Solved Input Shaping
What version is your input shaping plugin?
@SonnyD1 said in Input Shaping:
my wifi module changes from Idle to connecting, and then changes again from connecting to idle and reconnects.
Is the printer behaving normally otherwise?
Version 3.4.1-b1
I am getting a wifi module error that I have another thread on. I believe they are unrelated though. Otherwise, everything is functioning normally. I'm not sure if it matters but, the toolhead does move from the home position (middle of the bed) to the 20 position and then stops. It doesn't move the the requested 200.
How is the accelerometer wired?
@Phaedrux
Like so...hopefully this makes sense.
What kind of wire? How long?
@Phaedrux I’m using 1.5m stepper wires.
@SonnyD1 that won't be good enough. Best use USB3 cable as it's shielded
@jay_s_uk How much does the length matter and how long should I aim for?
@SonnyD1 I use a 2.7m USB3 cable so any length should be fine
@jay_s_uk Apparently that was the issue. I bought a USB 3.0 cable and made it up and now its working. Don't know what to do with that data yet but thats a different issue. I'm making progress thanks to the help. Thank you.
