Updating a Duet2Wifi DuetWifiServer
I hope it is everything this time. But i can read something about Wifi at the end so i hope thats it.
M122<CR>
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
Board ID: 08DDM-9FAM2-LW4S4-6J9FL-3S86M-KJSBX
Used output buffers: 1 of 26 (1 max)
Static ram: 23836
Dynamic ram: 73384 of which 0 recycled
Never used RAM 14860, free system stack 184 words
Tasks: NETWORK(ready,7.5%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,91.9%,620) IDLE(ready,0.6%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:02:13 ago, cause: power up
Last software reset details not available
Error status: 0x00
Step timer max interval 0
MCU temperature: min 26.5, current 31.3, max 31.5
Supply voltage: min 0.5, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 2.22ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 0.18ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
= WiFi =
Network state is disabled
WiFi module is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
ok -
Can you extract the full contents of this zip file into your firmware folder?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
Then try sending these commands and report back what they return.
M552
M552 S-1
M552 S0
M552 S1
M997 S1 -
M552
okM552 S-1
okM552 S0
okM552 S1
Turn off the current WiFi mode before selecting a new one
okM997 S1
Error: M997: File 0:/firmware/DuetWiFiServer.bin not found
ok -
"WiFi module started
Error: failed to initialise WiFi module: bad reply format version"This Message Came after some secounds too.
Complete answer to the M997 S1:
M997 S1
ok
WiFi module started
Error: failed to initialise WiFi module: bad reply format version -
Do you have a new SD card to test with? Formatted as FAT32.
Hello @Phaedrux ,
The SD Card i used was FAT32 already, but i have a 32GB FAT 32 that i just tested, unfortunatly the result of the:
M552
M552 S-1
M552 S0
M552 S1
M997 S1Commands were the same:
M552
ok
M552 S-1
ok
M552 S0
ok
M552 S1
ok
M997 S1
ok
WiFi module started
Do you still have the wifi server bin file in the sys folder as well?
Try
M997 S1 P"0:/sys/DuetWiFiServer.bin"
after the SD Card Swap there was only the files from the Zip file in the firmware folder.
But now i copied the firmware folder and called it sys.
I tried the command in YAT:
<LF>
Trying to connect at 230400 baud: success<LF>Erasing 8192 bytes...<LF>Erasing 269216 bytes...<LF>Uploading file...<LF>5% complete<LF>10% complete<LF>15% complete<LF>20% complete<LF>25% complete<LF>30% complete<LF>35% complete<LF>40% complete<LF>45% complete<LF>50% complete<LF>55% complete<LF>60% complete<LF>65% complete<LF>70% complete<LF>75% complete<LF>80% complete<LF>85% complete<LF>90% complete<LF>95% complete<LF>Upload successful<LF>ok<LF> -
Ok so that's promising. The firmware was updated successfully.
Can you now try the same sequence of commands?
M552
M552 S-1
M552 S0
M552 S1Have you tried adding an SSID with M587 yet? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m587-add-wifi-host-network-to-remembered-list-or-list-remembered-networks
Not sure why your firmware folder didn't work before. I think you have something wrong with your SD card folder structure.
See here for details on what folders are required to be present on the SD card: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
Unfortonatly something still went wrong, the error messages do not give me a clue to what it might be.
M552
ok
M552 S-1
ok
M552 S0
ok
WiFi module started
M552 S1
ok
Error: WiFi module reported: no known networks found
WiFi module is idle
WiFi module is idle
M587 S"MyWifi" P"MyPW"
Error: M587: Failed to add SSID to remembered list: SPI timeout
ok
Error: failed to retrieve WiFi status message: SPI timeout
WiFi module is idle
Error: failed to change WiFi mode: SPI timeout"Error: WiFi module reported: no known networks found
WiFi module is idle"This message comes now quite often. Before today i never had this, but i read that it is not unusual.
I even did the reformating the 4 GB SD Card.
Well the module is responding now.
Can you send M122 again and share the results again?
Please send
M588 S"*"
to clear out any saved networks and try adding again. -
thats good to hear, that it is moving into the right direction.
M122
Used output buffers: 1 of 26 (11 max)
Static ram: 23836
Dynamic ram: 74792 of which 20 recycled
Never used RAM 13432, free system stack 193 words
Tasks: NETWORK(ready,8.6%,335) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,363) MAIN(running,91.3%,458) IDLE(ready,0.0%,30), total 100.0%
Last reset 00:01:29 ago, cause: reset button or watchdog
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 32.6, current 32.8, max 33.7
Supply voltage: min 1.3, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Cache data hit count 3638083520
Slowest loop: 2.24ms; fastest: 0.14ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Code queue is empty
=== Network ===
Slowest loop: 99.91ms; fastest: 0.00ms
= WiFi =
Failed messages: pending 0, notready 0, noresp 3
okFor the other command:
M588 S""
Error: M588: Failed to reset the WiFi module to factory settings: WiFi module is disabled
ok
M552
ok
M552 S-1
ok
M552 S0
ok
WiFi module started
M588 S""
oki´m waiting for your response before trying to safe an other network again. Not that I undo something by accident
Can you send M552 S1 and then send M122?
@Milan-R said in Updating a Duet2Wifi DuetWifiServer:
M588 S""
There needs to be an
between the quotes. -
weird it was in Yat but somehow got lost.
Well but i tried:
M588 S"*"
M552 S1
M122M588 S""
ok
M552 S1
ok
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
M122
Static ram: 23836
Tasks: NETWORK(ready,7.6%,335) HEAT(notifyWait,0.0%,349) Move(notifyWait,0.0%,363) MAIN(running,92.4%,458) IDLE(ready,0.0%,30), total 100.0%
Last reset 00:51:52 ago, cause: reset button or watchdog
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 32.5, current 36.3, max 36.5
Supply voltage: min 1.3, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 99.50ms; fastest: 0.14ms
=== Storage ===
SD card longest read time 2.0ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Code queue is empty
=== Network ===
Slowest loop: 1.35ms; fastest: 0.00ms
= WiFi =
Network state is changingMode
WiFi module is idle
Failed to get WiFi status
ok
WiFi module is idle
M588 S""
ok -
WiFi module is idleOk, so now let's try adding your SSID again.
i was confinced that it would work this time
I tried the steps: "Set WiFi to idle mode","Configure network SSID and password","Enable networking"
Error: WiFi module reported: no known networks found<LF>WiFi module is idle(...)
M552 S-1
WiFi module stopped<LF>ok<LF>
M552
WiFi module is disabled<LF>ok<LF>
M552 S0
ok<LF>WiFi module started<LF>
M552
WiFi module is idle<LF>ok<LF>
M587 S"OneDoesNotSimplyConnectToWifi2" P"BLANKED"
ok<LF>
M587
Remembered networks:<LF>OneDoesNotSimplyConnectToWifi2 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
M552 S1
ok<LF>Error: WiFi module reported: no known networks found<LF>WiFi module is idle(...)<LF>Error: WiFi module reported: no known networks f[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.]I ran a M122 too:
Under the headline wifi something changed:
Network state is active
WiFi module is idle
WiFi firmware version 1.27
WiFi MAC address a0:20:a6:19:22:84
WiFi Vcc 3.29, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 28576
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
When and where did you purchase your Duet wifi?
i got it on ebay (kleinanzeigen) so not the online shop.
But as far as i could tell it is an original. I googled a little to dopple check.
But i´ll ask for the Bill so i can see when it was bought
M552
ok<LF>
M587
M552 S1
ok<LF>Error: WiFi module reported: no known networks foundCan you confirm that the wifi network you are using is 2.4ghz? The Duet cannot connect to 5ghz networks.
i got it on ebay
Unfortunately there would be no warranty in this case.
wow ok that was my bad, but also i have to talk to my roommates
The Wifi name is slightly different between the 2,4 ghz and the 5 hgz. Just the F in wifi is caps or not.
Now i could connect.
So sorry to go to all this writing because of my supidity...
But now it seems to work THANKS once again.
i´m so embarresed
