Solved Gcode "Look Ahead" Limit for Variable Setting
Is there some form of "look ahead" with the Duet control interpreting the Gcode? I am using global variables to set values based on conditional events that occur in specific points within the gcode. For example after a specific layer is completed and a desired temperature is set.
However, I notice the variable is set before the linear motion has occurred. Is there a way to wait until a linear motion has completed before setting a variable?
For example - HAAS machine tools use G103 - see below
@chrishamm SOLVED - Thanks
M400 did the trick. -
