Spurious heater faults
cc @Phaedrux maybe?
Can you try removing
M307 H0 R0.246 K0.112:0.000 D30.62 E1.35 S1.00 B0 ; Bed, with enclosure tuned at 100c
from your config.g and re-running the tuning process withM303 H0 S100
and this time take a screen shot of the tuning process after a while so we can see the graph?Be sure to start the tuning process from ambient temp.
Thanks!
Still running the tuner, can post results when done. Just realized that my config.g has "B4240" for the bed thermistor, when I think it should be B3950. Could that be the cause?
I think the problem is that it is using the wrong thermistor value, as per the graph the keenovo thermistor vs bed thermistor are way different when they should be the same. This is my mistake.
Thank you Phaedrux!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
Hmm, got another heater fault today despite having changed the thermistor value and retuning.
Are you copy and pasting the results into your config?
Have you tried using M500 to save them to config-override.g and then adding M501 to the end of your config to load the values at startup?It seems like the values aren't actually applied. Can you send
M307 H0
in the gcode console and see what values it is actually using.Is it perhaps your part cooling fan coming on and causing the temp to drop? Or is the enclosure temp different during a print versus when it's tuned?
Yep I do copy/paste the line into config.g. It looks like the values are applied correctly too:
In my config.g:
M307 H0:
What does the temp graph look like when the error occurs? It seems weird that it expects a rate of 0.28 but actually saw a rate of 0. Is the thermistor not making good contact?
undefined Phaedrux has marked this topic as unsolved
This post is deleted! -
@arnold_r_clark said in Spurious heater faults:
never reach the same conclusion twice
How much variation are you seeing?
