CustomHttpEndpoint script not working
@j-dewit one for @chrishamm then
@jay_s_uk Thanks, I am trying to figure out where DSF puts it's logs on the SBC. But so far no luck on debugging.
@j-dewit said in CustomHttpEndpoint script not working:
You can get logs using
sudo journalctl -xe -u duetcontrolserver
I used
CustomHttpEndPoint
using the dsf-python library without issue. Here is an example. -
@falcounet I will try that example perhaps I have more luck with that one. Are you running the same firmware or a newer version?
I did manage to get the faul that is occuring:
Sep 07 10:54:39 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[39] Connection id "0HMKGLC886QRH" accepted. Sep 07 10:54:39 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[1] Connection id "0HMKGLC886QRH" started. Sep 07 10:54:59 duet3 DuetWebServer[665]: DuetWebServer.Services.ModelObserver[0] New number of custom HTTP endpoints: 0 Sep 07 10:54:59 duet3 sudo[3741]: pam_unix(sudo:session): session closed for user root Sep 07 10:55:03 duet3 sudo[3813]: pi : TTY=pts/0 ; PWD=/opt/dsf/bin ; USER=root ; COMMAND=./CustomHttpEndpoint Sep 07 10:55:03 duet3 sudo[3813]: pam_unix(sudo:session): session opened for user root by pi(uid=0) Sep 07 10:55:04 duet3 DuetWebServer[665]: DuetWebServer.Services.ModelObserver[0] New number of custom HTTP endpoints: 1 Sep 07 10:55:04 duet3 DuetWebServer[665]: DuetWebServer.Services.ModelObserver[0] Registered HTTP GET endpoint via /machine/custom-http-endpoint/demo Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets[6] Connection id "0HMKGLC886QRH" received FIN. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[39] Connection id "0HMKGLC886QRI" accepted. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[1] Connection id "0HMKGLC886QRI" started. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[10] Connection id "0HMKGLC886QRH" disconnecting. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets[7] Connection id "0HMKGLC886QRH" sending FIN because: "The client closed the connection." Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://10.0.0.2/machine/custom-http-endpoint/demo - - Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.HostFiltering.HostFilteringMiddleware[2] All hosts are allowed. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Routing.Matching.DfaMatcher[1000] No candidates found for the request path '/machine/custom-http-endpoint/demo' Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Routing.EndpointRoutingMiddleware[2] Request did not match any endpoints Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[2] Connection id "0HMKGLC886QRH" stopped. Sep 07 10:55:49 duet3 DuetWebServer[665]: DuetWebServer.Authorization.SessionKeyAuthenticationHandler[8] AuthenticationScheme: SessionKey was successfully authenticated. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel[13] Connection id "0HMKGLC886QRG", Request id "0HMKGLC886QRG:00000005": An unhandled exception was thrown by the application. System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (13): Permission denied /run/dsf/custom-http-endpoint/demo-GET.sock at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) at DuetWebServer.Middleware.HttpEndpointConnection.Connect(String socketPath) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Middleware/HttpEndpointConnection.cs:line 31 at DuetWebServer.Middleware.CustomEndpointMiddleware.InvokeAsync(HttpContext context) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Middleware/CustomEndpointMiddleware.cs:line 97 at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context) at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application) Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Server.Kestrel.Connections[9] Connection id "0HMKGLC886QRG" completed keep alive response. Sep 07 10:55:49 duet3 DuetWebServer[665]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://10.0.0.2/machine/custom-http-endpoint/demo - - - 500 0 - 31.3982ms
So the first thing is strange since it is telling that no endpoint is matched. And then there is a permission error on the unix socket that is created.
Upping the permissions on the /run/dsf/custom-http-endpoint/demo-GET.sock solves the issue.
I am running the test scrips as root, perhaps it is better to use a different user? Or is there soms sort of permission mismatch during the installation?
@j-dewit Ideally the HTTP endpoint application should run as
dsf
user butpi
may work, too. It is possible to run it as root but then you need to adjust the permissions of the UNIX socket file so that thedsf
user/group can access it. -
@chrishamm That makes sense, just tested with the pi user, but that also is giving permission errors.
Perhaps it is a good idea to update the documentation how to properly run these testing scripts.
I tried running the script as a service with the dsf user. But now the DuetControlServer is dropping the connection due to missing permissions.
Sep 07 14:23:25 duet3 DuetControlServer[3666]: [error] IPC#67: Failed to find plugin permissions for pid #6017 Sep 07 14:23:25 duet3 DuetControlServer[3666]: [warn] IPC#67: Terminating connection due to insufficient permissions
I am running a stand-alone c# application on the pi and don't want to use the plugins 'yet' due to easy-er debugging. What is the best way to get these permissions working?
@j-dewit It may be AppArmor restricting access.
You may probably need ot set it in complain mode for debugging purposes or temporarily disable it (from the DSF config) to check if that's your issue. -
@falcounet there is no apparmor profile for DSF tools so I doubt it. But I'll check if I can make file permissions for HTTP endpoints simpler in the next DSF version.
@chrishamm I got the service working by running as root user using a umask 0000. That way the created socket is readable by dsf user.
There must be a better way to do this, but sadly I am not an expert on user management in linux.
But for development this works.
