newbie with MFM
@apak i think, this could be a serial number
Well, I got this msg,
Duet3D rotating magnet filament monitor v1 on pin 121.io1.in, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 10.0mm, no data received
config
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jan 23 2022 08:20:22 GMT+0100 (hora estándar de Europa central) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"URmaker" ; set printer name ;M918 P1 E4 F2000000 ; configure direct-connect display LCD ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards X M569 P0.1 S1 ; physical drive 0.1 goes forwards Y M569 P0.2 S1 ; physical drive 0.2 goes forwards Z1 M569 P0.3 S1 ; physical drive 0.2 goes forwards Z2 M569 P121.0 S1 ; physical drive 121.0 goes forwards E M584 X0.0 Y0.1 Z0.2:0.3 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z640.00 E415.00 ; set steps per mm M566 X600.00 Y600.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z600.00 E3000.00 ; set maximum speeds (mm/min) M201 X900.00 Y900.00 Z200.00 E600.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1400 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S120 ; Set idle timeout ; Axis Limits M208 X0 Y-10 Z-1 S1 ; set axis minima M208 X550 Y360 Z300 S0 ; set axis maxima ; Leadscrews Definition for Z_Tilt M671 X-178:732 Y148:148 S8 ; OJO revisar y medir la posicion de los husillos ; Endstops M574 X2 S1 P"!io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in M574 Y2 S1 P"!io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ;M574 Z1 S1 P"!io3.in+!io2.in" ; configure switch-type 2 endstop independent ; Filament Sensor ;M98 P"0:/sys/00-Functions/FilamentsensorStatus" M591 D0 P3 C"121.io1.in" S1 R70:130 L24.8 E10.0 ; Z-Probe M558 P8 C"!121.io0.in" H10 F300:150 T6000 R0.5 ; set Z probe type to unmodulated and the dive height + speeds G31 P1000 X-25 Y45 Z6.29 ;Z6.37 ; set Z probe trigger value, offset and trigger height M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters M557 X10:520 Y35:365 P5:4 ; define mesh grid ; Heaters BED M308 S0 P"temp0" Y"thermistor" T100000 B4092 A"Heated Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M143 H0 P0 S120 A2 ; disable temporarily H0 if temp exceeds 120C M143 H0 P0 S130 A0 ; heater fault H0 if temp exceeds 130C M570 H0 P60 T15 S0 ; heater fault for 15 seg of 60C excursion ; Heaters HOTEND M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M143 H1 S275 A2 ; disable temporarily H1 if temp exceeds 275C M143 H1 S285 A0 ; heater fault H1 if temp exceeds 280C M570 H1 P10 T30 S0 ; heater fault for 10 seg of 30C excursion ; Fan0 = Part Coooling M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Fan1 = Hotend M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Fan2 = Case Fan M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; PID Backup M307 H0 R0.505 C362.346:362.346 D9.17 S1.00 V23.8 B0 I0 M307 H1 R4.689 C199.474:103.181 D7.28 S1.00 V22.7 B0 I0 ; Tools M563 P0 S"T0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M302 S180 R180 ; allow extrusion starting from 180°C and retractions already from 180°C ; Firmware Retraction M404 N1.75 ; Define filament diameter for print monitor M207 S0.95 R0 F2400 Z0 ; Firmware retraction ; LCD M575 P1 S1 B57600 ; enable support for PanelDue ; Miscellaneous M501 ; load saved parameters from non-volatile memory M703 ; Load Preloaded filamento config M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
Checked wiring and seams OK...
MFM Toolboard
3.3v 3.3v
gnd gnd
out io1.in -
red led flashes 7 times, it´s a v1 magnet, so how can I fix this issue?
@apak sanded top part and now it´s flashing red/green, will try now
M591 D0 Duet3D rotating magnet filament monitor v3 on pin 121.io1.in, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 10.0mm, version 3, mag 125 agc 128, no calibration data
NEED more sanding I presume
Does the axis of the hobbed assembly rotate when you push filament through the sensor? If you are not sure, have a look at this thread.
@apak It won't get "real" data until you print something.
I'm not sure if hitting the "Extrude" button on DWC will be enough or if you actually have to start a print and wait a little bit.
@alankilian it works fine, I adjust the value, but once pause and resume, the values where doubled and kept on pausing
@apak Post the results of M591 D0 before and during the pause.
Also, your AGC value of 128 is too high.
THIS page says what to do about it:
Values for 'agc' of 50 to 105 are considered normal. If the value is higher, up to 128, the distance between the magnet and the sensor is likely to be too large (target is 0.25mm). Check that the screws holding the PCB down are not loose (caution: they are screwed into the plastic, so don't over-tighten them). If they are already tight, you could remove the 2 long screws to separate the two plastic parts and very slightly sand down the bottom surface of the top one (the one with the PCB attached) to move the sensor closer to the magnet.
5/3/2022, 16:10:17 M591 D0 Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 113 agc 128, error 7 5/3/2022, 16:10:16 M591 D0 Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 116 agc 128, measured sensitivity 28.06mm/rev, min 36% max 106% over 45.6mm
getting ERROR 7 every now and then, so I am not able to use MFM
right now it´s disable so I can monitor what happens as it keeps logging data even disabled
undefined apak referenced this topic
M122
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6M2-NW4SD-6J1DL-3SN6K-1TQ7K Used output buffers: 10 of 24 (21 max) === RTOS === Static ram: 23876 Dynamic ram: 76888 of which 176 recycled Never used RAM 10620, free system stack 110 words Tasks: NETWORK(ready,14.2%,244) HEAT(delaying,0.0%,330) Move(notifyWait,0.2%,309) MAIN(running,85.4%,445) IDLE(ready,0.2%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:36:12 ago, cause: power up Last software reset at 2022-02-18 00:31, reason: User, GCodes spinning, available RAM 11004, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 26.4, current 41.1, max 45.8 Supply voltage: min 23.5, current 24.2, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/20, heap memory allocated/used/recyclable 2048/930/728, gc cycles 8 Driver 0: position 19172, ok, SG min/max 0/302 Driver 1: position 301, ok, SG min/max 0/304 Driver 2: position 249, ok, SG min/max 0/1023 Driver 3: position 0, standstill, SG min/max 0/1023 Driver 4: position 0, ok, SG min/max 0/295 Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2022-03-12 10:09:46 Cache data hit count 4294967295 Slowest loop: 136.97ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 4.5ms, write time 159.6ms, max retries 0 === Move === DMs created 83, maxWait 622074ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 13127, completed moves 13119, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.2 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X140.482 Y140.933" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is doing "G4 S2 " in state(s) 0 0, running macro Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: pos 63.28, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === Network === Slowest loop: 162.91ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address bc:ff:4d:45:5d:1f WiFi Vcc 3.31, reset reason Turned on by main processor WiFi flash size 4194304, free heap 20008 WiFi IP address 192.168.0.51 WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@apak ```
12/3/2022, 10:08:48 M591 D0
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.37mm/rev, min 10% max 116% over 710.7mm
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, error 7
12/3/2022, 10:08:47 M591 D0
12/3/2022, 10:08:46 M591 D0
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 112 agc 128, error 7
12/3/2022, 10:08:45 M591 D0
12/3/2022, 10:08:44 M591 D0
12/3/2022, 10:08:43 M591 D0
12/3/2022, 10:08:42 M591 D0
12/3/2022, 10:08:41 M591 D0
12/3/2022, 10:08:39 M591 D0
12/3/2022, 10:07:58 M591 D0
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.14mm/rev, min 10% max 115% over 690.7mm
12/3/2022, 10:07:57 M591 D0
12/3/2022, 10:07:56 M591 D0
12/3/2022, 10:07:55 M591 D0
12/3/2022, 10:07:53 M591 D0
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.17mm/rev, min 10% max 115% over 680.7mm
12/3/2022, 10:07:52 M591 D0
12/3/2022, 10:07:51 M591 D0
12/3/2022, 10:07:49 M591 D0
12/3/2022, 10:07:48 M591 D0
12/3/2022, 10:07:47 M591 D0
12/3/2022, 10:07:46 M591 D0
12/3/2022, 10:07:44 M591 D0
12/3/2022, 10:07:43 M591 D0
12/3/2022, 10:07:42 M591 D0
12/3/2022, 10:07:40 M591 D0
12/3/2022, 10:07:35 M591 D0
Duet3D rotating magnet filament monitor v3 on pin e1stop, disabled, sensitivity 25.62mm/rev, allow 1% to 200%, check every 10.0mm, version 3, mag 113 agc 128, measured sensitivity 29.17mm/rev, min 10% max 115% over 680.7mm -
