Coordinate System Correction Help
I've been trying to setup my coordinate system correctly for a bit and I'm just turning myself around at this point. When I first home my X (bed) and Y (hot end) they both go the correct direction and home at the location I want them to.
However, when I got to home z and it's in the absolute mode, it goes the wrong way to get back to (0,0) where I have it probing in homez.g. What do I need to change to get correctly oriented in absolute mode? Is it my homing files that are wrong? is it my axis limits? end stop config? probe offsets? Any help is appreciated as I seem to be directionally challenged at the moment
My Config.g File
; CONFIG.G ; Drives M569 P0 S1 ; physical drive 0 goes forwards (eventually X) M569 P1 S1 ; physical drive 1 goes forwards (eventually Y) M569 P2 S1 ; physical drive 2 goes forwards (eventually Z) ; Axis Limits M208 X-5 Y-5 Z0 S1 ; set axis minima M208 X150 Y150 Z200 S0 ; set axis maxim ; Endstops M574 X1 S3 ; configure sensorless endstop for high end on X M574 Y1 S3 ; configure sensorless endstop for high end on Y M915 X Y R0 F0 S5 ; configure stall detection for X and Y ; Z-Probe M950 S0 C"duex.pwm1" ; Duet 2 WiFi/Ethernet + DueX2/5 M558 P9 C"^zprobe.in" H5 F120 T6000 ; Duet 2 WiFi/Ethernet, DueX2/5 G31 P500 X20.888 Y33.5 Z4.3 ; set Z probe trigger value, offset and trigger height M557 X0:150 Y0:150 P3 ; define probing grid
Home X/Y
G91 ;relative positioning G1 H1 X320.5 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X-5 F12000 ; go back a few mm G1 H1 X320.5 F7000 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
G91 ; relative positioning G1 H1 Y320.5 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 Y-5 F12000 ; go back a few mm G1 H1 Y320.5 F7000 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning
Home Z
G91 ; relative mode G1 H2 Z10 F200 ; raise head 4mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode G1 X0 Y0 F2000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height
In your M574 commands you have specified that X and Y have "endstops" at the low end but your homing code is moving toward the high end.
Since you are using stall detection the homing code is going to finish but the X and Y positions should end up set to -5.
I don't think you want that.
In the code for homing Z you have a move to X = 0 and Y= 0 - this is going to end up moving away from where X and Y stopped after homing.
Where do you want 0, 0 to be? At the left front corner of the bed or the center of the bed?
@fcwilt the left front corner
@jrcl said in Coordinate System Correction Help:
OK - since you have the "endstop" sensing specified at the low end of the X/Y axes you need to re-do you homing code so X/Y move toward the low end, not the high end as you have now.
Remember when a low end endstop is triggered the axis position is set to the axis min value from M208 and when a high end endstop is triggered the axis position is set to the axis max value from M208.
@fcwilt said in Coordinate System Correction Help:
Got it, that helps . Now I've got everything setup (mostly) correctly, where X and Y are homing in the right place, DWC buttons move the axis the correct direction, but when I home Z my tool goes back to true (0,0) and not (35, 45) where I specified after X and Y hit the end stop in the homing files. What H value should I have for my last G1 command in homex.g and homey.g so that the adjustments to get it over the bed stay as 0,0 in absolute positioning.
;HOME X G91 ;relative positioning G1 H1 X320.5 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X-5 F12000 ; go back a few mm G1 H1 X320.5 F7000 ; move slowly to X axis endstop once more (second pass) G1 H1 X-35 F7000 ; move so Z probe is over bed in X direction G90 ; absolute positioning
;HOME Y G91 ; relative positioning G1 H1 Y-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 Y5 F12000 ; go back a few mm G1 H1 Y-320.5 F7000 ; move slowly to X axis endstop once more (second pass) G1 H1 Y45 F7000 ; move so Z probe is over bed in Y direction G90 ; absolute positioning
; HOME Z G91 ; relative mode G1 H2 Z10 F200 ; raise head 4mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode G1 X0 Y0 F2000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height
Unless you changed the M208 min settings both X and Y have a min value of -5.
You are still homing X toward the high end instead of the low end where you specified the "endstop" is - see the M574 command for X.
Once both the X and Y homing files are correctly homing towards the low end then the logical position of both X and Y will be set to -5 because that is the value set in M208.
Are those values actually correct in that you want X=0 and Y=0 to be 5mm from the low end of each axis?
When homing X you have a final move G1 H1 X-35 F7000. When homing Y you have a final move G1 H1 Y45 F7000.
G1 H1 moves are only used when seeking an endstop, either a physical switch or via stall detection.
So those final moves serve no purpose or not the purpose you intend. What do you believe those moves are doing?
Usually the goal of homing X and Y is to establish the desired position for X=0 Y=0. Is that what you are trying to do?
Also what is the intent of including a .5 after some of the values in the X and Y homing files? You only need a value large enough to insure enough movement to reach the limit of travel so that stall detection works. Since X and Y max are specified as 150 in the M208 I assume they are the limit of travel in the direction of the high end? If so homing moves of 160 will be all that is needed to insure homing works.
