Solved: Jogging past axis limits..?
I did that, @jay_s_uk, but then the endstops didn't activate, but I'll try (anything) again!
UPDATE: Now I get the G0/G1: target position outside machine limits when I try to move any axis. The proximity sensors do work, though!
@nightowl999 you'll need to do the same with your Z endstop too.
There's also no need to include M564 as S1 H1 are the default setup -
I'm in the process of doing that now, @jay_s_uk, but won't I still have the same problem?
@nightowl999 not if you're jogging to the -ve once homed
Blinkin' 'eck, @jay_s_uk, you've only gone and sorted it!
The only thing, and I might just have to get used to this, is that the machine home coordinates are back to the maxima values, rather than 0, 0, 0 I was hoping to achieve.
I don't care any more . It's not as if the machine co-ordinates really matter with a CNC, as the starting point of the work being cut is more important!
@nightowl999 exactly. Typically front left is 0,0. Ideally you want it there as otherwise whatever you're cutting is the opposite way it appears on screen.
Homing to max is perfectly fine.
If you did want to flip it the other way you'd have to change your M574s back, flip the move direction in M569 and rewrite your homing files to move towards the minima rather than the maxima -
Thanks, @jay_s_uk. I think it's time I started doing stuff, rather than messing about!
Talking of homing... Because I can't really reach the back of the machine when it's homed, I temporarily REM'd out the lines relating to the Y axes in the homeall.g file. But, it still homed the Y axes.
Does the Home All button on the dashboard run the homeall.g file, or the individual home files?
@nightowl999 homeall but if a certain axis isn't there, it then calls the homing file for that axis, unless they're hidden
Well, I don't know who had that foresight, @jay_s_uk, but that would explain the magical event
I really appreciate the help, thank you.
@nightowl999 said in Solved: Jogging past axis limits..?:
That will leave a bruise if your don't sort this out!
Did you follow the basic comissioning procedure that it outlined in the docs?
https://docs.duet3d.com/en/How_to_guides/Commissioning#h-7-check-endstops
Its really straight forward to to take it step by stepIf you do it 'half-way' then it WILL come back to haunt you someday. DAMHIKT!
@sinned6915 said in Solved: Jogging past axis limits..?:
Yeah, I followed those instructions closely, but it's in changing things to suit my situation that made it difficult (in my mind, anyway), and trying to keep track of incremental changes is a bit challenging.
I believe this is sorted now, so apart from one or two other capabilities I want to integrate into the system (using an old Carbide3D touch probe, install a power fail/resurrect ability and install an externally switched feed hold (pause/resume) facility, I'm almost ready to cut stuff!
Carbide3D
I am in the middle of comissioning a mill right now too. I understand what you are going through.
GOOD LUCK!
Would you post a picture or two of your mill?
Sure, @fcwilt, but I’ll do it tomorrow 🥱
Not sure if this is what you wanted, @fcwilt, but here you go:
The machine is a RatRig 1075 KillerBee, although I've made a few amendments to the supplied machine, including using 4x proximity sensors instead of limit switches, and redesigned the spoil board supports. It has a Duet 3 MB6HC control board (as you already know!) connected via a wired network to a Microsoft Surface Pro.
Most of my work is done on my iMac, which is in the house, so I connect to the Surface Pro and the Duet via a wired network using powerline adapters.
Apart from my own knowledge limits, everything seems to work well - but the proof will be when I eventually make something!
@nightowl999
Thanks for the pictures.
