and there are very exciting things coming in the future.
I guess another way would be to put tracking markers on the bed and print head then visually track those to confirm the printer is following the gcode...
@Peter-Lebiedzinski I have a few questions regarding "anomaly detection". Assuming a print is showing signs of under extrusion, would your system detect and report that? If so, is it "intelligent" enough to diagnose the reason which could be say a partially blocked nozzle, print speed too high and exceeding the maximum volumetric flow rate of the hot end, temperature too low for the filament in use, motor current too low for the extruder in use, or any of the other reasons that can cause under extrusion? Also, with things such as bulging corners or other surface defects, is it intelligent enough to discriminate between genuine defects and features of the model itself?
@deckingman This would depend on what sensor values are available. If we have feedback data from the extruder motor (current, position, command position, etc), then yes. That is why we like the way Duet is moving with adding support for closed-loop steppers and low-level variable sampling at 4 Hz.
As for diagnosing the root cause of the issue, maybe, but not with high certainty, at least not as of now with our testing. We plan on trying various simple methods first before developing an end-to-end model for this, some of which would be clustering the data from our AD ("Anomaly Detection") model and seeing if we can segment out any distinct clusters that we can label as "pertaining to an issue with X, Y, or Z".
Regarding your last question, if it is a computer vision model then it is very unlikely to be able to discriminate genuine defects vs model features. It takes everything at face value as it sees it on the sensor. This of course could be addressed with a CAD model informed ML model, but we do not have plans on developing that as of now.
@CNCModeller This would be helpful, but not necessary. At the end of the day we want to make it as modular and easy to use for the user.
With nowadays computer vision operations, we can easily pointcloud the current print from a single camera angle.
We could perhaps wrap this into a feature rather quickly and release it for beta testing. The end feature would be a detector for clog, something conventional object detectors struggle to detect as it is trying to detect the absence of something in the frame.
@Gianluca
We have created a ZIP installer for the 3.5.0-rc.1 versions of RRF/DSF/DWC, it can be found here: https://github.com/printpal-io/DSF_PrintWatchAI_Plugin/releases/tag/v3.5.0-rc.1Please note that the 3.5.0-rc.1 currently has an issue with the HTTP endpoints being registered. This can be easily worked around by doing the following:
- Make sure the plugin is installed and started
- SSH into the SBC
- Enter the command:
sudo systemctl restart duetwebserver
This will restart the webserver and register the endpoints correctly. This must be done every time the SBC is started up. This should be fixed in the next release.
@Gianluca
- SSH into the SBC
Thank you so much for your precious help. This evening, after work, I will do all the tests and update you. I'm sure others who have installed the latest firmware version will find your work very useful!
@DNvM84 @jay_s_uk
I've created a Plugin for DWC-only configurations to be able to run the AI monitoring. It will work for DWC 3.4, 3.4.6, and 3.5.0-rc as of now. It can be found here: https://github.com/printpal-io/DWC_PrintWatchAI_PluginIn order to use the plugin, you still need a device (Raspberry Pi, or any SBC) running the AI backend component, and it needs to be on the same network (Ethernet or WiFi) as the Duet mainboard. The backend component as well as how to set it up can be found here: https://github.com/printpal-io/PrintWatchAI_Backend
I would recommend using a Raspberry Pi for running the backend since they are simple and easy to use.
I have also tested the Plugin's Backend component with great success on an Orange Pi Zero3 board and it works just as well. The Orange Pi Zero3 is a little more economical ($22.99 on amazon: https://www.amazon.com/Orange-Pi-Allwinner-Quad-Core-Development/dp/B0CB1BYTT8/ref=sr_1_5?crid=BYJ6JUDXT64O&keywords=orange+pi+zero+3&qid=1694217352&sprefix=orange+pi+zero+3%2Caps%2C118&sr=8-5)When testing, please run with
Test Mode
enabled, since the code that checks if the printer is 'Printing' has not been fully tested. -
@Peter-Lebiedzinski
I first tried to install PrintWatchAI_Backend on my RPI 4 from the command prompt, and in point 5 of the list I get an error that prevents the installation. I attach a list.pi@VORON-24-SBC:~ $ cd /home/pi pi@VORON-24-SBC:~ $ wget https://github.com/printpal-io/PrintWatchAI_Backend/archive/refs/tags/raspberrypi.zip --2023-09-21 11:40:21-- https://github.com/printpal-io/PrintWatchAI_Backend/archive/refs/tags/raspberrypi.zip Risoluzione di github.com (github.com)... 140.82.121.4 Connessione a github.com (github.com)|140.82.121.4|:443... connesso. Richiesta HTTP inviata, in attesa di risposta... 302 Found Posizione: https://codeload.github.com/printpal-io/PrintWatchAI_Backend/zip/refs/tags/raspberrypi [segue] --2023-09-21 11:40:21-- https://codeload.github.com/printpal-io/PrintWatchAI_Backend/zip/refs/tags/raspberrypi Risoluzione di codeload.github.com (codeload.github.com)... 140.82.121.10 Connessione a codeload.github.com (codeload.github.com)|140.82.121.10|:443... connesso. Richiesta HTTP inviata, in attesa di risposta... 200 OK Lunghezza: non specificato [application/zip] Salvataggio in: "raspberrypi.zip" raspberrypi.zip [ <=> ] 19,14K --.-KB/s in 0,03s 2023-09-21 11:40:22 (550 KB/s) - "raspberrypi.zip" salvato [19599] pi@VORON-24-SBC:~ $ unzip raspberrypi.zip && rm raspberrypi.zip Archive: raspberrypi.zip ff8985d86b20f8dac85b9908a5057b61b5a3df26 replace PrintWatchAI_Backend-raspberrypi/LICENSE? [y]es, [n]o, [A]ll, [N]one, [r]ename: y inflating: PrintWatchAI_Backend-raspberrypi/LICENSE inflating: PrintWatchAI_Backend-raspberrypi/README.md replace PrintWatchAI_Backend-raspberrypi/main.py? [y]es, [n]o, [A]ll, [N]one, [r]ename: a error: invalid response [a] replace PrintWatchAI_Backend-raspberrypi/main.py? [y]es, [n]o, [A]ll, [N]one, [r]ename: A inflating: PrintWatchAI_Backend-raspberrypi/main.py inflating: PrintWatchAI_Backend-raspberrypi/printwatch.service extracting: PrintWatchAI_Backend-raspberrypi/printwatch/__init__.py inflating: PrintWatchAI_Backend-raspberrypi/printwatch/client.py inflating: PrintWatchAI_Backend-raspberrypi/printwatch/core.py inflating: PrintWatchAI_Backend-raspberrypi/printwatch/interface.py inflating: PrintWatchAI_Backend-raspberrypi/printwatch/utils.py inflating: PrintWatchAI_Backend-raspberrypi/requirements.txt inflating: PrintWatchAI_Backend-raspberrypi/ustreamer.service pi@VORON-24-SBC:~ $ cd PrintWatchAI_Backend-raspberrypi pi@VORON-24-SBC:~/PrintWatchAI_Backend-raspberrypi $ pip3 install -r requirements.txt Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from -r requirements.txt (line 1)) (40.8.0) Requirement already satisfied: wheel in /usr/lib/python3/dist-packages (from -r requirements.txt (line 2)) (0.32.3) Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 3)) (3.8.5) Requirement already satisfied: ujson in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 4)) (5.7.0) Collecting typing (from -r requirements.txt (line 5)) Using cached https://www.piwheels.org/simple/typing/typing-3.7.4.3-py3-none-any.whl Collecting uvicorn (from -r requirements.txt (line 6)) Using cached https://files.pythonhosted.org/packages/ad/bd/d47ee02312640fcf26c7e1c807402d5c5eab468571153a94ec8f7ada0e46/uvicorn-0.22.0-py3-none-any.whl Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from -r requirements.txt (line 7)) (5.4.1) Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from -r requirements.txt (line 8)) (2.21.0) Collecting fastapi (from -r requirements.txt (line 9)) Using cached https://files.pythonhosted.org/packages/76/e5/ca411b260caa4e72f9ac5482f331fe74fd4eb5b97aa74d1d2806ccf07e2c/fastapi-0.103.1-py3-none-any.whl Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (1.3.1) Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (23.1.0) Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (1.3.3) Requirement already satisfied: typing-extensions>=3.7.4; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (4.7.1) Requirement already satisfied: charset-normalizer<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (3.2.0) Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (1.9.2) Requirement already satisfied: asynctest==0.13.0; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (0.13.0) Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (4.0.3) Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 3)) (6.0.4) Requirement already satisfied: click>=7.0 in /usr/lib/python3/dist-packages (from uvicorn->-r requirements.txt (line 6)) (7.0) Collecting h11>=0.8 (from uvicorn->-r requirements.txt (line 6)) Using cached https://files.pythonhosted.org/packages/95/04/ff642e65ad6b90db43e668d70ffb6736436c7ce41fcc549f4e9472234127/h11-0.14.0-py3-none-any.whl Collecting anyio<4.0.0,>=3.7.1 (from fastapi->-r requirements.txt (line 9)) Using cached https://files.pythonhosted.org/packages/19/24/44299477fe7dcc9cb58d0a57d5a7588d6af2ff403fdd2d47a246c91a3246/anyio-3.7.1-py3-none-any.whl Collecting pydantic!=1.8,!=1.8.1,!=2.0.0,!=2.0.1,!=2.1.0,<3.0.0,>=1.7.4 (from fastapi->-r requirements.txt (line 9)) Using cached https://files.pythonhosted.org/packages/82/06/fafdc75e48b248eff364b4249af4bcc6952225e8f20e8205820afc66e88e/pydantic-2.3.0-py3-none-any.whl Collecting starlette<0.28.0,>=0.27.0 (from fastapi->-r requirements.txt (line 9)) Using cached https://files.pythonhosted.org/packages/58/f8/e2cca22387965584a409795913b774235752be4176d276714e15e1a58884/starlette-0.27.0-py3-none-any.whl Requirement already satisfied: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from attrs>=17.3.0->aiohttp->-r requirements.txt (line 3)) (6.7.0) Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->-r requirements.txt (line 3)) (2.6) Collecting exceptiongroup; python_version < "3.11" (from anyio<4.0.0,>=3.7.1->fastapi->-r requirements.txt (line 9)) Downloading https://files.pythonhosted.org/packages/ad/83/b71e58666f156a39fb29417e4c8ca4bc7400c0dd4ed9e8842ab54dc8c344/exceptiongroup-1.1.3-py3-none-any.whl Collecting sniffio>=1.1 (from anyio<4.0.0,>=3.7.1->fastapi->-r requirements.txt (line 9)) Downloading https://files.pythonhosted.org/packages/c3/a0/5dba8ed157b0136607c7f2151db695885606968d1fae123dc3391e0cfdbf/sniffio-1.3.0-py3-none-any.whl Collecting pydantic-core==2.6.3 (from pydantic!=1.8,!=1.8.1,!=2.0.0,!=2.0.1,!=2.1.0,<3.0.0,>=1.7.4->fastapi->-r requirements.txt (line 9)) Using cached https://files.pythonhosted.org/packages/cb/fe/8c9363389f8f303fb151895af83ac30e06c0406779fe188b4281a64e4c50/pydantic_core-2.6.3.tar.gz Installing build dependencies ... done Complete output from command python setup.py egg_info: Traceback (most recent call last): File "<string>", line 1, in <module> File "/usr/lib/python3.7/tokenize.py", line 447, in open buffer = _builtin_open(filename, 'rb') FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-install-r73yhlap/pydantic-core/setup.py' ---------------------------------------- Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-r73yhlap/pydantic-core/
Even though the installation of PrintWatchAI_Backend was not successful, I installed the plugin on DWC, but once I enter the data in "settings" when I regenerate the page, they are not saved and you have to enter them again.
In the "preview" screen the webcam does not work.
For now I don't have any other tests I can do...
@Gianluca This looks like it might be an issue with the version of pip installed. Can you try updating it with:
pip3 install --upgrade pip
or
pip install --upgrade pip
and then re-running the installation commands that failed for the backend?
None of the DWC plugin settings or UI items will work if the Backend is not running so both of your issues should be fixed by doing this. Let me know if this fixes your issue.
@Peter-Lebiedzinski
I'm sorry, I tried to install PIP but I'm getting other errors. Unfortunately I am unable to continue..pi@VORON-24-SBC:~ $ pip3 install --upgrade pip WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip. Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue. To avoid this problem you can invoke Python with '-m pip' instead of running pip directly. Defaulting to user installation because normal site-packages is not writeable Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Requirement already satisfied: pip in ./.local/lib/python3.7/site-packages (23.2.1) pi@VORON-24-SBC:~ $ pip install --upgrade pip WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip. Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue. To avoid this problem you can invoke Python with '-m pip' instead of running pip directly. DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality. Defaulting to user installation because normal site-packages is not writeable Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Requirement already up-to-date: pip in ./.local/lib/python2.7/site-packages (20.3.4) WARNING: You are using pip version 20.3.4; however, version 23.2.1 is available. You should consider upgrading via the '/usr/bin/python -m pip install --upgrade pip' command.
This post is deleted! -
@Gianluca said in AI Print Monitoring / Printer Health monitoring:
You may need to upgrade pip using python.
See if this post helps at all: https://github.com/pypa/pip/issues/5599
or if any of these commands work:
python3 -m pip install --upgrade pip
@Herve_Smith This Forum post was made prior to us planning on supporting DWC-only, since then we have developed a plugin that works with DWC-only configurations, see forum comment:
@DNvM84 @jay_s_uk
Test Mode
