IS on a bedslinger with 2 accelerometers
How can I best get out a good result as I have a bedslinger X with toolboard and Y with separate accelerometer. Documentation says that single axis measurement is not possible.
@tecno, what documentation says that?
The page https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping_plugin explicitly says the opposite - "It is recommended to configure only those axes that actually have an accelerometer fitted. Assuming you have a bed slinger and the accelerometer is only mounted on X (print head), record only moves on the X axis. "
On mine, I just did X and Y as separate processes. For Y I fixed accelerometer to the bed, for X I fixed it to the print-head. I had no difficulty telling the plugin to only do one axis, and then I found a shaper setting that worked for both.
@achrn
OK, a missunderstanding for me then. So I will just continue playing around and see what I can get.Thanks
Bengt -
@achrn said in IS on a bedslinger with 2 accelerometers:
