Heater Code setup question
No, heater 0 is just the first heater. It can be used for a hotend.
You may want to try bang-bang mode with this heater.
But where is the thermistor in relation to the rest of the heater? Can you show us photos of the setup?
@phaedrux
how would i activate bang bang mode?
here is picture:
i have both close to heating element. originally i had them directly on aluminum but i moved them closer since they werent reading any changes in temp
That's a very loose connection between the theristor and the heat source.
You've got two thermistors in there, which are you trying to use for control?
@phaedrux should i directly tape them to the heating element?
@phaedrux
how do i activate bang bang mode? -
@drak said in Heater Code setup question:
M307 H0 B0 S1.00
M307 H0 B1 S1.00
B1 would be bang bang mode. But it's still going to have to register a temp increase for it to not fault out.
Is this a temporary setup, or intended for actual use?
@phaedrux the goal is to use this heating element long term
In this configuration, or improved? At the moment, it's a bit "janky" as the kids say.
I wouldn't want to run a heater control with a thermistor attached with tape. When it falls off (and it will) at best you ruin a print.
@phaedrux this setup is just to workout the duet control side of the heating element and make sure i can heat up the aluminum consistantly
What temperatures do you aim at with this bold construction? From what I can see on your photo, most of the 50 watts dissipate into air, the rest tries to heat up the aluminum, the clamps and all the other metal connected by those.
Sure you can control that with the Duet - the question is: Can such a construct be covered by the PID tuning, or is the heat increase too slow for the algorithm? In the latter case, you will want to insert proper values for
M307
by guess. Here you can look up the details. -
undefined Drak referenced this topic
