Connecting stepper motor encoders to closed loop drivers
@v-a-m-p-printing-snproj
; config-override.g file generated in response to M500 at 2021-03-31 14:08
; Heater model parameters
M307 H0 A72.0 C92.5 D2.7 S1.00 V24.1 B0
M307 H1 A654.0 C177.9 D11.3 S1.00 V24.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
@v-a-m-p-printing-snproj said in Connecting stepper motor encoders to closed loop drivers:
I changed the direction with the switch on the driver and it printed alright, prints were sloppy. I ordered a new hot end so hopefully that helps with the sloppy prints when i get it moving right again.
OK, it's good to hear you've got it running.
Let us know when you have a new hot-end and have some new results.
@alankilian Oh it was printing before I put the closed loop drivers on. I got it to home the x and y fine separately, but when I home all itll home x and y and shoot off to the corner and trys to keep moving without homing the z.
Is it possible my cordinates got all screwed up? Should i reset all my homing? -
Can you describe what you are doing to accomplish this?
Are you clicking the "home all" button on the DWC or are you running the homex.g file by hand?
@alankilian Im clicking home all on the dwc.
OK, this is your homeall.g file:
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-420 Y420 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-420 ; home X axis G1 H1 Y420 ; home Y axis G1 X-5 Y-5 F6000 ; go back a few mm G1 H1 X-420 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y420 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X10 Y75 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
Type those lines in one-at-a-time in the console while taking a video and we'll be able to see where the error occurs.
@alankilian I noticed that my Y coordinate was reading 315 where it originally was deploying my Bl touch to home the z so I changed the Y coordinate for the first probe point to Y315 instead of Y 75 and the home all worked fine.
@v-a-m-p-printing-snproj Excellent!
@alankilian Will this effect the positioning now when I go and try to print?
Now that you've got the closed-loop drivers connected, please start a new thread completely describing the problem you are having and people will take a look and respond.
Posting all your config and homing files in that new thread will help people help you.
You should mark this thread solved.
@alankilian Sounds good thanks for the help! One more question now that everything is moving in the right direction and homing properly can I set my drivers to closed loop?
Start a thread about "Closed-Loop tuning on CL57T stepper driver" and we'll talk there.
It's going to be a long conversation I bet.
