LE TORRI NEL GRAFICO
@luca-massimiliano HO UOTTENUTO CON IL BED,G ORIGINALE G32
Calibrated 6 factors using 10 points, (mean, deviation) before (-0.936, 2.324) after (0.007, 0.693) ORA lancio g29. ma cosa ignifica(mean, deviation) before (-0.936, 2.324) after (0.007, 0.693) ? -
@luca-massimiliano ecco cosa capita , non compredo dove sia il problema
g29 immagino la costruzone della stampante e' molto incerta ma se riuscissi a stamare piccoli pezzi precisi potrei correggere gli errori della grossolana costruzione che potrebbero essere ovunque . devo ridurre il sondaggio g 29 e come?Warning: Skipping grid point (-40.0, -120.0) because Z probe cannot reach it
Warning: Skipping grid point (-20.0, -120.0) because Z probe cannot reach it
Warning: Skipping grid point (0.0, -120.0) because Z probe cannot reach it
Warning: Skipping grid point (20.0, -120.0) because Z probe cannot reach it
Warning: Skipping grid point (40.0, -120.0) because Z probe cannot reach it
Warning: Skipping grid point (80.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (60.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (40.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (20.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (0.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (-20.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (-40.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (-60.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (-80.0, -100.0) because Z probe cannot reach it
Warning: Skipping grid point (-100.0, -80.0) because Z probe cannot reach it
Warning: Skipping grid point (-80.0, -80.0) because Z probe cannot reach it
Warning: Skipping grid point (-60.0, -80.0) because Z probe cannot reach it -
This usually means that your grid has unreachable points due to the offset between probe and nozzle, or the machine cannot physically travel to those points. In all cases, altering the size of the grid would be the solution.
@phaedrux puoi aiutarmi a comporre definere una griglia ?
What does the resulting heightmap look like?
The grid could be left to match the size of the bed. You can ignore the grid points that are not reachable as long as the resulting heightmap is still useful.
This post is deleted! -
@phaedrux HO SISTEMATO LA STRUTTURA DELLA STAMPANTE GRAZIE AD UN GROSSO CALIBRO. HO REGOLATO I FINE CORSA ,FACCIO SCENDERE VICINO AL CENTRO E DOPO AVER AZZERATO M666 , MISURO CON IL CALIBRO LA DISTANZA TRA LE SLITTE E IL BED ,DIREI PERFETTO ,POI LANCIO G 32 POI M666 E OTTENGO M666
Endstop adjustments X-1.70 Y-1.83 Z3.53, tilt X0.00% Y0.00%, MISURO COL CALIBRO E LE MISURE DELLE ALTEZZE DELLE SLITTE NON SONO PI' UGUALI -
@luca-massimiliano M666
Endstop adjustments X-1.63 Y-1.84 Z3.46, tilt X0.00% Y0.00% ORA DOPO G32 COME DEVO INTERVENIRE ABBASO FISICAMENTE IL FINE CORSA DI Z ? E DI QUANTO ? DI 3.46 VERSO IL LETTO? ORA HO RIPORTATO M666 A X Y Z 0 E NON HO ESEGUITO IL G32 N G29 , QUINDI SENZA NESSUNA CALIBRAZIONE HO OTTENUTO STAMPE COSA IMPOSSIBILE DOPO LE 2 CALIBRAZIONI. SAI DIRMI I MOTIVO . SCUSA SE HO SCRITTO maiuscolo era impostato -
M666 Endstop adjustments X-1.63 Y-1.84 Z3.46
I'm not positive, but I think this would indicate that the endstop on your Z tower is much farther out of position compared to your other towers.
Auto calibration can compensate I think, but the recommendation is to be within 1mm of each other.
https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration#m666-command
@phaedrux forse non riesco a spiegarmi la distanza fisica dei fine corsa al piano di stampa per ciascuna torre risulta uguale con m666 x0 y0 z0 e stampa corretto (quindi se sono corretti i fine corsa ,perché mi corregge z 3.46 non può esserci un errore di 4mm . ma se lancio il g32 o g29 mi cambia sia la distanza fisica dei fine corsa al piano di stampa sia m666 =X-1.63 Y-1.84 Z3.46, e in piu' non stampa piu',la soda e' una BLTouch funziona correttemente. (
@rjenkinsgb said in LE TORRI NEL GRAFICO:
Kossel
ciao ho letto che hai fatto diversi progetti, ecco la mia domanda :nella progettazione di una delta Kossel che limiti si hanno dimensionalmente
@phaedrux CIAO CARO maximum size delta bed AND OF THE TOWERS MANAGED BY Duet3D WIFE, IT HAS LIMITS
@luca-massimiliano said in LE TORRI NEL GRAFICO:
I am not sure what you are saying.
@phaedrux using my Duet3D WIFE I would like to build a new delta printer, are there any size limits, for example the maximum height or the print radius, would I like to build a new delta printer?
Start by reading this. I am building Delta 1400 high 550 diameter.
@tecno thanks tecno my question: are there maximum size limits for the management of my Duet3D WIFE card?
@tecno GeoGebra dSim graphic simulato non riesco aprire scaricare i programmi dei vari simulatore tu quale usi ?simulated I can not open download the programs of the various simulator which one do you use?
