RGB LED wiring with Duet 2 wifi
Hello, I am new to duet 2 wifi and I need to connect RGB LED stripe (which has three terminal, 5V,GND and a signal terminal). I am aware of using pin 5 from CONN_LCD for signal but need a level shitfer for that. In that case what kind of level shifter is available on the market which is compatible with duet 2 wifi RRF3.3 ???
I want the LED color 'green' while turning my 3D printer on, 'blue' while printer starts printing and 'red' while printer stops printing. And I am using firmware RRF3.3 and I only need 5 LEDs on my printer.Other way is to connect the signal pin to one of the heater or fan pin as PWM signal but what would be the process of wiring? Do I still need level shifter for that?
Thank you ! -
undefined Phaedrux locked this topic
A single thread for your issue is sufficient.
