Duet mini 5+ freezes and shuts off heaters
@phaedrux I was going to ask the same thing about static considering it's sitting on carpet. I have seen Duet 2 Wifi's lose their wifi connectivity due to this until they are restarted.
Just a small update. I switched from Nylon to PETG. 250C/83C hotend/bed temps. I didn't change anything but the print temperatures. I was able to make 6 small and large successful prints using both Cura 5 and MatterControl slicers. Prints were perfect.
Now, loaded Nylon back on, but kept the bed temp the same for testing. 281C/83C. I will test different parameters.
@michael-hathaway are Nylon and CF more prone to static buildup? Perhaps grounding the nozzle would help. Make sure the extruder motor is grounded, too. I still have no idea how itβs triggering a βmanual resetβ, unless a sudden zap is enough to drag the reset signal to ground.
The printer is grounded and there is no carpet, only concrete in workshop. If static were the culprit, it would not print at lower temperatures.
It was 45-46Β°C in my workshop last week and I think the higher printing temperatures over loaded the board. While it was triggering a reset, one time it also triggered an emergency stop on its own.
It is now 26Β°C in the shop and it is printing my lower temp Nylon fine. I will load the HTNCF next and see if fails or continues to print.
@michael-hathaway I asked @dc42 if he thought high ambient temperature causing the Duet MCU to overheat would trigger a reset that looks like a manual reset. He said "I think that's unlikely, but not impossible." Without knowing how hot the Duet board is getting (map the on-board MCU temp sensor to see a graph) that's difficult to know. An MCU reset or shutdown would be triggered somewhere above 85Β°C.
I know you said "the printer is grounded", but specifically are the metal parts of the hotend grounded? I still think a static shock is more likely, and grounding the hot end would eliminate this. You said you swapped out the PT1000 for a new one and got a different failure, so possibly static charge in the the hot end has arced through that and caused a reset. High ambient temperature + high temperature nozzle (this would lower humidity, making static worse) + possibly CF and Nylon that produce more static charge than PETG might be enough to reset the MCU.
However, @chrishamm thinks that a static shock to the temperature inputs may cause a MemoryProtectionFault reset (it does on the 6HC, not sure about the Mini 5+), which would show up in the M122 report.
One other question: How did the old Mini 5+ fail? Could it be related? Maybe the MCU got zapped?
@droftarts I ordered a ring terminal to fit the hot end for grounding, will be here tomorrow. It was extremely humid here and hot.
All the boards show the same failure. I have had trouble free performance for 1.5 years. I have had the mini board shut down before when the chamber temperature went over 50C. This is an unusual heat wave in California. If this keeps up, I think I will install air conditioning in the workshop.
The other Matterhacker guys prefer their Azteeg boards. But for me, I only use Duet.
Added electrical ground wire from the hotend to the frame and to electrical earth ground. Printer still failed prints.
Pulled printer from workshop into air conditioned building. Printer has produced several 10+ hour prints.
For fun, I added a copper heat sink to the MCU. Temperature now reading a -6.7Β°C drop. Probably not worth doing, but if a few degrees means the difference between another stall and not, then I am ok with it. I can now be part of the "stuck a heat sink on my MCU" fan club. lol
I think that I will make a new case cover that brings ambient air from outside the heat chamber to the Duet and then draw it back out again. Shouldn't be too difficult, I think two 60mm fans would work well.
I often see housings with the Duet mounted near the bottom, cooling them from above. In your case, Iβm not sure, but it is really essential to follow the explicit recommendations: cool the bottom of the board! Then, even a mediocre blower at low speed is sufficient.
@infiniteloop I am not sure I follow you here. Why would I want to cool the bottom of the board? Are you talking about the back side of the board?
Cooling the back side of the board is for the stepper drivers as well as a couple of other items. I had a rather large fan cooling the back side of the board at the start of this. Didn't help what so ever. No, what ever is tripping the reset of the board is either on the front side or the board in it's entirety.
My board enclosure is located inside the heated print chamber. Blowing hot air over an overheated board is not going to be the answer for me. Bringing in cool air to cool the board and then exhausting it so that it doesn't cool the print chamber is what is needed.
My warped sense of humor here
@michael-hathaway said in Duet mini 5+ freezes and shuts off heaters:
Sorry for my English: it's the back side what I mean.
My original case had a 92mm fan on the front side and it was designed to blow air on the front and force the air around to the back side to cool the steppers. Still its hot air circulating and I need to do this a little differently this time. I didn't really have problems until we had a few really hot days and I was printing high temperature plastics, which made the chamber even hotter, surpassing the limits of the system.
@michael-hathaway when you initially asked about this problem, there were a number of useful pieces of information that you werenβt forthcoming with: that the Duet (and PSU, I think) are mounted inside the heated chamber, the high ambient temperature at the time, printing high temperature materials. This lead to a focus on other factors that might cause the reset, rather than the obvious one; the board temperature.
What sort of temperature does the chamber get to? You are stressing the electronics on the board running it inside the enclosure. The MCU itself may be rated to 85C (operating temperature, not ambient temperature), but other components on the board may not be, and could be causing voltage fluctuations and the βphantomβ resets. I donβt think we publish a temperature range of operation for Duet boards (Iβll ask @dc42), but subjecting it to heat intentionally seems less than ideal. I think you have got away with it in past, but a combination of factors has pushed the board beyond its temperature limits. Is it possible to mount it outside the enclosure?
@droftarts I agree with you completely.
The boards are not faulty, I am just pushing them to their limits. It's not really intentional though, I have just gotten away with it until now.
I don't think it is the MCU causing the shutdown, but something else on the board. I have printed no less than 20,000 prints on my original Duet mini 5. IMO it's way better than the American or any other boards on the market.
It's just a Prusa aluminum clad enclosure, many people use these. I have never pushed the chamber over 60Β°C and I know it was over 50 when I was having problems with the MCU in the 67-70C range. It was 48Β°C here in the shade and my workshop was close to that temperature. Both the combined high ambient temperature and the increase current through the board to bring the hotend up to 330C is what I think caused the resets/emergency shutdown.
Will the Duet 6HC handle higher temperatures better than the mini 5+? Are the components on the board higher grade?
The printer went 5 layers and stopped. I have no idea why it is freezing.
Weβll maybe you shouldnβt (should) leave it out in the cold? Sorry, couldnβt resistβ¦
Iβm fully certified to use dad jokesβ¦
https://youtu.be/4CeWYM08s7A -
@tlas I don't wish to wire for external board. I am not the first person to print inside an enclosure. I just didn't know the thermal limits of this board until now. I will end up switching over to the 6HC as it seems to be more robust.
@michael-hathaway
Mostly a joke there (board freezingβ¦ leaving it out in the coldβ¦).I can understand why folks would want to keep the boards in heated chambers.
FYI, bringing in a line of compressed air at ~10 psi is helpful to provide local cooling without impacting the overall chamber too much.
@tlas I joked with a friend this morning when I told him I was going to water cool my MCU.
@michael-hathaway Unfortunately, I don't think it's just the MCU, and this issue isn't just limited to the Mini 5+. Other components aren't rated higher than 85C, and running at high temperatures will shorten the life of all the components. We don't give recommended operating temperature limits (though we are talking about it), because the board heating itself up due to FETs/stepper drivers/power supplies on the board is very application specific.
With the 6HC, the higher rating on the stepper drivers mean they run cooler, so don't add as much self-heating to the board, so perhaps that's what you mean when you say they are more robust.
We really don't advise running Duets in heated chambers; it will shorten their life.
@droftarts Yes, this is what I said in my previous statement to you. It is all the components on the board.
The chamber is heated by the bed and hotend. The reason why it prints petg and not the high temp nylon is because the chamber temp rises much higher with the higher temp plastics. Especially on very hot days. I realize now that I cannot print my higher temp plastics until I bring cold air in to cool the electronics.
