Solved Panel Duet Chamber Temp
Trying to set chamber temps via panel due, and they keep reverting to the existing setpoint when I hit set. I'm able to set the temp via DWC and gcode commands fine.
Anyone run into this?
Running panel due firmware 3.4.3
Can you send M122 in the DWC gcode console and copy paste the results?
Also please share your config.g thanks. -
@phaedrux
M122:9/22/2022, 7:58:17 AM m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956BA-NA3TN-6J9F6-3SD6N-TBBUT Used output buffers: 1 of 40 (21 max) === RTOS === Static ram: 151000 Dynamic ram: 96888 of which 140 recycled Never used RAM 102644, free system stack 200 words Tasks: NETWORK(ready,3452.9%,209) ETHERNET(notifyWait,23.3%,168) HEAT(notifyWait,12.7%,321) Move(notifyWait,1.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,4.7%,333) TMC(notifyWait,4276.5%,92) MAIN(running,2747.7%,925) IDLE(ready,0.1%,30), total 10518.9% Owned mutexes: === Platform === Last reset 15:56:16 ago, cause: reset button Last software reset at 2022-09-21 15:38, reason: User, GCodes spinning, available RAM 102644, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 136 MCU temperature: min 37.9, current 38.8, max 46.3 Supply voltage: min 23.7, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 4, reads 13782, writes 19 timeouts 0 Driver 1: standstill, SG min 0, mspos 4, reads 13782, writes 19 timeouts 0 Driver 2: standstill, SG min 0, mspos 4, reads 13785, writes 16 timeouts 0 Driver 3: standstill, SG min 0, mspos 4, reads 13785, writes 16 timeouts 0 Driver 4: standstill, SG min 0, mspos 4, reads 13785, writes 16 timeouts 0 Driver 5: standstill, SG min 0, mspos 4, reads 13787, writes 15 timeouts 0 Date/time: 2022-09-22 07:58:13 Slowest loop: 4.89ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 2 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.2 Heater 2 is on, I-accum = -0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === CAN === Messages queued 516376, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 286881/0/0 Tx timeouts 0,0,286880,0,0,229494 last cancelled message type 30 dest 127 === Network === Slowest loop: 11.61ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
Config:
; Configuration file for Duet3 (firmware version 4.0 or newer) ; executed by the firmware on start-up ; General preferences M111 S0 ; Debugging off M575 P1 B115200 S1 ; set baud rate for panel due G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves G4 S1 M118 P2 S"{""controlCommand"":""reset""}" ;reset display ;M669 K1 ; Select CoreXY mode M669 K1 X1:1:0:0:0:0 Y-1:+1:0:0:0:0 Z0:0:1:1:1:0 U0:0:0:0:0:1 ;Select CoreXY mode M564 S1 H1 ; Forbid axis movements when not homed ; Network M552 S0 ; Ethernet ON G4 S1 ; WAIT 1 SECOND M552 S1 ; ENABLE NETWORK AS CLIENT ; --- Z Drive map --- ; _______ ; | 2 | ; | ----- | ; | 1 | 3 | ; |_______| ; front ; ; (looking at the printer from the top) ; Drive directions M569 P0 S0 D3 H5 V25 ; A M915 P0 T5 R0 H336 M569 P1 S0 D3 H5 V25 ; B M915 P1 T5 R0 H336 M569 P2 S1 D3 ; Z1 M569 P3 S1 D3 ; Z2 M569 P4 S1 D3 ; Z3 M569 P5 S0; Extruder ; Motor mapping and steps per mm M584 X0 Y1 Z2:3:4 E5 M350 X16 Y16 Z16 E16 I1 ; Use 1/16 microstepping with interpolation everywhere M92 X80 Y80 Z1280 ; Set XYZ steps per mm (1.8deg motors) M92 E400 ;steps per mm LGX M350 X32 Y32 Z32 E32 ;Increase Z & E microstepping ; Drive currents M906 X1600 Y1600 Z1600 E700 ; XYZ and E current LGX M906 I15 ; Idle current percentage M84 S120 ; Idle timeout ;Acceleration and speeds M566 X250 Y250 Z100 E300 ; (jerk) Set maximum instantaneous speed changes (mm/min) was M203 X12500 Y12500 Z2000 E7000 ; Set maximum speeds (mm/min) M201 X7000 Y7000 Z1500 E2000 ; Set max accelerations (mm/s^2)' ; Endstops M574 X2 P"^!io3.in" S1 ; DEFINE X ENDSTOP M574 Y2 P"^!io4.in" S1 ; DEFINE Y ENDSTOP M574 Z0 P"nil" ; No Z endstop ; Axis travel limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X510 Y331 Z635 S0 ; Set axis maxima ; Bed leveling M671 X13:244:454 Y13.5:326.5:13.5 S20 ; Define Z belts locations (Front_Left, Back_Middle, Front_Right) M557 X35:450 Y20:270 P5:5 ; Define bed mesh grid (inductive probe, positions include the probe offset!) M376 H10 ; Fade mesh out compensation over 20mm Z ; Bed heater M308 S0 P"TEMP0" Y"thermistor" T100000 B3950 A"Bed Temp" ; configure sensor 0 as thermistor on pin bedtemp (heater sensor) M950 H0 C"OUT0" T0 Q10 ; create bed heater output on out0 and map it to sensor 0. Set PWM frequency to 10Hz M140 P0 H0 ; Mark heater H0 as bed heater (for DWC) M143 H0 S120 ;Set bed max M307 H0 B1 S1.0 ; Enable Bang Bang mode and set PWM to 100% ; Hotend heater M308 S1 P"TEMP3" Y"thermistor" T100000 B4267; define E0 temperature sensor M950 H1 C"OUT1" T1 ; heater 1 uses the e0_heat pin and sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S305 ; Set temperature limit for heater 1 ;Chamber Heater ;M308 S2 P"TEMP2" Y"thermistor" T10000 B3892 A"Chamber Temp" ; define chamber temp sensor M308 S2 P"TEMP2" Y"thermistor" A"Chamber Temp" T100000 B4725 C7.06e-8 ;R5000 M950 H2 C"OUT2" T2 ; create heater output on out2 and map it to sensor 2 (mic6 sensor). Set PWM frequency to 10Hz M141 P1 H2 ; Mark heater H2 as Chamber temp (for DWC) M143 H2 S75 ;Set chamber max M307 H2 B1 S1.0 D120 ; Enable Bang Bang mode and set PWM to 100% ; MCU sensors M308 S3 Y"mcu-temp" A"MCU" M308 S4 Y"drivers" A"Duet Drivers" ; Fans M950 F0 C"out5" Q250 ; Create fan 0 (hotend) M106 P0 C"Hotend_Fan" S0 H1 T40 ; Configure fan 0: Thermostatic control is turned on, based on sensor #1 M950 F1 C"out4" Q250 ; Create fan 1 (part cooling) M106 P1 C"Part_Fan" S0 H-1 ; Configure fan 1: Thermostatic control is turned off M950 F2 C"OUT7" Q250 ;CREATE FAN2 (ENCLOSURE FAN) M106 P2 C"Enclosure_Fan" H3:4 T40:70 ;CONFIGURE FAN THERMOSTATIC CONTROL IS ON BASED ON SENSOR 3 &4 M950 F3 C"OUT8" ;CREATE FAN2 (CHAMBER FAN) M106 P3 C"Chamber_Fan" B.25 X0.5 H2 T20 ;CONFIGURE FAN ; Z probes M558 K0 P8 C"!io5.in" T60000 F300 H5 S0.01 R0.2 G31 K0 P500 X-18 Y-34.5 Z0 ; Tools M563 P0 D0 H1 F1 ; Define tool 0 using fan 1 for M106 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;Filament Detect ;M950 J1 C"IO6.IN" ;Create pin1 M591 P1 D0 C"IO6.IN" S0 ;SET FILAMENT MONITOR EXTRUDER 0 ENDSTOP ;Pause M950 J2 C"!IO1.IN" ;Create pin2 M581 P2 T1 C0 S1 ;SD CARD M950 D1 C"spi.cs0" ;DEF1NE SD CARD READER M501 ; load config-override.g T0 ; select tool 0
@that-guy-e said in Panel Duet Chamber Temp:
Do you mean 3.4.1?
https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.1
Can you confirm on the setup page on the PanelDue?
Can you update to 3.4.2?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.2/Duet2and3Firmware-3.4.2.zip
You are correct, panel due firmware is 3.4.1. Sorry about that.
Updated controller firmware to 3.4.2 and still no luck.
Any chance the panel due is looking for a specific heater number to be referenced for the chamber heater?
@phaedrux With 3.4.2 not helping, any other thoughts?
Is there a preferred heater number to assign to the chamber from a panel due standpoint?
M141 P1 H2
I think you need to remove the P1. That sets it as chamber 1 instead of chamber 0.
I had to change P1 to P0. Looks like its working now.
If I left the P parameter out, the panel due creates two chamber heaters, 0 and 1. Not exactly sure why.
