DWC Duet Web Control 3.4.0-rc2 no extrude or retract
@phaedrux
M550 P"Valkyrie 3030 V001" ; set printer name
M669 K1 ; core xy
G29 S1 ; Set Units to Millimeters; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S1 ; physical drive 0 goes forwardsM569 P0.1 S1
M569 P0.1 S1 ; physical drive 1 goes forwardsM569 P0.1 S1
M569 P0.2 S1 ; physical drive 2 goes forwards
M569 P0.3 S1 ; physical drive 3 goes forwards (spare)
M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop
M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards
M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwardsM584 X1 Y0 E2 Z0.4:0.5:0.6 ; set drive mapping FL,FR,RC
M350 X16 Y16 I1 ; configure microstepping with interpolation
M350 Z16 E16 I1
M92 X80.00 Y80.00 Z320.00 E260.00 ; set steps per m
M566 X500.00 Y500.00 Z800.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min)
M203 X8000.00 Y8000.00 Z1000.00 E400.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z200.00 E250.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1400 I10 ; set motor currents (mA) and motor idle factor in per cent
M84 S20 ; Set idle timeout; Axis Limits
M208 X0 Y0 Z0 S1 ; set axis minima "Travel Area"
M208 X270 Y240 Z405 S0 ; set axis maxima "Travel area"; Endstops
M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
M574 Y2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
;M574 Z2 S2 P"!io4.in" ; != invert signal
M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
M671 X-34.4:296:132.5 Y0:0:296 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584; Sensorless config
M915 P0.4:0.5:0.6 S5 R0 F0 H200 ; Lower values less sensitive S3, F filter, R =Action; Z-Probe
M558 P8 C"!io3.in" H5 F600 T18000 A30 S0.03 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 Z0.5 ; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
G31 P500 X26 Y6 ; set x,y trigger value, offset and trigger height
M557 X30:270 Y10:250 S40 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T°C" ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"out0" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0
M307 H0 R0.140 K0.103:0.000 D43.19 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
M308 S1 P"temp1" Y"thermistor" T100000 B4267 A"Extruder T°C" ; configure sensor 1 as thermistor on pin e0temp (104gt2)
M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 R3.548 K0.733:0.000 D4.96 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"out4" Q500 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"out3" Q500 ; create fan 1 on pin fan1 and set its frequency
M98 P/macros/3zhome -
@moth4017 You don't have a T0 at the end to select Tool 0. Your M98 needs to be changed to M98 P"/macros/3zhome"
@moth4017 said in DWC Duet Web Control 3.4.0-rc2 no extrude or retract:
G29 S1 does not set units to mm. It loads the heightmap, which shouldn't happen in config.g anyway. Best to remove that line.
@phaedrux removed G29, can you think of any reason why the extrude/retrack may not be working?
Is the tool selected? Your screen shot doesn't show the full window so it's hard to tell.
Can you share the results of M122 and M98 P"config.g"
It seems you're using a mini5+? But you have 6 drivers configured...
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc1 (2022-02-09 10:27:22) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
Used output buffers: 3 of 40 (14 max)
Static ram: 103652
Dynamic ram: 109368 of which 12 recycled
Never used RAM 28608, free system stack 154 words
Tasks: NETWORK(ready,12.6%,240) HEAT(notifyWait,0.0%,338) Move(notifyWait,0.0%,292) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,1.1%,114) MAIN(running,85.3%,428) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:04:03 ago, cause: power up
Last software reset at 2022-03-01 07:23, reason: User, GCodes spinning, available RAM 28608, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
MCU revision 3, ADC conversions started 243877, completed 243877, timed out 0, errs 0
Step timer max interval 955
MCU temperature: min 19.6, current 29.8, max 30.4
Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22127, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 1: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22127, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 2: pos 96320, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22126, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 22126, writes 9, timeouts 0, DMA errors 0, CC errors 0
Driver 4: pos 0, standstill, SG min 152, read errors 0, write errors 0, ifcnt 16, reads 22120, writes 16, timeouts 0, DMA errors 0, CC errors 0
Driver 5: pos 0, standstill, SG min 16, read errors 0, write errors 0, ifcnt 16, reads 22119, writes 16, timeouts 0, DMA errors 0, CC errors 0
Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 22118, writes 17, timeouts 0, DMA errors 0, CC errors 0
Date/time: 2022-03-02 16:52:41
Cache data hit count 459070420
Slowest loop: 118.95ms; fastest: 0.08ms
=== Storage ===
Free file entries: 9
SD card longest read time 13.8ms, write time 11.5ms, max retries 0
DMs created 83, segments created 3, maxWait 624ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Heater 0 is on, I-accum = 0.2
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is doing "M190 S85 " in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 2193, received 0, lost 0, boc 0
Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1220/0/0
Tx timeouts 0,0,1219,0,0,972 last cancelled message type 30 dest 127
=== Network ===
Slowest loop: 52.60ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address f0:08:d1:02:a1:0b
WiFi Vcc 3.34, reset reason Power up
WiFi flash size 2097152, free heap 26896
WiFi IP address 192.168.0.19
WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
M98
Error: M98: No P or R parameter; General preferences
M669 K1 ; core xy; Network
M350 Z16 E16 I1
M98 P/macros/3zhome - WiFi -
M98
Error: M98: No P or R parameterThe command to send is
M98 P"config.g"
Can you please test with RC2?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/DuetWebControl-SD.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0rc2/Duet3Firmware_Mini5plus.uf2
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
@phaedrux
Hi had issues updating firmware via DWC
Error: M997: In-application programming binary "0:/firmware/Duet3_SDiap32_Mini5plus.bin" not foundso did the update via usb.
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledUpdated to rc2
I worked out the issue i did not have any filaments loaded, didn't realise i had to enter a filament , im still not sure why it needs filaments in DWC as all the info comes from the slicer
You appear to be missing this file.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3_SDiap32_Mini5plus.bin
You should place it in the firmware directory to make future updates possible.
I can't really make out the details in your screen shot. What do you mean by loading a filament?
once i had added a filament here see photo then the retract/extrude was available
since the new release of 3.4.0 i have this issue again where the retract and extrude is grayed out
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Valkyrie 3030 V001" ; set printer name M669 K1 ; core xy ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0 goes forwardsM569 P0.1 S1 M569 P0.1 S1 ; physical drive 1 goes forwardsM569 P0.1 S1 M569 P0.2 S1 ; physical drive 2 goes forwards ( blown needs replacing) M569 P0.3 S1 ; physical drive 3 goes forwards (extruder M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwards M584 X1 Y0 E3 Z0.4:0.5:0.6 ; set drive mapping FL,FR,RC M350 X16 Y16 I1 ; configure microstepping with interpolation M350 Z16 E16 I1 M92 X80.00 Y80.00 Z320.00 E260.00 ; set steps per m M566 X500.00 Y500.00 Z800.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X8000.00 Y8000.00 Z1000.00 E400.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z200.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1400 I10 ; set motor currents (mA) and motor idle factor in per cent M84 S20 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima "Travel Area" M208 X270 Y240 Z405 S0 ; set axis maxima "Travel area" ; Endstops M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in M574 Y2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in ;M574 Z2 S2 P"!io4.in" ; != invert signal M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors M671 X-34.4:296:132.5 Y0:0:296 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584 M558 P8 C"!io3.in" H5 F600 T18000 A30 S0.03 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 Z0.9 ; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed G31 P500 X26 Y6 ; set x,y trigger value, offset and trigger height M557 X30:270 Y10:250 S40 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T°C" ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"out0" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.140 K0.103:0.000 D43.19 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4267 A"Extruder T°C" ; configure sensor 1 as thermistor on pin e0temp (104gt2) M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R3.435 K0.348:0.274 D6.64 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out3" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 T0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M98 P"/macros/3zhome"
@moth4017 Where do you select T0? I have a T0 at the bottom of config.g to make sure it's selected.
@stephen6309 when i checked in the console which tool i have it has defaulted to T0 , but i have added it now to my config.g now.
Thanks for the reply -
Ok even though the firmware new that the tool T0 was selected adding T0 to the config seems to have fixed this issue.
This post is deleted! -
@arnold_r_clark
Ill get some Rat poison
same here with 3.4
Found out that you have to select tool active , then it works
