Solved Revo 6 PID tuning just hangs
@wingtip said in Revo 6 PID tuning just hangs:
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.3 (2022-10-05)
Duet WiFi Server Version: 1.25
Duet Web Control 3.2.2How did you update the firmware? You've got the latest firmware version, almost, but the rest hasn't been updated. That can cause some weird behaviour.
I suggest you upload this single zip file to the system tab in DWC. That should get you updated all around.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.4/Duet2and3Firmware-3.4.4.zip
@Phaedrux i have no clue im an idiot lol... but if what you say is true then that explains why i lost the ability to see the mesh level height map in the dwc.. I will upload that file momentarily...
the reason why i had the c parameter in there is everytime i try to youtube search issues , the majority of videos are all centered around marlin but i thought the duet documents pages said same thing but obviously i was mistaken... -
@wingtip
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.4 (2022-10-20)
Duet WiFi Server Version: 1.27
Duet Web Control 3.4.4
still not heating up. going to see of the height map is working again real quick. EDIT: ummm did they do away with the heightmap visual in recent updates? Again until a few days ago i was on a much older version. -
@wingtip
Ok, im at a loss here. Since i do have 12 volts at the heater (so it must be starting to heat up) but the duet stops the tuning within a minute or so and says the temp isnt rising, i could only assume i had a break or intermittent connection from the thermistor to the main board. I verified all the thermistor wires were showing continuity through all break out boards and cable chains and to the mainboard. Still wont heat up and im just at a loss as to why it wont just heat up...According to the revo documentation here https://e3d-online.zendesk.com/hc/en-us/articles/4409926923665-Revo-Six-RepRap-Firmware-Guide I did make a slight change to the line
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 .
My config had C7.06e-8
I then re tried the m303 but with h1 instead of t0 and i got this... not sure if the info in the image will help diagnose anything. Im not even sure if that data is old data or from the 3 hour attempt at tuning earlier today...
According to the image you posted, you sent M301 H1, not M303 H1.
If the heater isn't heating, then it could be a wiring issue. Check the voltage at the connector. Alternatively or are you sure that you've got the 12 V version? If you have the 24V version but are only supplying it with 12V, that would also fail to heat up.
@wingtip good catch on the 301 vs the 303.. fat finger mistake i guess. however, as i stated before i verified i had 12 volts at heating element and verified all the connections from the thermistor back to the main board. I will retry the 303 again soon as i finish my breakfast lol...
Yes, it is the 12vt version of the revo.EDIT: tried again with the 303 and still cancels tuning with message temp not increasing. Sigh
It's a plugin now. You can enable it from the plugins tab.
https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#plugins
Can you post your full config.g?
Also please send M122 and M98 P"config.g" in the gcode console tab and copy and paste the results here. -
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6K-9GU4G
Used output buffers: 1 of 26 (23 max)
Static ram: 23860
Dynamic ram: 75584 of which 12 recycled
Never used RAM 12624, free system stack 176 words
Tasks: NETWORK(notifyWait,13.3%,242) HEAT(notifyWait,0.0%,223) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,86.7%,438) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes:
Last reset 00:59:59 ago, cause: power up
Last software reset at 2022-10-23 03:36, reason: User, GCodes spinning, available RAM 12480, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 22.2, current 23.3, max 28.2
Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7: standstill, SG min n/a
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2022-10-23 12:59:31
Slowest loop: 32.55ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.1ms, write time 139.2ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== DueX ===
Read count 1, 0.02 reads/min
=== Network ===
Slowest loop: 331.60ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.27
WiFi MAC address bc:dd:c2:89:a2:58
WiFi Vcc 3.42, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25232
WiFi IP address 192.168.1.7
WiFi signal strength -48dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
m98
Error: M98: No P or R parameter -
; config.g
; executed by the firmware on start-up; general preferences
M550 P"The Big One" ; set printer name; communications
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
M575 P1 S1 B57600 ; enable support for PanelDue; drives
M569 P0 S0 ; physical drive 0 goes reverse
M569 P1 S0 ; physical drive 1 goes reverse
M569 P3 S0 ; physical drive 3 goes reverse
M569 P4 S1 ; physical drive 4 goes forwards
M569 P5 S0 ; physical drive 5 goes reverseM584 X0:3 Y1 Z2:5 E4 ; set drive mapping
M92 X391.113 Y78.812 Z392.117 E397.022 ; set steps per mm
M203 X4000 Y4000 Z800 E6000 ; set maximum speeds (mm/min)
M566 X300 Y300 Z180 E3000 P1 ; set maximum instantaneous speed changes (mm/min)
M201 X700 Y700 Z200 E3000 ; set accelerations (mm/s^2)
M906 X1400 Y1000 Z700 E1000 I30 ; set motor currents (mA) and motor idle factor in per centM84 S30 ; set idle timeout
; axis limits
M208 X0:655 Y0:440 Z0:400 ; set axes min/max
; endstops
M574 X1 S1 P"!xstop+!e0stop" ; configure active-high endstops for low end on X
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y; Z probe
M98 P"probe_config.g" ; configure Z probe by invoking gcode file
; bed heater
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 R0.257 C549.0 D2.37 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S120 ; set temperature limit for heater 0; tool heater
M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; define E1 temperature sensor (old v6 value C7.06e-8)
M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 R1.350 K0.427:0.039 D6.10 E1.35 S1.00 B0 V11.6 ; disable bang-bang mode for heater and set PWM limit, (pidm303t0s236 not t1)
M143 H1 S280 ; set temperature limit for heater 1; part cooling fan
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; tool cooling fan
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; tool 0
G10 P0 X0 Y0 Z0 ; set tool axis offsets
G10 P0 R0 S0 ; set tool active and standby temperatures
T0 ; set tool active -
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
And you're sure the heater is connected to e1heat?
I will re verify, however, nothing has changed as this config g had been working just fine. it just sat for close to a year since i last printed and all i changed was updating the firmware and replace the v6 with a revo 6. it was almost just plug and play. i only had to install a xt 30 connector to the heater cable and it does show continuity through the coil at that connector. its when i went to try to pid tune that things just decided to causing grief...
Does the LED near the heater output light up when you turn on the heater to a set temp?
We could also switch to another heater output incase it's the heater mosfet that has failed. If it still doesn't work that would mean it's either the heater itself or the cable in between.
Does the temp displayed increase if you warm it up with your hands or a heat gun?
@Phaedrux said in Revo 6 PID tuning just hangs:
Yes, it is connected to E1 on the board
yes the led lights up.
let me find my heat gun
