Problem with Duet 2 Wifi
@Phaedrux There is a www folder, with stuff in it, but I don't know what is supposed to be in it.
@Phaedrux Just the config.g folder was empty.
@mesacrash said in Problem with Duet 2 Wifi:
You mean file right? There should be no folder inside of the sys folder on the SD card.
Can you post your config.g.bak file that you renamed to config.g?
@Phaedrux Yes, in the sys folder was the config.g file, which was empty.
Can you send
M20 P"/www/"
and see what it responds with? It should gives you the contents of the www folder. -
@Phaedrux I can only send via YAT:
M20 P"/www/"
Begin file list<LF>NONE<LF>End file list<LF>ok<LF> -
@Phaedrux If I put the SD card in my computer, I can see folders and files.
@Phaedrux I remembered that I had an archive of the original SD card. I found there was a folder missing from my operational SD card. I put the folder in it and it still won't work. The board seems to know the SD card is mounted but doesn't recognize there are files on it.
@Phaedrux This is the second time this has happened to me. The board in the machine is a replacement for the first board. 3dWorld replaced the first board, should I contact them, perhaps? The first one lasted about a month. This one has been running about 5 months. And running well, I might add.
The first one blew a fuse as well?
Can you post some close up photos of the board please? Perhaps we can spot some damage.
It would be a good idea to find out what is shorting a damaging the boards before replacing it again.
@Phaedrux The first one did NOT blow a fuse, however the symptoms are similar. I am very skilled in electronics and I don't find anything that would cause a short. I have replaced the fuse with a 1 amp fuse and it is still good after 4 days. Things other than a short can cause a fuse to blow. Like the board itself.
The similarities start and end with the SD card no longer reading the card. The first board lasted a month, yet this one ran for 5 months. This machine has printed a lot of filament, well. I see no reasonable answer for this.
@Phaedrux I think I got it. Sometimes a change in the weather will accelerate oxidation between connections. I went through the screw connections, loosened them then tightened them. Boom, it connected and is reading everything. I will test it tomorrow.
@Phaedrux It is working fine.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
