Toolboard 1LC heater falut mid print
@hbm-3d said in Toolboard 1LC heater falut mid print:
Only after a reset of the 6HC
Interesting, what do you mean by "Only after a reset of the 6HC"?
Pressing reset button or issuing a command? -
@fotomas I pressed the reset button on the mainboard.
undefined Vinculum referenced this topic
I have picked up this problem again after upgrading my printer to firmware 3.4.
Both my 5+ Mini board and Toolboard run firmware 3.4.
To overcome this issue temporarily I have cameld from the 5+ mini direct to the thermistor and heater.
What I did now was upgrade to 3.4 and reconnected the thermistor to the toolboar again and changed back to my previous config:
;M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ;
Unfortunately the issue remains and I have no clue what to do next ?!!
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2804, free system stack 88 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,92.0%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0% Last reset 00:05:30 ago, cause: software Last software reset data not available Driver 0: pos 0, 840.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 25, reads 34192, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -2/10, peak Rx sync delay 205, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.5, current 24.5, max 24.5 MCU temperature: min 35.7C, current 37.9C, max 38.0C Last sensors broadcast 0x00000002 found 1 89 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 5312, send timeouts 0, received 2989, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: DL70G-S396U-D65J0-40KMW-2303Z-HP9WR Used output buffers: 11 of 40 (23 max) === RTOS === Static ram: 103684 Dynamic ram: 110360 of which 28 recycled Never used RAM 27640, free system stack 190 words Tasks: NETWORK(ready,14.1%,255) HEAT(notifyWait,0.0%,367) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,0.7%,105) MAIN(running,84.3%,428) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:06:55 ago, cause: software Last software reset at 2022-03-19 20:03, reason: User, GCodes spinning, available RAM 27592, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 415196, completed 415194, timed out 0, errs 0 Step timer max interval 1065 MCU temperature: min 34.4, current 36.6, max 36.6 Supply voltage: min 24.4, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 1 queued, 1 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 21825, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 26, reads 21824, writes 12, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 21827, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 25, reads 21823, writes 12, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 21825, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2022-03-19 20:10:28 Cache data hit count 788041111 Slowest loop: 27.07ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 3755, received 6679, lost 0, boc 0 Longest wait 5ms for reply type 6024, peak Tx sync delay 251, free buffers 18 (min 17), ts 2076/2075/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 16.85ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address f0:08:d1:02:ef:4b WiFi Vcc 3.40, reset reason Power up WiFi flash size 2097152, free heap 25200 WiFi IP address 192.168.0.117 WiFi signal strength -48dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 4 0 0 0 0 0 0 0
@fotomas can you try using temp1?
@jay_s_uk Maybe I was not clear in my explanation. After this happened I added four wires from the Mini 5+ to the heater and thermistor, That have worked fine, but partly defeats the purpose of havinga toolboard.
After upgrading both the toolboard an main board to firmware 3.4 I switched back to using the toolboard for the thermistor and the issue still remains. In other words the firmware upgrade and bringing the toolboard to the same firmware version as the main board did not help.
@fotomas I meant using temp1 on the toolboard
@jay_s_uk Ah.. sorry
Connected the thermistor to the toolboars temp1 connector, the beside IO2,
changed config.g as listed below:
;M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 M308 S1 P"121.temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp1 ;M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1 ;M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C
And got:
I have dome my best to verify that the wiring is not the problem but I get the same message with the thermistor disconnected.
for those who have not read the whole thread:
The Hotend heater connection (OUT0) does not function either but all the other stuff works:- Part cooling fan,
- Hotend cooling fan,
- BL-Toouch,
- X endstop & Y endstop (IO3)
- Extruder stepper motor
I am starting to think that my toolboard is broken in some way.
What else can I try?
17.05.2021
https://www.dold-mechatronik.de -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
