Retrofit Hardware
@Lexan yes, the 6XD can.
In the duet 3 family it's pretty much yet the 6XD or 1XD boards for each motor with an external driver -
@jay_s_uk okay this fix the problem that i didnt seen comming, but wont answer my problem i see comming
can i control the 25 kg servo via the 1lc toolboard ?
and if yes, wich port can i use? -
@Lexan do you have a part number for it?
@jay_s_uk said in Retrofit Hardware:
i will check that out tmrw, just play with the idea to use a 3hc board instead the 2x 1lc
@Lexan should be a DSSERVO DS3225
@Lexan said in Retrofit Hardware:
DSSERVO DS3225
I would say not. seems like it can pull up to 1.9A which is too much for a toolboard
@Lexan any recommends how to controll this one instead ?
i think ~2A will be also too much for the 6hc -
@Lexan it may well be. Best to just use a step down converter.
The control can still be from the toolboard or 6HC. -
@Lexan okay but then the control could also be from a toolboard, right ?
the way to the hotend is about 4 meters, so i would like to take the cables as short as possible -
@Lexan yes to controlling from the toolboard. you'd either have to run a separate 5v cable or mount a stepdown converter on the toolhead
