beta 3.5b2 no wifi re connection after emergency stop
@moth4017 is that using the emergency stop button in DWC? if possible can you connect a USB cable and see if you can reproduce it, then send M552 and M122 over USB and report the results here.
@T3P3Tony i would do this but for some reason i can no longer get the com port to work
can i use M929 to log the info required?
@T3P3Tony
eventlog.txt logfile if you look at the logfile i hit the "emergency stop" button in DWC after the "homez.g" -
@moth4017 that shows the WiFi module starting and reconnecting
@T3P3Tony the resart was me pushing the reset button on the duet 3mini5 so I could get access to the log file via DWC , I could just pull the SD card and get the data with out a restart
Data from SD card after the "Please stand by...." message ion DWC
in the log file "emergency stop" in DWC was pressed during the home z.g macro
eventlog1.txt -
I am very happy with 3.5b2 so far, but suddenly, I've realized that I have the same issue on the mini5 Ethernet. I have to reboot the board to reconnect DWC.
I'll do some more tests later tonight if I have a chance.
@terabyte
Hi , i have lost my usb connection but could you see if you can do what Tony suggestedIf possible can you connect a USB cable and see if you can reproduce it, then send M552 and M122 over USB and report the results here.
I can also confirm this is a problem for me as well. I am using a 6HC with SBC. I have to power cycle the whole machine to get it through the issue. Simply rebooting the Pi4 will not solve the problem.
Here is an M122 after reboot.
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5beta2 (2023-02-08 15:27:50) running on Duet 3 MB6HC v1.0 or earlier (SBC mode) Board ID: 08DJM-956L2-G43S4-6J1FD-3SJ6T-TB6QH Used output buffers: 1 of 40 (17 max) === RTOS === Static ram: 154344 Dynamic ram: 85824 of which 2892 recycled Never used RAM 99556, free system stack 200 words Tasks: SBC(ready,0.7%,418) HEAT(notifyWait,0.0%,325) Move(notifyWait,0.0%,342) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,340) TMC(notifyWait,6.0%,90) MAIN(running,92.5%,160) IDLE(ready,0.8%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:01:45 ago, cause: power up Last software reset at 2023-03-10 21:36, reason: User, Gcodes spinning, available RAM 99556, slot 1 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 132 MCU temperature: min 23.5, current 24.4, max 37.5 Supply voltage: min 0.2, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 0.2, current 12.2, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/1472/1232, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 8, reads 52289, writes 11 timeouts 0 Driver 1: standstill, SG min 0, mspos 8, reads 52289, writes 11 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0 Driver 5: standstill, SG min 0, mspos 8, reads 52283, writes 18 timeouts 0 Date/time: 2023-03-11 11:47:31 Slowest loop: 2.36ms; fastest: 0.06ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x80000003 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === Extruder 0: no data received === CAN === Messages queued 892, received 4517, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 49166, free buffers 50 (min 49), ts 528/400/0 Tx timeouts 0,0,127,0,0,0 last cancelled message type 30 dest 127 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 3297/3297 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x26934 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-beta.2 (2023-02-08 11:47:09) Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 14.41, max time between full transfers: 286.2ms, max pin wait times: 34.3ms/7.2ms Codes per second: 0.60 Maximum length of RX/TX data transfers: 4505/804
Same here. After Emergency stop, DWC stuck in please wait. Presing reset buton on 6HC bring machine back to life.
6HC + 1LC, SBC.
if you refresh the browser you still get the "Please stand by "........ message , i still carnt get my USB to connect so i carnt grab the data.
Also i have noticed that i cannot connect to the printer, if the printer is on before the PC which i use to connect to the printer . pressing the reset button on the printer then gets a connection .
ive also tried this on a stm board running 3.5b2 same issue if you press "emergency stop" in DWC you get the "Please stand by "........ message untill you reset the control board.
