    Skew calibration with calibration square? Maths help needed
    2.2k
    • oliofundefined
      oliof @droftarts
      @droftarts Klipper uses the diagonals to compute as well, see https://www.klipper3d.org/Skew_Correction.html
      A Macro with parameters would be nice, I just need to know the maths (-:
        droftarts administrators @oliof
        @oliof It's in the Marlin firmware link I posted:
         * Marlin automatically computes skew factors from these measurements.
         * Skew factors may also be computed and set manually:
         *  - Compute AB     : SQRT(2*AC*AC+2*BD*BD-4*AD*AD)/2
         *  - XY_SKEW_FACTOR : TAN(PI/2-ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)))
         * If desired, follow the same procedure for XZ and YZ.
         * Use these diagrams for reference:
         *    Y                     Z                     Z
         *    ^     B-------C       ^     B-------C       ^     B-------C
         *    |  A-------D          |  A-------D          |  A-------D
         *    +-------------->X     +-------------->X     +-------------->Y
         *     XY_SKEW_FACTOR        XZ_SKEW_FACTOR        YZ_SKEW_FACTOR
        Cartesian bed-slinger with Duet 3 Mini 5+ WiFi and 1LC : RRP Fisher Delta v1 with Duet 2 Maestro : TronXY X5S with Duet 3 MB6HC and Roto toolboard
        oliofundefined 1 Reply Last reply Reply Quote 1
        • oliofundefined
          oliof @moth4017
          @moth4017 you could probably check the source code repositories to figure out who wrote it.
          • oliofundefined
            oliof @droftarts
            @droftarts Thanks, I completely missed that (-: I think I will be able to sort it from here.
              @oliof M291 in RRF v3.5beta1 has been extended to allow user input with S4/5/6/7. But you can just have a gcode with a list of variables to set, get it to "do the math(s)" and set M556.
              • oliofundefined
                oliof @droftarts
                @droftarts a parametrized macro would be perfectly fine.
                droftartsundefined 2 Replies Last reply Reply Quote 0
                  @oliof Okay, that took a little time! Marlin's M852 uses the ‘skew factor'; Klipper and Marlin (in configuration.h) allow you to put the measured diagonals in, and calculates the skew factor from them. RRF's M556 uses the physical distance of measuring points, and converts these internally, or put the skew factor in directly (see following post).
                  To allow RRF to use the diagonal measurement of a test piece, we need to calculate the skew factor from those measurements. I drew a quick test in OnShape to check my maths:
                  You can play around with this here (open 'Sketch1' and select 'Top' view): https://cad.onshape.com/documents/6ff12352632c0ad7ab55a879/
                  And then did some meta Gcode to calculate the skew distance/factor using the Marlin formulae. The file below calculates the distance AB for each of XY, XZ and YZ, then calculates the (Marlin) skew factor (which could be used directly to set M556, see following post), then calculates the skew mm offset for the given side length (AD - this is the same for XY, XZ and YZ, though could be changed so they can be different) for M556 in RRF. It sets M556, then sends M556 again to report the skew factor in use, which should look like the Marlin skew value, as RRF converts the skew mm offset to skew factor internally. Hope that helps!
                  ;    Y                     Z                     Z
                  ;    ^     B-------C       ^     B-------C       ^     B-------C
                  ;    |  A-------D          |  A-------D          |  A-------D
                  ;    +-------------->X     +-------------->X     +-------------->Y
                  var AD = 200
                  var XY_AC = 331.229
                  var XY_BD = 241.842
                  var XY_skew_mm = 0
                  var XZ_AC = 262.488
                  var XZ_BD = 304.795
                  var XZ_skew_mm = 0
                  var YZ_AC = 283.551
                  var YZ_BD = 282.137
                  var YZ_skew_mm = 0
                  ; Compute XY
                  var XY_AB = sqrt((2 * (var.XY_AC * var.XY_AC)) + (2 * (var.XY_BD * var.XY_BD)) - (4 * (var.AD * var.AD)))/2
                  var XY_skew_factor = tan(pi/2-acos((var.XY_AC * var.XY_AC - var.XY_AB * var.XY_AB - var.AD * var.AD)/(2 * var.XY_AB * var.AD)))
                  if (var.XY_AC-var.XY_BD>=0)
                  	set var.XY_skew_mm = sqrt(var.XY_AB * var.XY_AB - var.AD * var.AD)
                  else
                  	set var.XY_skew_mm = -sqrt(var.XY_AB * var.XY_AB - var.AD * var.AD)
                  ; Compute XZ
                  var XZ_AB = sqrt((2 * (var.XZ_AC * var.XZ_AC)) + (2 * (var.XZ_BD * var.XZ_BD)) - (4 * (var.AD * var.AD)))/2
                  var XZ_skew_factor = tan(pi/2-acos((var.XZ_AC * var.XZ_AC - var.XZ_AB * var.XZ_AB - var.AD * var.AD)/(2 * var.XZ_AB * var.AD)))
                  if (var.XZ_AC-var.XZ_BD>=0)
                  	set var.XZ_skew_mm = sqrt(var.XZ_AB * var.XZ_AB - var.AD * var.AD)
                  else
                  	set var.XZ_skew_mm = -sqrt(var.XZ_AB * var.XZ_AB - var.AD * var.AD)
                  ; Compute YZ
                  var YZ_AB = sqrt((2 * (var.YZ_AC * var.YZ_AC)) + (2 * (var.YZ_BD * var.YZ_BD)) - (4 * (var.AD * var.AD)))/2
                  var YZ_skew_factor = tan(pi/2-acos((var.YZ_AC * var.YZ_AC - var.YZ_AB * var.YZ_AB - var.AD * var.AD)/(2 * var.YZ_AB * var.AD)))
                  if (var.YZ_AC-var.YZ_BD>=0)
                  	set var.YZ_skew_mm = sqrt(var.YZ_AB * var.YZ_AB - var.AD * var.AD)
                  else
                  	set var.YZ_skew_mm = -sqrt(var.YZ_AB * var.YZ_AB - var.AD * var.AD)
                  echo "XY: AB ", var.XY_AB, " Skew mm " , var.XY_skew_mm, " Skew factor ", var.XY_skew_factor
                  echo "XZ: AB ", var.XZ_AB, " Skew mm " , var.XZ_skew_mm, " Skew factor ", var.XZ_skew_factor
                  echo "YZ: AB ", var.YZ_AB, " Skew mm " , var.YZ_skew_mm, " Skew factor ", var.YZ_skew_factor
                  M556 S{var.AD} X{var.XY_skew_mm} Y{var.XZ_skew_mm} Z{var.YZ_skew_mm}
                  M556
                  Sample output:
                  M98 P"0:/macros/Skew calibration"
                  XY: AB  210.0002  Skew mm  64.03204  Skew factor  0.3201567
                  XZ: AB  202.2374  Skew mm  -29.9996090  Skew factor  -0.1500003
                  YZ: AB  200.0031  Skew mm  1.105738  Skew factor  0.0049993
                  Axis compensations - XY: 0.32016, YZ: -0.15000, ZX: 0.00553
                  OwenDundefined 1 Reply Last reply Reply Quote 2
                    @oliof Also just found out (from @dc42) that if you use S1 in M556 then XYZ values are the skew factors!
                    • oliofundefined
                      oliof @droftarts
                      @droftarts Fantastic, thanks!
                        @oliof No worries, good meta gcode practice for me! I'm updating the main post for clarity, so might change in the next few minutes (but not the code). Let me know if you need it to do something different.
                        • oliofundefined
                          oliof @droftarts
                          @droftarts I think just adding parameters so this can be put in as an M556.1 would be a great addition.
                            @oliof I asked @dc42 that exact question, with that exact Gcode! However, I'm not even sure how many people are using skew compensation as to whether it's worth it, now that there is this workaround for diagonal lengths. Probably not a high priority. Feel free to add it to the firmware wishlist, though, see if it gets any traction.
                            It's also a question about whether this is a more accurate method of measuring skew than the existing method, though at least it doesn't need any extra vitamins. The accuracy of both methods depends on whether there are corner bulges and how uniform/good the print is. Any feedback on that would be useful.
                            • OwenDundefined
                              OwenD @droftarts
                              @droftarts
                              I'm not sure I agree with your drawing (as it applies to the calculations in Marlin).
                              If the X and Y axis are skewed you should end up with a rhombus.
                              i.e. all four sides are the same lengths, but the corner angles are no 90 degrees.
                              I came up with this macro
                              It requires RRF 3.5.0b1+ as it takes user input in M291
                              When you enter the measured length of the first diagonal it calculates what the other diagonal should be and puts that in as the default.
                              I have checked my calculations against this formula and they seem correct.
                              It also seems to work with the 100mm3 test piece I printed, although my printed Z dimensions do not match what they should be.
                              Someone has logged this as a bug, so I'm not sure if that's the cause
                              I think if we use M556 P1, the results can be directly applied.
                              I'd love if someone could review my methodology.
                              EDIT:
                              Code changed to correct mistake in calculating area and expected diagonals of rhombus
                              ; set_skew_M556.g
                              ; calculate the skew values based on diagonal measurements of a test object
                              ;  https://www.thingiverse.com/thing:2972743/comments
                              ; Mark the test point corners A,B,C,D as per the diagram below
                              ; computation formulae from Marlin firmware
                              ;  - Compute AB     : SQRT(2*AC*AC+2*BD*BD-4*AD*AD)/2
                              ;  - XY_SKEW_FACTOR : TAN(PI/2-ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)))
                              ; If desired, follow the same procedure for XZ and YZ.
                              ; Use these diagrams for reference:
                              ;    Y                     Z                     Z
                              ;     XY_SKEW_FACTOR        XZ_SKEW_FACTOR        YZ_SKEW_FACTOR
                              var xySkew = 0
                              var xzSkew =0
                              var yzSkew = 0
                              M291 S3 P"Measure X-Y Skew?" R"Measure X-Y"
                              G4 P200
                              ; Maximum size limited to whichever axis is smallest
                              var max = min(move.axes[0].max,move.axes[1].max,move.axes[2].max)
                              M291 S6 P{"Enter side length of square (mm) max = " ^ var.max} R"Square" L10 H{var.max} F100.00 J1
                              var calculatedDiagonal = sqrt((input*input) + (input*input))
                              var A_D = input
                              var x2 = move.axes[0].max * move.axes[0].max
                              var y2 = move.axes[1].max * move.axes[1].max
                              ; limit the diagonal to teh max possible iin the print volume
                              var maxDiagonal = sqrt(var.y2 + var.x2)
                              M291 S6 P"Enter A -> C measurement" R"A -> C"  R"X -> Y"  F{var.calculatedDiagonal} L10.0 H{var.maxDiagonal} J1
                              var A_C = input
                              ; calculate area of rhombus given one side and diagonal
                              ; 1/2 var.A_D sqrt(4*var.A_D*var.A_D)  - var.A_C * var.A_C
                              var area = 1/2* var.A_C * sqrt(4 * var.A_D * var.A_D  - var.A_C * var.A_C)
                              echo "Area = " ^ var.area
                              var difXY =  (var.area / var.A_C) * 2 ; calculates second diagonal of a rhombus given length of first
                              M291 S6 P"Enter B -> D measurement" R"B -> D" R"X -> Y" F{var.difXY} L10.0 H{var.maxDiagonal} J1
                              var B_D = input
                              var A_B = sqrt((2 * var.A_C * var.A_C) + (2 * var.B_D * var.B_D) - (4 * var.A_D * var.A_D))/2
                              set var.xySkew = tan(pi/2-acos((var.A_C*var.A_C-var.A_B*var.A_B-var.A_D*var.A_D)/(2*var.A_B*var.A_D)))
                              echo "Set M556 for X-Y Skew to M556 S1 X" ^ var.xySkew ^ " Ynn Znn"
                              G4 P200
                              M291 S4 P{"Apply skew (" ^ var.xySkew ^ ") to X-Y?"} R"Apply?" K{"Yes","No"} F0 J1
                              if input = 0
                              	M556 S1 X{var.xySkew}
                              else
                              	set var.xySkew = 0 ; revert back to zero as not applied
                              G4 P200
                              ; move to X Z
                              M291 S3 P"Continue to X-Z Skew?" R"Measure X-Z"
                              G4 P200
                              M291 S6 P"Enter A -> C measurement" R"A -> C" R"X -> Z" F{var.calculatedDiagonal} L10.0 H{var.maxDiagonal} J1
                              set var.A_C = input
                              set var.area = 1/2* var.A_C * sqrt(4 * var.A_D * var.A_D  - var.A_C * var.A_C)
                              var difXZ =  (var.area / var.A_C) * 2 ; calculates second diagonal of a rhombus given length of first
                              echo var.difXZ
                              M291 S6 P"Enter B -> D measurement" R"B -> D" R"X -> Z" F{var.difXZ} L10.0 H{var.maxDiagonal} J1
                              set var.B_D = input
                              set var.A_B = sqrt((2 * var.A_C * var.A_C) + (2 * var.B_D * var.B_D) - (4 * var.A_D * var.A_D))/2
                              set var.xzSkew = tan(pi/2-acos((var.A_C*var.A_C-var.A_B*var.A_B-var.A_D*var.A_D)/(2*var.A_B*var.A_D)))
                              echo "Set M556 for X-Z skew to M556 S1 Xnn Ynn Z"^ var.xzSkew
                              G4 P200
                              M291 S4 P{"Apply Skew (" ^var.xzSkew ^ ") to X-Z?"} R"Apply?" K{"Yes","No"} F0 J1
                              if input = 0
                              	M556 S1 Z{var.xzSkew}
                              else
                              	set var.xzSkew = 0 ; revert to zero as not applied
                              G4 P200
                              ; move to Y Z
                              M291 S3 P"Continue to Y-Z Skew?" R"Measure Y-Z"
                              G4 P200
                              M291 S6 P"Enter A -> C measurement" R"A -> C" R"Y -> Z" F{var.calculatedDiagonal} L10.0 H{var.maxDiagonal} J1
                              set var.A_C = input
                              var difYZ =  var.area / var.A_C * 2
                              echo var.difYZ
                              M291 S6 P"Enter B -> D measurement" R"B -> D" R"Y -> Z" F{var.difYZ} L10.0 H{var.maxDiagonal} J1
                              set var.B_D = input
                              set var.yzSkew = tan(pi/2-acos((var.A_C*var.A_C-var.A_B*var.A_B-var.A_D*var.A_D)/(2*var.A_B*var.A_D)))
                              echo "Set M556 for Y-Z skew to M556 S1 Xnn Y" ^ var.yzSkew ^ "Znn"
                              M291 S4 P{"Apply skew (" ^var.yzSkew ^ ") to Y-Z?"} R"Apply?" K{"Yes","No"} F0 J1
                              if input = 0
                              	M556 S1 Y{var.yzSkew}
                              else
                              	set var.yzSkew = 0 ; revert back to zero as not applied
                              if (move.compensation.skew.tanXY != var.xySkew) || (move.compensation.skew.tanXZ != var.xzSkew) || (move.compensation.skew.tanYZ  != var.yzSkew)
                              	echo "Calculated skew settings should be:"
                              	echo "M556 S1 X" ^ {var.xySkew}^ " Y" ^ {var.yzSkew} ^ " Z" ^ {var.xzSkew}
                              	echo "Actual setting"
                              	M556
                              	M291 S4 P{"One or more skew settings has not been applied - Apply Now?"} R"Settings not applied?" K{"Yes","No"} F0 J1
                              	if input = 0
                              		M556 S1 X{var.xySkew} Y{var.yzSkew}	Z{var.xzSkew}
                              		M556
                              M291 S1 T10 P"Review results in console or send M556 to confirm" R"Done"
                              OwenDundefined 1 Reply Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @OwenD
                                @droftarts
                                I just ran your macro against mine and they essentially gave the same output when the same values were used, so I think I've misunderstood how you applied the measurements based on your drawing.
                                var AD = 180
                                var XY_AC = 244
                                var XY_BD = 265.57
                                var XY_skew_mm = 0
                                var XZ_AC = 254.5584
                                var XZ_BD = 254.5584
                                var XZ_skew_mm = 0
                                var YZ_AC = 254.5584
                                var YZ_BD = 254.5584
                                var YZ_skew_mm = 0
                                your output
                                My output
                                OwenDundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                • OwenDundefined
                                  OwenD @OwenD
                                  Thinking on all this, I have to say that in many ways, the RRF method of using the measured skew at a given distance from a plane does probably make for an easier method.
                                  It means you don't have to worry about over/under extrusion or other factors affecting the printed part size.
                                  If I'm using diagonals then it only works if the printed part is exactly dimensionally accurate. Especially if it's based on a cube or square.
                                  If I print something that's supposed to be 100x100x100 and it ends up 99.6 x 100 x 101.2 then my macro doesn't really work.
                                  But if I print something approximately 110x110x110 and measure the skew at 100mm from the plane then the angles will be correct regardless of the actual dimension.
                                  To me that probably gives you more chance of getting accurate skew settings without other possible inaccuracies in the system getting in the way.
                                  Alternately we'd have to measure the actual dimensions on each face and calculate to diagonals of a parallelogram.
                                  In truth it's probably taken longer to do the macro to use diagonals than it would have to make a measuring tool per the RRF docs.
                                  As mentioned above, for some reason the diagonal measurement test piece I did was quite a bit out on the Z direction. (>1.5mm too high)
                                  X & Y are near perfect (<0.2mm from dimension)
                                  I have checked that Z steps are correct by measuring from frame to X gantry, carrying out a 100mm move and measuring again. Actual movement it exactly 100mm.
                                  WTF?
                                  Now I'm printing a plain 100mm cube to double check.
                                  Down the rabbit hole I go 😕
                                    droftarts administrators @OwenD
                                    @OwenD Thanks for chiming in! I was thinking about this earlier, and I think you are correct. I took the Marlin formulae as correct, and didn't think it through. The shape produced from misaligned axes would be a rhombus not a parallelogram. The two axes, assuming they have been configured correctly, should move the set distance in their plane, so the square would deform into a rhombus.
                                    So, we shouldn't be calculating AB; AB = AD. Your calculations work in the same way as mine, taken from Marlin; AB is calculated where the point B is perpendicular to AD, at the distance AD. I haven't sat down and drawn out the two formula that Marlin uses, I took it that they were correct... but perhaps they are not! I did notice some small differences when calculating the skew factor from the Marlin formulae vs from the measured skew (the old way of doing it).
                                    The interesting thing about the old way of doing this is that it is unambiguous. Take this:
                                    If you measure up 150mm, you get a skew distance of 30mm. Skew factor is 30/150=0.2
                                    If I run these diagonals and AD of 200 through yours I get 0.1999988, and through mine I also get 0.1999988, which is, arguably, very close. But it feels it should work out to 0.2!
                                    However, as we're assuming the square deforms into a rhombus, the nice thing is that it makes an isosceles triangle with the diagonal measurements. So the trigonometry should be easy to do. But tomorrow, because it's a bit late here.
                                    OwenDundefined 1 Reply Last reply Reply Quote 1
                                    • OwenDundefined
                                      OwenD @droftarts
                                      @droftarts
                                      I just realised I made a mistake in my calculations.
                                      It only affected the calculation of the expected length of the diagonals and the area.
                                      I was using the area of the square and not the rhombus.
                                      If I use these dimensions with the RRF method and with my macro the results are essentially the same..
                                      RRF Method
                                      My macro
                                      • oliofundefined
                                        oliof @droftarts
                                        @droftarts I just meant to use the feature that allows you to give macros an unused gcode name and then calling that, without changes to the firmware (-;
                                        droftartsundefined 1 Reply Last reply Reply Quote -1
                                          @oliof ah, yes, that could work too, once we decide on the correct calculations! I’ve been composing a longer reply for those for the last couple of days!
                                            I spent a bit of time looking at this, and have come to the conclusion that doing it the Marlin way is ... fine. A rhombus is a parallelogram with some extra constraints. If we knew that the shape created by misaligned axes was always going to be a rhombus, only the diagonals would need measuring, and everything else could be worked out from that. Using the Marlin formulae, it covers parallelograms AND rhombuses, though you need to provide the extra AD measurement. Realistically, I'd guess that diagonals can only be measured to an accuracy of perhaps 0.25mm (depending on accuracy of print/bulges/measuring device), so it's never going to be perfect, but certainly good enough.
                                            And just because I wanted to know, I looked up what the two formulae Marlin uses are.
                                            Compute AB : SQRT(2ACAC+2BDBD-4ADAD)/2
                                            This is the parallelogram (and so also works for rhombi) formula to calculate the length of a side from the diagonals and the other side, see https://onlinemschool.com/math/formula/parallelogram/#h3
                                            This can also be written as SQRT((AC*AC+BD*BD-AD*AD)/2)
                                            XY_SKEW_FACTOR : TAN(PI/2-ACOS((ACAC-ABAB-ADAD)/(2AB*AD)))
                                            ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)) This part is the 'Law of cosines' https://en.wikipedia.org/wiki/Law_of_cosines, and calculates the angle in radians at A given AB, AC and AD. See also https://www.calculatorsoup.com/calculators/geometry-plane/parallelogram.php
                                            TAN(PI/2-A) gives the angle at A, ie between AE (the vertical point above A) and AB, and then using tan gives the skew factor.
                                            @OwenD I had a look at your macro, and it works fine for me... in 3.5b1, because of the use of M291 S4 and S6! I also saw that you calculated some of the rhombus values, like area and the second diagonal from the first diagonal and AD, but then these weren't used in the calculations, I think?
                                            @oliof Here's a generalised skew calculator macro. It also calculates the skew in mm, like the physical RRF method would measure, as a sense check. I'll do a M556.1 version when everyone agrees this is the best method, and I have some time!
                                            ; skew_calculator.g
                                            ; Bed Skew Compensation
                                            ; This feature corrects for misalignment in the XYZ axes.
                                            ; Take the following steps to get the bed skew in the XY plane:
                                            ; 1. Print a test square, e.g. https://www.thingiverse.com/thing:2563185 or https://www.thingiverse.com/thing:2972743
                                            ; 2. Mark the test point corners A,B,C,D as per the diagram below, if not already on the print
                                            ;    Y
                                            ;    ^  E--B-------C
                                            ;    |  A-------D
                                            ;    +-------------->X
                                            ; 3. Measure the diagonal A to C
                                            ; 4. Measure the diagonal B to D
                                            ; 5. Measure the edge A to D
                                            ; 6. Fill in the relevant measurements into the variables below, save and run the macro to show the result
                                            ; 7. If desired, follow the same procedure for XZ and YZ.
                                            ; Skew factors are computed automatically from these formulae, which may also be computed and set manually:
                                            ; Compute AB     : SQRT(2*AC*AC+2*BD*BD-4*AD*AD)/2
                                            ; XY_SKEW_FACTOR : TAN(PI/2-ACOS((AC*AC-AB*AB-AD*AD)/(2*AB*AD)))
                                            var A_C = 320.15611
                                            var B_D = 250
                                            var A_D = 200
                                            echo "Inputs: AC = " ^ var.A_C ^ ", BD = " ^ var.B_D ^ ", AD = " ^ var.A_D
                                            var A_B = sqrt(2 * var.A_C * var.A_C + 2 * var.B_D * var.B_D - 4 * var.A_D * var.A_D)/2 ; if rhombus, A_B = A_D
                                            var A_angle = acos((var.A_C * var.A_C - var.A_B * var.A_B - var.A_D * var.A_D)/(2 * var.A_B * var.A_D))
                                            var xySkew = tan(pi/2-var.A_angle) ; skew
                                            var A_E = var.A_B * sin(var.A_angle)
                                            var E_B = sqrt(var.A_B * var.A_B - var.A_E * var.A_E)
                                            echo "AB = " ^ var.A_B ^ ", XY skew = " ^ var.xySkew ^ ", Skew @ " ^ var.A_E ^ "mm = " ^ var.E_B ^ "mm"
                                            Output:
                                            M98 P"0:/macros/skew_calculator.g"
                                            Inputs: AC = 320.1561, BD = 250, AD = 200
                                            AB = 206.1552, XY skew = 0.2499996, Skew @ 200.0000mm = 49.99992mm
                                            dc42undefined OwenDundefined 2 Replies Last reply Reply Quote 3
