z offsets for different tools
Unfortunately that did not help
M208 X-35:328.5 Y-49:245 Z-20:300 C-45:360
But it think it goes into the wrong direction because the nozzle is lower than the switch probe. Probing can only work without a tool.
@MIke-1 whats in your homez?
@jay_s_uk
This here after probing:
Tool T1
Tool T2
With
; G10 OFFSETS
G10 P0 X20.803 Y43.444 Z-5.07 ; Set tool 0 axis offsets
G10 P1 X-7.861 Y38.650 Z-5.71 ; Set tool 1 axis offsets
G10 P2 X20.615 Y43.681 Z-16.41 ; G10 P2 X20.615 Y43.681 Z-6.06 mehr Abstand z.b. von -1 nach -2 (Offset wird kleiner) ; Set tool 2 axis offsets
G10 P3 X-7.717 Y38.818 Z-5.61 ; Set tool 3 axis offsetsBut I dont see this effect on the nozzle
@MIke-1 ok, whats in you tpre2.g and tpost2.g?
@MIke-1 you aren't restoring the X/Y/Z position in tpost. see here https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#:~:text=After changing tool,or similar commands.
@MIke-1 yea
It is not working. The first layer with the first extruder is fine. After the extruder change the layer is more or less on the same level, as they are on a similar hight. The second layer has a big offset to the first one with the second extruder because the offset in the config is unrelistic to high to check the functionality.
A Z move is needed in the gcode to get on the right level...; tpost2.g
; called after tool 2 has been selected;heatup
M116 P2
M116 H0 S5;prime nozzle
;M98 P"prime.g"M98 P"brush_right"
M106 R1 ; restore print cooling fan speed
;M593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
G60 S0
G1 R0 X0 Y0 Z-5;G91
;G1 Z-5 F1000
;G90 -
@MIke-1
This here at the very end fixted the issue!G1 R2 Z2 F2000
G1 R2 Z0 F2000Thanks to the Duet Team!
