Help!! Didn’t find access point while trying to connect
Can you send M122 and copy and paste the full reply here?
@Phaedrux trying to, but marked as spam
Give it a minute and try again.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DGMSN-6J1F0-3S06P-KBQMG
Used output buffers: 1 of 24 (1 max)
Static ram: 25712
Dynamic ram: 93216 of which 0 recycled
Exception stack ram used: 304
Never used ram: 11840
Tasks: NETWORK(ready,1244) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
Owned mutexes: -
@Dillon-Brown === Platform ===
Last reset 04:02:15 ago, cause: power up
Last software reset time unknown, reason: Heat task stuck, spinning module GCodes, available RAM 11484 bytes (slot 1)
Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049ac Task 0x4e49414d
Stack: 004486cf 0044a266 01001400 00000000 000004d9 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f 3c0281fc 3e3a3325 3e638e29 3e924925 3885108c 397d66d2 c0a00000 00000000 60000010 0043db4f 00000062 0043b3bb
Error status: 0
Free file entries: 10
MCU temperature: min 19.4, current 33.1, max 33.4
Supply voltage: min 0.0, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Slowest loop: 200.62ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is assembling a command in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 8486.38ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi module is idle
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b2:15:56
WiFi Vcc 3.43, reset reason Hardware watchdog
WiFi flash size 4194304, free heap 23624
=== Filament sensors ===
Extruder 0 sensor: no filament
ok
- WiFi -
Can you send
M997 S1
in the usb terminal? That will force a reflash of the wifi module. -
@Phaedrux whats the usb terminal? Just the serial tools app ive been using to communicate?
@Dillon-Brown this is what i get back from M997 S1
M997 S1
Trying to connect at 230400 baud: success
Erasing 4096 bytes…
Erasing 212992 bytes…
Uploading file…
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
ok -
@Dillon-Brown I then tried M552 S1 and wifi went idle with no known networks found
@Dillon-Brown I may have to call spectrum and get them to direct away from my 5 ghz network again
Have you sent the M587 command to add your wifi SSID and password?
And yes, it will only connect to a 2.4ghz access point.
