Pressure advance tuning with conditional G-code
@medicusdkfz said in Pressure advance tuning with conditional G-code:
thank you for your incredible job... Could you tell me, what the latest version is?
TY, Pierre
Thanks Pierre! And yes, the macro in the first post is still the latest version. I'm planning to provide an update with minor changes this week, including the ones from @CNCModeller, but probably nothing drastic. If you have any ideas for improvement, let me know.
@cncmodeller said in Pressure advance tuning with conditional G-code:
This seems to be working a treat on my machine. Thanks very much for the effort!
You're welcome, I'm happy that you got it working
- Add a var to control if the file was simulated or not in a single location. I then put an if before the relevant GCode statements w.r.t. setting and un setting simulation mode.
I've since learned that M37 also supports simulating a macro based on meta commands, and that doesn't require changing the code itself, so that might even be a more robust option for a less confident user?
On the other hand, your approach 1) puts the code itself in "debugging mode" which is persistent and developer-friendly and 2) doesn't add the "time taken" at the bottom of the macro file.
Disable Bed heating if the temperature is set to 0 as I don't have a working heated bed yet.
That's an excellent point, I hadn't considered printers without a heated bed. If you don't mind, I would like to incorporate your optimizations.
Just thinking a similar approach to retraction / de-retraction distances might be a nice project too, albeit I'm going to have to learn a lot about conditional GCode to figure that out!!
The reason why I found the pressure advance tuning such a good first use case, is because I couldn't convince my slicer to print a contiguous perimeter/wall with different speeds. At least in PrusaSlicer, the modifiers insisted on splitting the model in separate parts.
However, I was also a bit proud and hand-crafted all G-code and calculations myself, with secondary features like the brim taking a disproportional amount of time. So I wouldn't necessarily recommend doing that.
I'm currently tackling retraction tuning with PrusaSlicer entirely. I simply add two cylinder shapes some distance apart, and enter a height-based formula in the "Before layer change G-code" text box in PrusaSlicer that determines the retraction value.
Theoretically, such a test model would not be difficult to convert to a macro. However, I'm dearly missing the concept of a 'function' in the meta command instruction set, which would make it easier to create and maintain such code. Therefore, I think the quickest road to success is to further resist the urge to DIY things like infill and circular perimeters and start by parameterizing the G-code of a pre-sliced model.
Do you have any favorite models to tune retraction?
Anyway thanks again, this is great
@schmart feel free to use anything I've contributed.
I'm only just getting to the point of wanting to dial in my printer by science rather than guessing / witchcraft. Print quality and speed has only just got good enough to warrant the effort.
I believe Teaching Tech's calibration website is a pretty good resource. But I used your code before venturing over there.
Personally I was thinking the same way as you, two decent diameter thin wall towers and judge stringing and wall gaps on un-retract when starting a layer on each tower.
Definitely something I need to get to grips with!
Thanks again
All the best.
Barry M -
PS: w.r.t functions, I think it's possible to call other gcode files as subroutines and I even think you can pass in variables in recent beta firmware but not sure about returning results. More reading required lol.
@cncmodeller, @Schmart you would need to use a global variable, set in the sub macro, to pass information back to the main calling macro.
@t3p3tony said in Pressure advance tuning with conditional G-code:
Hi Tony, I had already done some testing with moving subroutine code in separate macros. On the surface, it seems that, between the Neanderthal approach of copying and pasting code, and re-using logic through parameterized macros, the balance tips towards the latter. However, I came across some conceptual and technical downsides that made me decide otherwise:
- Abstraction. I consider the macro as a vehicle for an end-user, not a developer; a cohesive unit of code that an end user would want to run. The macro is the 'public interface' to the functionality provided. A 'submacro' should not be able to have a public interface since it doesn't provide a useful experience by itself.
- Coupling and reliability. Subroutines exist to improve the maintainability of code and are not intended for an end-user to touch or run. If a unit of code is spread across multiple macros, it's easy for the end user to break functionality (e.g. remove a macro) or never get the functionality to run (e.g. not naming macros correctly). The absolute locations and names of macros are suddenly important and tightly coupled to the whole solution.
- Deployment and versioning. Depending on the complexity of the test print I want to generate, there could be many submacros involved, for things like circles, infill, fonts, etc. Splitting a solution in (potentially) many different macros complicates the setup, handling and publishing of code and updates. This becomes even more challenging when the same submacro is used by multiple main macros and the submacro needs an update that maintains backward compatibility.
- Testability. When using submacros, I have even less troubleshooting options and I can't isolate problems in my code properly. The only surefire way to test a multi-macro solution is to actually execute it with
M98
and send it to the printer. The developer experience is therefore not optimal:- If I call the main macro with
M37 P"parent"
, theM98 P"child"
within the main macro (with the purpose of calling the submacro) is not executed. Submacros are only called when I execute the main macro withM98
. - If I send an
M37 S1
command in the DWC console, this causes anyecho
statement to be suppressed, leaving me fully in the dark. UsingM37 S1
in the main macro is an option, but then submacros are still not called. - Isolated testing of a 'submacro' is not possible since
M37
doesn't accept parameters. Wrapping that submacro with another macro is of no use because of point #1.
- Scope. Traditionally, variables in a parent's scope are available to a subroutine, function, a C++ preprocessor directive or a code fragment that's simply #included from another file. However, variables in a parent macro cannot be shared with a child macro, and that makes sense in terms of separation of concerns. Ways to solve this:
- Making all or only the necessary variables global is an option, though, to avoid naming clashes, these should be namespaced properly. However, I consider this a workaround. I believe the concept of global variables is more suited to defining a small number of shared and relatively static or read-only printer settings. Global variables don't really seem intended for inter-scope communication where there are a lot of global variables in use and where they continually change.
- Using parameterized macros is also an option. However, because of parameter naming requirements, the number of variables that can be passed to a macro is limited. You can use single letters only, and three or four letters are already reserved (G, M, N and T). Additionally, this requires me to convert back and forth between highly recognizable local variable names and obscure macro parameter names, and keep the mapping between these logical.
- Performance. I haven't yet determined if the speed with which macros can be called would be an issue, so whether e.g. caching of called macros is implemented. For sections of a print that need to be executed quickly and frequently, this would be a requirement to prevent stuttering in the movement and blobs in the print. Accuracy and timing is pretty important in test prints, so that's something I need to avoid.
All in all, I've settled on putting the code as one big chunk in a single macro for now, and my hopes for the future are that some of the remarks above can be addressed!
I've included the test code. I had to slightly clean up the code to include it in this post.
Hopefully that provides some additional clarification to the above epistle (TLDR anyone?
_Parent code
Run this with
M37 P"0:/macros/_Parent"
. Note how messages from the child macro are not included. Running this withM98 P"0:/macros/_Parent"
does call the child macro, butalso actually tries to print this. Wrapping the parent code between
M37 S1
andM37 S0
commands and running it withM98
also ignores the call to the child macro. At least on my RepRapFirmware 3.4.0 beta 6.echo "Parent started" while {iterations < 10} echo "Calling child macro, iteration #" ^ {iterations} M98 P"0:/macros/_Child" X50 Y50 F2400 R6000 echo "Parent ended"
_Child code
Note that a standalone simulation with
M37 P"0:/macros/_Child" X100 Y100 F2400 R6000
does not work becauseM37
does not pass parameters, and causes unknown parameter errors.var size_x = {param.X} var size_y = {param.Y} var feedrate = {param.F} var travel_feedrate = {param.R} echo "Child started" ; Print single-perimeter rectangle G90 ; Use absolute coordinates G1 X{-var.size_x / 2} Y{-var.size_y / 2} F{var.travel_feedrate} G91 ; Use relative coordinates G1 X{var.size_x} F{var.feedrate} G1 Y{var.size_y} F{var.feedrate} G1 X{-var.size_x} F{var.feedrate} G1 Y{-var.size_y} F{var.feedrate} echo "Child ended"
Thanks! I took the liberty of integrating your suggestions.
I came across this site which seems to offer an interesting approach to retraction tuning as well. For now, I hacked together a more classical attempt to tune retraction settings . Please see attached file Retraction.g.
I tested this on my printer, but still, please consider this a beta release.
@schmart said in Pressure advance tuning with conditional G-code:
@Schmart That's brilliant and it works fine on my machine.
I have added restart length variation as follows so you can run it twice once with zero restart increment to identify optimum retraction, then a second time with a good retraction length start value and zero retraction increment and a restart increment to get the optimum restart length.
See code changes below.
; Retraction restart length to start with var retraction_restart_length_start = 0.0 ; Retraction restart length increment for each (whole) millimeter print height ; e.g. if var.height = 20, var.retraction_length_start = 0.0 and var.retraction_length_increment = 0.05, ; then the retraction test range is from 0.0 to (0.0 + 20 * 0.05) => 0.0 to 1.0. var retraction_restart_length_increment = 0.05
; Set firmware retraction M207 S{var.retraction_length_start} R{var.retraction_restart_length_start} F{60 * var.retraction_speed} T{60 * var.deretraction_speed} Z{var.retraction_z_lift}
; Set firmware retraction var retraction_length = {var.retraction_length_start + var.z * var.retraction_length_increment} var retraction_restart_length = {var.retraction_restart_length_start + var.z * var.retraction_restart_length_increment} M207 S{var.retraction_length} R{var.retraction_restart_length} F{60 * var.retraction_speed} T{60 * var.deretraction_speed} Z{var.retraction_z_lift}
; Output some statistics while printing echo "Layer " ^ {var.layer} ^ " (" ^ {var.layer + 1} ^ " of " ^ {var.layers} ^ " at " ^ {var.z} ^ "mm)" echo "Retraction length: " ^ {var.retraction_length} echo "Retraction Restart length: " ^ {var.retraction_restart_length}
From memory that's all I changed. I can post my full file but it has my customisations for print settings and location.
Many thanks again!!
Cheers
Barry M -
@cncmodeller could you post the full file?
undefined PCR referenced this topic
@pcr , sorry better late than never...
; This macro generates a test print to determine the best pressure advance factor (M572 S-parameter) ; It uses the test print described in this forum post: ; https://forum.duet3d.com/topic/6698/pressure-advance-calibration ; Author: Schmart ; WARNING: all dimensions, size units and speeds are in mm and mm/s ; Reference for conditional G-code: ; - https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands ; Wishes for conditional G-code: ; - Canceling or stopping running conditional G-code ; - Simulation; logging what commands would be executed/generated without actually executing them ; - Dumping the variables (names and values) in a macro, perhaps also treating variable in a meta-way, e.g. {#var} for count, {var[0].name} and {var['layer_height'].value} ; - Assigning an object or array to a variable. E.g. var axis = move.axes[0]; echo {var.axis.letter} ; - Custom subroutine/function definition, e.g. def print_line(var a, var b) ; - ceiling(), pow() and sq() functions ; TODO: ; - Many optimizations still remaining ; - Perhaps the most important variables (bed and print temperature, filament diameter, extrusion multiplier, PA stepping) ; can be made into macro parameters, e.g. M98 P"0:/macros/4 - Print Tuning/Pressure Advance" B40 P204 D1.75 X0.95 S0.02 P0.002 ;Log events var event_log = 1 ; Single location to activate simulation mode var sim_mode = 0 ; Starting value for pressure advance var pa_start = 0.6 ; Pressure advance increment for each (whole) millimeter print height ; e.g. if var.height = 20, var.pa_start = 0.1 and var.pa_stepping = 0.004, then ; the PA test range is from 0.1 to (0.1 + 20 * 0.004) => 0.1 to 0.18. var pa_stepping = 0.01 ; The extruder to apply the pressure advance factor to var pa_extruder = 0 ; These values specify the center of the print bed ; The default bed center is at (0,0) var x_center = 0 var y_center = 150 ; Print temperatures var print_temperature = 225 var standby_temperature = 200 var bed_temperature = 0 ; Height of the test print var height = 60 var layer_height = 0.40 ; Number of fast segments var fast_segments = 3 ; Slow segments are at the beginning and the end, and in between fast segments, e.g. SLOW FAST SLOW FAST SLOW var slow_segment_length = 10 var fast_segment_length = 20 ; Definition of speeds var first_layer_speed = 20 var travel_speed = 80 var fast_segment_speed = 60 var slow_segment_speed = 10 ; Number of perimeters around the object as a stable base var skirt_loops = 6 ; Height of the skirt in layers var skirt_layers = 2 ; The tool number to print with var tool_number = 0 ; Extrusion width is calculated here, but can also be set with a literal value ; Note that 1.05 and 1.125 are common factors that result in 0.42mm or 0.45mm width respectively var nozzle_bore_diameter = 0.60 var extrusion_width = {var.nozzle_bore_diameter * 1.125} var filament_diameter = 1.78 var extrusion_multiplier = 1.00 ; Firmware retraction settings var retract_length = 3.0 var retract_restart_length = 1.0 var retract_speed = 1200 var deretract_speed = 1200 var retract_z_lift = 0 ; Flow math var filament_flow = {pi * var.filament_diameter * var.filament_diameter / 4} var regular_flow = {(var.extrusion_width - var.layer_height) * var.layer_height + pi * var.layer_height * var.layer_height / 4} var bridge_flow = {pi * var.nozzle_bore_diameter * var.nozzle_bore_diameter / 4} var line_spacing = {var.extrusion_width - var.layer_height * (1 - pi / 4)} var regular_flow_ratio = { var.extrusion_multiplier * var.regular_flow / var.filament_flow} var purge_line_flow_ratio = { 2.0 * var.regular_flow_ratio } if {var.event_log > 0} M929 P"PA_log.txt" S1 ; start logging to file eventlog.txt echo "extrusion_width: " ^ var.extrusion_width echo "layer_height: " ^ var.layer_height echo "filament_flow: " ^ var.filament_flow echo "bridge_flow: " ^ var.bridge_flow echo "regular_flow: " ^ var.regular_flow echo "line_spacing: " ^ var.line_spacing echo "regular_flow_ratio: " ^ var.regular_flow_ratio if {var.sim_mode > 0} ;M37 S1 ; Enter simulation mode ; Set firmware retraction M207 S{var.retract_length} R{var.retract_restart_length} F{60 * var.retract_speed} T{60 * var.deretract_speed} Z{var.retract_z_lift} T{var.tool_number} ; Select tool M106 S0 ; Turn off part cooling fan M568 P{var.tool_number} S{var.print_temperature} R{var.standby_temperature} A1 ; Set tool to standby temperature if {var.bed_temperature > 0} M190 S{var.bed_temperature} ; Wait for bed temperature to reach setpoint M116 P{var.tool_number} ; Wait for temperatures associated with the selected tool to be reached ; Make an inventory of axes that have not yet been homed var axes = "" echo "Total number of axes: " ^ {#move.axes} while {iterations < #move.axes} if {!move.axes[iterations].homed} set var.axes = {var.axes ^ move.axes[iterations].letter} ; Home applicable axes echo "Axes to be homed: " ^ var.axes G28 {var.axes} ;G28 XYZ ; Home the X, Y and Z axes ;G28 XY ; Home the X and Y axes ;G28 Z ; Home the Z axis G21 ; Set units to millimeters M83 ; Use relative distances for extrusion ; Calculate object width var width = {var.fast_segments * var.fast_segment_length + (1 + var.fast_segments) * var.slow_segment_length} ; Calculate starting coordinates and other constant(s) var x_start = {var.x_center - 0.5 * var.width + var.skirt_loops * var.line_spacing} var y_start = {var.y_center - 0.5 * var.line_spacing + var.skirt_loops * var.line_spacing} var travel_feedrate = {60 * var.travel_speed} var first_layer_feedrate = {60 * var.first_layer_speed} ; Absolute position for purge line in X and Y space, 50 mm behind model G90 ; Use absolute coordinates G1 X{var.x_start} Y{var.y_start + 50} F{var.travel_feedrate} ; Set heater to final temperature and wait M568 A2 M116 P{var.tool_number} ; Absolute position of nozzle at first layer height G1 Z{var.layer_height} F{var.travel_feedrate} ; Relatively print two fat purge lines G91 ; Switch to relative coordinates G1 X{var.width} E{var.width * var.purge_line_flow_ratio} F{var.first_layer_feedrate} G1 Y{-(2 * var.line_spacing)} F{var.travel_feedrate} G1 X{-var.width} E{var.width * var.purge_line_flow_ratio} F{var.first_layer_feedrate} G10 ; Retract to prevent oozing ; Move to the start of the model in X, Y and Z space ; The skirt code also moves to the start, but the skirt can be disabled. ; Also, the skirt code does not set Z, and there may be no purge line for which Z is set. Safety first. G90 ; Use absolute coordinates G1 X{var.x_start} Y{var.y_start} Z{var.layer_height} F{var.travel_feedrate} G91 ; Switch to relative coordinates G11 ; Advance/unretract/deretract in preparation to print ; Routine for printing the test object var layers = {floor(var.height / var.layer_height)} echo "Total number of layers: " ^ var.layers while {iterations < var.layers} ; Track current layer var layer = {iterations + 1} ; Current height in mm var z = {var.layer * var.layer_height} ; Calculate pressure advance factor var pa = {var.pa_start + floor(var.z) * var.pa_stepping} ; Set pressure advance M572 D{var.pa_extruder} S{var.pa} ; Output some statistics while printing echo "Layer " ^ iterations ^ " (" ^ {iterations + 1} ^ " of " ^ {var.layers} ^ " at " ^ {var.z} ^ "mm)" echo "Pressure advance: " ^ {var.pa} ; Output Filament Sensor Reading M591 D0 ; Pre-calculate feedrates for first layer and other layers var slow_segment_feedrate = {60 * (var.layer == 1 ? var.first_layer_speed : var.slow_segment_speed)} var fast_segment_feedrate = {60 * (var.layer == 1 ? var.first_layer_speed : var.fast_segment_speed)} ; Print skirt if {iterations < var.skirt_layers} G90 ; Use absolute coordinates ; Move to absolute XY start coordinates G1 X{var.x_start} Y{var.y_start} F{var.travel_feedrate} G91 ; Switch to relative coordinates ; Print all loops of the skirt while {iterations < var.skirt_loops} var skirt_loop = {var.skirt_loops - iterations} var x = {var.width + 2 * var.skirt_loop * var.line_spacing} var y = {var.line_spacing + 2 * var.skirt_loop * var.line_spacing} ; Print one full skirt loop while iterations < 2 var direction = {iterations == 0 ? 1 : -1} G1 X{var.direction * var.x} E{var.x * var.regular_flow_ratio} F{var.fast_segment_feedrate} G1 Y{var.direction * var.y} E{var.y * var.regular_flow_ratio} F{var.fast_segment_feedrate} ; Travel to the start of the next skirt loop G1 X{var.line_spacing} Y{var.line_spacing} F{var.travel_feedrate} ; Print two perimeters back and forth of alternating slow and fast segments while iterations < 2 var direction = {iterations == 0 ? 1 : -1} ; Slow starting segment (X) G1 X{var.direction * var.slow_segment_length} E{var.slow_segment_length * var.regular_flow_ratio} F{var.slow_segment_feedrate} ; Remaining fast and slow segments (X) while iterations < var.fast_segments G1 X{var.direction * var.fast_segment_length} E{var.fast_segment_length * var.regular_flow_ratio} F{var.fast_segment_feedrate} G1 X{var.direction * var.slow_segment_length} E{var.slow_segment_length * var.regular_flow_ratio} F{var.slow_segment_feedrate} ; Print the side perimeter (Y) G1 Y{var.direction * var.line_spacing} E{var.line_spacing * var.regular_flow_ratio} F{var.slow_segment_feedrate} ; Move one layer up G1 Z{var.layer_height} F{var.travel_feedrate} G10 ; Retract G91 ; Relative positioning G1 F3000 Z20 ; Move gantry up 20mm G90 ; Absolute positioning G28 X ; Home X axis ;M104 S0 ; Turn off nozzle heat block M568 P{var.tool_number} S0 R0 A2 ; Set required heater temperature off if {var.bed_temperature > 0} M140 S0 ; Turn off bed M106 S0 ; Turn off part cooling fan M18 ; Disable stepper motors if {var.sim_mode > 0} M37 S0 ; Leave simulation mode if {var.event_log > 0} M929 S0 ; stop logging
