Issues with pressure advance since RRF 3.4
@argo I've been messing around with it for the last week. I had it set at 0.055 previously. I have noticed zero change to PA when updated in config.g However I was tinkering earlier and when I change PA live using paneldue whilst printing it does have an effect. I got the corners not perfect but not too bad, updated config.g with new PA value. Ran the print again and back to c**p corners again. It's almost like PA value in config.g is being ignored.
@r4ffers Make sure your slicer start gcode doesn't disable PA. Check every .g file on your SD card, too.
@bot thanks, I've just updated that. I'll try another print in a mo.
@bot ok good shout
@bot said in Issues with pressure advance since RRF 3.4:
Can't see anything tha'ts disabling PA.
if I issue M572 D0 whilst printing I get PA0.095 -
@argo said in Issues with pressure advance since RRF 3.4:
PA 0.095 is quite high for direct drive setup.
Do you also get incomplete infill lines if you increase PA further to get less bulging corners?Doesn't seem to be
@r4ffers Did you try this print with different E j**k/accel?
@bot yep. Made no change to the corners.
So if you enter your PA value manually during a print - how do your corners then look?
@argo I'll try a print tonight, I'm on call this week.
@argo Hi, so started the print off issued M572 D0 to report current PA of 0.095. M572 D0 S0 to clear PA then issued M572 D0 S0.085. Issued M572 D0 to report current PA of 0.085. Here is the result.
Corners look miles better. I did notice the infill not quite reaching the internal perimeter in places.
Also note the walls on the square top layer, PA is working when manually input during print and as expected with such a high value for direct extruder.Hope this helps.
I’ll do the same test when I’m back from my business trip on Friday.
Though PA is reporting the correct value you set it to 0 and again to the value it was before and it works?
@argo I set it to zero 1st just to make sure it reported the change. In my config I had it set at 0.095 but I manually set it to 0.085. I'm fairly sure I used to have it set at 0.055, if I get chance tonight I'll try it at that and see what happens. I've looked through everything and can't find anything that would disable PA .
It'll be interesting to see if your PA works manually.
@r4ffers said in Issues with pressure advance since RRF 3.4:
It seems like a better test might be to start the print, verify the supposed PA setting via console, let it print for some amount of time. Then, re-command the same PA value and see if the print changes.
@ccs86 I've proved that already.
I also did the test you described but the corners are still bulging at PA 0.052 for PLA.
Seeing this thread, I really wish I had spent time making that band-aid test print use a bit less plastic...
I’ve looked at your print again and spotted holes in your infill lines. That’s usually due too much pressure advance. You are using your LGX lite in a direct drive setup? Then for PLA a value around 0.05 and 0.06 is usually the best value. For ABS it’s even lower.
I’m curious how your infill looks like. I’m also getting nice(er) corners with a much too high PA value (you are at 0.09?) but then also get holes in perimeters / solid fill and infill lines don’t connect anymore - what is to be expected with too high PA.@Wulfsta
Didn’t know you are registered here. Would have mentioned that the test print was from you. -
After synchronizing with @Argo what already has been tested and what not I wanted to rule out that the problem is caused by the 1LC toolboard.
Top: E stepper comnnected to a Duet3 3HC
Bottom: E stepper connected to 1LCSo at least we are now sure that it is not related to the 1LC.
My setup:
Same printer as @Argo
Duet3 6HC with 1LC and SBC running RRF 3.4.3
LGX extruder with Rapido HF hotend.config.g
; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M669 K1 ; Select CoreXY mode M564 S1 H1 ; Forbid axis movements when not homed G4 S1 ; wait for expansion boards to start ; Drives ; --- Z Drive map --- ; _______ ; | 3 | 4 | ; | ----- | ; | 2 | 5 | ; ------- ; front ; ; Drive directions M569 P0 S1 ; A (X) M569 P1 S1 ; B (Y) M569 P2 S1 ; Z1 M569 P3 S0 ; Z2 M569 P4 S1 ; Z3 M569 P5 S0 ; Z4 M569 P121.0 S1 ; E ; Motor mapping and steps per mm M584 X1 Y0 Z2:3:4:5 E121.0 M350 X16 Y16 Z16 E16 I1 ; Use 1/16 microstepping with interpolation everywhere M92 X80 Y80 Z400 E414.92683 ; Drive currents M906 X1500 Y1500 Z1500 E650 ; XYZ and E current M906 I30 ; Idle current percentage M84 S300 ; Idle timeout ; Accelerations and speed ;M566 X600 Y600 Z60 E8000 ; Set maximum instantaneous speed changes (mm/min) M566 X400 Y400 Z60 E8000 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z3000 E15000 ; Set maximum speeds (mm/min) M201 X10000 Y10000 Z250 E1800 ; Set maximum accelerations (mm/s^2) M204 P4000 T5000 ; Accelerometer ;M955 P121.0 I05 ; set address and orientation of tool board ; PA, DAA ;M572 D0 S0.05 M572 D0 S0.035 M593 P"zvdd" F35.2 ; Axis travel limits M208 X5 Y-5 Z0 S1 ; Set axis minima M208 X350 Y350 Z375 S0 ; Set axis maxima ; Endstops M574 X2 S1 P"^io1.in" ; Xmax endstop M574 Y2 S1 P"^io2.in" ; Ymax endstop ;M574 Z1 S1 P"^io3.in" ; Z endstop switch M574 Z1 P"nil" ; No endstop ; Z probes ;M558 K0 P8 C"121.io0.in" I1 H2.5 F250 T18000 A31 S0.0035 R0.2 ; set Z probe type to switch and the dive height + speeds ;G31 K0 P500 X0 Y25 Z8.74 ;M558 K1 P8 C"io3.in" I1 H2 F240 T18000 A31 S0.0035 R0.2 ; set Z probe type to switch and the dive height + speeds ;G31 K1 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height -0.8 ; Filament Sensor ;M591 D0 P7 C"121.io2.in" S1 ; Bed leveling M671 X-53:-53:400:400 Y-5:420:420:-5 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) ;M557 X20:335 Y20:330 P5:5 M557 X120:235 Y120:230 P2:2 ; Bed heater M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor M950 H0 C"out1" T0 ; create bed heater output M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater ; Hotend heater ;M308 S1 P"121.temp1" Y"pt1000" M308 S1 P"121.temp1" A"Heater 1" Y"thermistor" T100000 B4725 C7.06e-8 M950 H1 C"121.out0" T1 ;M950 H1 C"out2" T1 M307 H1 B0 S1 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; Set temperature limit for heater ; Chamber Thermistor M308 S2 P"temp1" A"Chamber" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor ; MCU sensors M308 S3 Y"mcu-temp" A"MCU" M308 S4 Y"drivers" A"Drivers" M912 P0 S-13 ; MCU temp calibration ; Fans ;M950 F0 C"121.out1" Q10000 ; part cooling fan # old Sunon M950 F0 C"121.out1" ; part cooling fan # new Gsdtime M106 P0 C"Bed" S0 H-1 ; part cooling fan M950 F1 C"121.out2" ; hotend fan M106 P1 C"Hotend" L0.70 X0.70 H1 T70 S0.70 ; hotend fan M950 F2 C"out7" Q10 ; air filter fan M106 P2 C"Filter" S0 H-1 B0.2 ; air filter fan M950 F3 C"out4" Q24000 ; electronics bay left side M106 P3 S0.75 H-1 B1 C"Bay" ; electronics bay left side ;M950 F4 C"1.out3" Q24000 ; electronics bay right side ;M106 P4 S0.75 H-1 B1 C"Bay Right" ; electronics bay right side M950 F5 C"out5" ; sbc fan M106 P5 S0.2 H-1 C"SBC" ; sbc fan M950 F6 C"out6" ; chamber light M106 P6 S1 H-1 C"Light" ; chamber light ; Tools M563 P0 S"Hotend" D0 H1 F0 ; define tool 0 ;G10 P0 X0 Y0 Z-2.75 G10 P0 X0 Y0 Z0 G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Enable debugging via USB ;M111 S1 P0 ; Platform ;M111 S1 P1 ; Network ;M111 S1 P2 ; Webserver ;M111 S1 P3 ; GCodes ;M111 S1 P4 ; Move ;M111 S1 P5 ; Heat ;M111 S1 P6 ; DAA ;M111 S1 P7 ; Roland ;M111 S1 P8 ; Scanner ;M111 S1 P9 ; PrintMonitor ;M111 S1 P10 ; Storage ;M111 S1 P11 ; PortControl ;M111 S1 P12 ; DuetExpansion ;M111 S1 P13 ; FilamentSensor ;M111 S1 P14 ; Wifi ;M111 S1 P15 ; Display ;M111 S1 P16 ; LinuxInterface ;M111 S1 P17 ; CAN ; Neopixel M150 X3 Q3000000 ; set LED type to NeoPixel and set SPI frequency to 3MHz M150 W255 P255 Y255 S3 F0 ; Misc M575 P1 S1 B115200 ; enable support for PanelDue M501 ; load config-override.g M302 P0 ; disallow cold extrudes T0 ; select tool 0 ; Auto Z M98 P"/macros/autoz/edit_me.g" ; load your settings for autoz with klicky probe M400 M98 P"/macros/autoz/scripts/autoz_globals.g" ; load autoz framework for klicky probe M400 ; ERCF ;M98 P"0:/macros/sys/ercf/lib/init.g"
Looks like I’m not alone with the issue anymore. Any news of an possible fix? And if possible, can we somehow assist in collecting more data (debug firmware with more logging?) for you to fix the issue?
