Heater fault when moving Y Axis
Hello, I could use some assistance. I am setting up a build using a DUET 3 HC6. I am installing a pellet extruder that is has three heaters with independent K-Style Thermocouples. I have the thermocouples ran to two daughterboards. I was able to get the heaters tuned but now when I move the Y axis my heaters fault and set to 2000 c instead of their actual temp.
I checked the wiring on the thermocouples.
I made sure the continuity is good.
I disabled the Y Axis and moved the extruder by hand to see if it would trigger the heater fault (It did not).
I've checked the wiring of my Y motor, everything is great.Thank you for your help
below is the link to my config file.
https://docs.google.com/document/d/10XdfVg8JJ72Q2h5y4btkh5xpThhucuYZW2Qnh01Lk8I/edit?usp=sharing -
Are you using thermocouple extension wires?
Are they of the right type?
Do the wires run next to any motor wiring? -
@phaedrux
I am not. I am currently using 24ga wires. Did not know that thermocouple wires needed to be anything special.Ill try that next.
Thank you
This post is deleted!
