Configuring custom printers
I have been looking through the forums for what seems like a long time, I’m looking for some kind of process or work flow when calibrating a new printer with a duet.
For instance I know that you’ll need to confirm feed rate before you can calibrate hotend temperature and retract speed. I’d like to tune my new build as efficiently as possible.
I copied the RepRap config that Chris’s basement posted a while ago as a starting point.. I gotta say, he’s got his set FAST. But there’s lots of holes in his guide.
I don’t wanna miss anything, the last time I set up a duet was 2018… and it’s been great since. But the I attempted to add a CR Touch to it and I fried it. It was epic, I pushed the pin and watched a little chip near the bottom turn red like a LED and POP.
@TOFUATSU the Ellis guide is pretty good to work through
https://ellis3dp.com/Print-Tuning-Guide/articles/index_tuning.html -
@TOFUATSU See the 'How to' guides on the Duet wiki: https://docs.duet3d.com/
