WiFi reported error: network scan failed
Also, just to be clear, the printer will print fine when supplied a gcode file on the SD card.
Before enabling access point mode did you configure the SSID and password, etc with M589?
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
When and where did you purchase the Duet?
@Phaedrux I did not configure the AP; I'll do that and report back.
This Duet was purchased from Filastruder around April 29, 2017. Been working well this whole time, thousands of hours of prints.
Are those SPI errors normal?
Let's see how AP mode goes. The SPI errors are normal in that they are a thing that can happen. But they are not ideal. It's possible that the wifi module is failing.
But try AP mode and try adding your SSID again.
TL;DR: AP mode works ok. Console output below (inputs hand-inserted as best I can).
I guess this implies that something about my router or the overall environment changed. I'm going to rebuild the router (little GL-MT300a box) and also see if I can get it positioned even closer to the Duet. I'll follow up if it turns out that I cannot get it to connect after the rebuild.
Any other thoughts?
Thanks for the help in debugging!
Rob
>> M589 S"DuetWifi" P"duetwifi" I192.168.11.1 Error: M589: Failed to configure access point parameters: WiFi module is disabled >> M552 S0 ok >> 589 S"DuetWifi" P"duetwifi" I192.168.11.1 ok >> M552 S2 WiFi module started ok ok WiFi module is providing access point DuetWifi, IP address 192.168.11.1 >> M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 08DAM-9K9K2-NGNS0-7JKDJ-3SJ6K-T70BL Used output buffers: 1 of 24 (24 max) === RTOS === Static ram: 23460 Dynamic ram: 73440 of which 60 recycled Never used RAM 15120, free system stack 108 words Tasks: NETWORK(ready,186) HEAT(blocked,294) MAIN(running,417) IDLE(ready,20) Owned mutexes: USB(MAIN) === Platform === Last reset 30:51:04 ago, cause: power up Last software reset details not available Error status: 0x0c Aux0 errors 0,0,0 MCU temperature: min 26.9, current 28.6, max 29.3 Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 27000, standstill, SG min/max not available Driver 1: position -23000, standstill, SG min/max not available Driver 2: position 172437, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-03-17 19:05:22 Cache data hit count 4294967295 Slowest loop: 99.86ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.8ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 829277, completed moves 829277, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 16.12ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is providing access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.25 WiFi MAC address 5e:cf:7f:37:8f:14 WiFi Vcc 3.40, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25672 WiFi IP address 192.168.11.1 Connected clients 1 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok ok
Well at least we know the wifi module is working.
@paralepsis I am having the same problem, except using the access point mode is not helping. Did you find a fix?
@tylersuard please start your own thread with your board info and M122 output
@tylersuard in my case I thought that the AP was fine, but in fact it had died.
@paralepsis The AP died, how did you handle it? Did you get a replacement from Duet, or ...?
