filament config for pellet extruder
is the filament config for the pellet extruder different? in what part? thanks
Can you be more detailed in what you're asking?
@Phaedrux in duet web control, we must add filaments config right? which contains config, load, and unload.
then, if I use a pellet extruder instead of filament, will the contents of the config be different from 3d printers in general -
The filament control is entirely optional. It allows you to set up some macros to help automate a load/unload process or to have specific settings for different materials/processes. That can be whatever you need it to be, but it is optional.
