Warning: Lost connection to Duet (SPI connection
@phaedrux
OK OK I understand better than tried I'm going to put ip directly on the config. But it's a shame that I can't use the rpi card, that's crazy. -
@sgk said in Warning: Lost connection to Duet (SPI connection:
There may be a problem with the cable or your board.
@phaedrux with the rpi
There may be a problem with the cable connecting the Duet to the RPI or your clone duet board.
@phaedrux yes ok i see there is a way to know? by changing the cable.
It doesn't work but I think I made a mistake somewhere
M552 S1 192.168.117 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet -
@phaedrux yes is my ip
An IP address must be a set of 4 numbers.
@phaedrux sorry i'm really stupid i didn't pay attention you're right
@sgk no it doesn't work it's not possible I'm going crazy
M552 S1 192.168.1.117 ; enable network and acquire dynamic address via DHCP
You need a P before the ip address.
M552 S1 P192.168.1.14
@phaedrux ok thank
you it works it works more than testing
even if i but a blank sheet i have this error
always this error -
@sgk
like jay said I have to change the probe that's the best thing I have to do -
@sgk
no more errors regarding this post thank you all for your help
