Extruder Too Hot
I had this issue before, I thought it was solved, but it is still ongoing.
I have a small printer. With heated bed (24V), Bondtech drive and Mosquito magnum extruder, 24V heatsink fan. (24 V heater with pt100 temp sensor and pt100 daughterboard).
I have tuned both heaters. The bed heater will stay consistent at temperature that was set.
However the extruder will go beyond the set temperature by almost 10 deg F.What could be the cause of this?
Thank you
@djthuma please try tuning the heater again and take a screen shot of the heater tuning process. and the output when it completes.
@T3P3Tony
I think I figured it out!I was changing the M307 setup in the config.g file.
But I forgot that the config override contained heater settings aswell. So those would eliminate the correct tuning of the config file.
I have updated the config override and it is remaining stable at printing temp.
Thanks, still learning, again
