Mismatch between Cura filament estimate and actual filament used
Cura estimates my print will cost 1760g of filament. I have already spent an entire 1kg roll, and according to Duet web control the print is not even halfway done, in terms of filament usage (in mm). What gives? Why is my Cura estimate so far off from what the Duet is actually doing?
Firmware version?
Can you share the gcode file and your config? -
@phaedrux Firmware 3.4, Gcode file is too large to upload
@phaedrux this is my config file config(1).g
Can you share the gcode file via cloud storage?
