npn 5v fly rrf e3
@gloomyandy have I blown something on the board
shall i update the firmware
Electronics
Diagnostics
Board: fly_E3 (STMWiFi)
Firmware: RepRapFirmware for STM32F4 based Boards 3.3RC2+1_1 (2021-05-13)
Duet WiFi Server Version: 1.26-01S-DNote: You can install updates on the System page.
will marlin be easier
@npm1 Can you turn off your board, disconnect the probe and plug in one of the other endstop switches (x or y) into the zstop socket. Then run the two tests again once without pressing the endstop switch, then again with the endstop switch pressed. Run this test with the Z driver still removed.
@gloomyandy endstop works with zero issues with everything triggered correctly
M119
Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: at min stop
2/25/2022, 9:38:20 PM g31
Z probe 0: current reading 0, threshold 500, trigger height 2.500, offsets X0.0 Y0.0
2/25/2022, 9:38:10 PM m119
Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped -
@gloomyandy the only thing i can think of is to switch the cables on the zstop cables around
@npm1 @npm1 In which case I would be looking very closely at that probe. Are you sure you have correctly identified the various wires? See: https://forum.duet3d.com/topic/25906/inductive-sensor-npn-no-not-working?_=1645824856161 (thanks to Jay for digging that one out).
@gloomyandy i knoq that the 5v cable is correctly connected ill switch the cables around and confirm to you shortly
I'm just gonna call it a day, may use an optical setup it with one of those allen keys
thanks for your efforts
