Connecting stepper motor encoders to closed loop drivers
@v-a-m-p-printing-snproj
Config .g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:39 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"VAMP" ; set printer name
M669 K1 ; select CoreXY mode; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M569 P5 S1 T2.5:2.5:5:5 ; physical drive 5 goes forwards
M569 P6 S1 T2.5:2.5:5:5 ; physical drive 6 goes forwards
M569 P7 S0 T2.5:2.5:5:5 ; physical drive 7 goes backwards
M569 P8 S0 T2.5:2.5:5:5 ; physical drive 8 goes backwards
M569 P9 S0 T2.5:2.5:5:5 ; physical drive 9 goes backwards
M584 X5 Y6 Z7:8:9 E3 ; set drive mapping
M92 X80.5234 Y79.6020 Z800.00 E95.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
M906 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X415 Y415 Z440 S0 ; set axis maxima; Endstops
M574 X1 Y2 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H6 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700
M305 P1 T4700000 B5140 R4700 ; set thermistor + ADC parameters for heater 1
M143 H0 S180 ; set temperature limit for heater 0 to 100C
M143 H1 S490 ; set temperature limit for heater 1 to 490C; Fans
M501 -
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:40 GMT-0400 (Eastern Daylight Time)
G91 ; relative positioning
G1 H1 X-420 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 H1 X-420 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning -
; homey.g
; called to home the Y axis
G1 H1 Y420 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y420 F360 ; move slowly to Y axis endstop once more (second pass)
; homez.g
; called to home the Z axis
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
; homeall.g
; called to home all axes
G1 H1 X-420 Y420 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-420 ; home X axis
G1 H1 Y420 ; home Y axis
G1 X-5 Y-5 F6000 ; go back a few mm
G1 H1 Y420 ; then move slowly to Y axis endstop
G1 X10 Y75 F6000 ; go to first bed probe point and home Z
; Example Homing file for RepRapFirmware on delta printerM117 Use https://configurator.reprapfirmware.org/ to set up your printer config
;G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
;G1 S1 X320 Y320 Z320 F2500 ; move all carriages up 320mm, stopping at the endstops
;G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
;G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
;G1 Z-5 F2000 ; down a few mm so that we can centre the head
;G90 ; back to absolute positioning
;G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate -
; config-override.g file generated in response to M500 at 2021-03-31 14:08
; Heater model parameters
M307 H0 A72.0 C92.5 D2.7 S1.00 V24.1 B0
M307 H1 A654.0 C177.9 D11.3 S1.00 V24.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
@v-a-m-p-printing-snproj said in Connecting stepper motor encoders to closed loop drivers:
I changed the direction with the switch on the driver and it printed alright, prints were sloppy. I ordered a new hot end so hopefully that helps with the sloppy prints when i get it moving right again.
OK, it's good to hear you've got it running.
Let us know when you have a new hot-end and have some new results.
@alankilian Oh it was printing before I put the closed loop drivers on. I got it to home the x and y fine separately, but when I home all itll home x and y and shoot off to the corner and trys to keep moving without homing the z.
Is it possible my cordinates got all screwed up? Should i reset all my homing? -
Can you describe what you are doing to accomplish this?
Are you clicking the "home all" button on the DWC or are you running the homex.g file by hand?
@alankilian Im clicking home all on the dwc.
OK, this is your homeall.g file:
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-420 Y420 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-420 ; home X axis G1 H1 Y420 ; home Y axis G1 X-5 Y-5 F6000 ; go back a few mm G1 H1 X-420 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y420 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X10 Y75 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
Type those lines in one-at-a-time in the console while taking a video and we'll be able to see where the error occurs.
@alankilian I noticed that my Y coordinate was reading 315 where it originally was deploying my Bl touch to home the z so I changed the Y coordinate for the first probe point to Y315 instead of Y 75 and the home all worked fine.
@v-a-m-p-printing-snproj Excellent!
@alankilian Will this effect the positioning now when I go and try to print?
Now that you've got the closed-loop drivers connected, please start a new thread completely describing the problem you are having and people will take a look and respond.
Posting all your config and homing files in that new thread will help people help you.
You should mark this thread solved.
@alankilian Sounds good thanks for the help! One more question now that everything is moving in the right direction and homing properly can I set my drivers to closed loop?
Start a thread about "Closed-Loop tuning on CL57T stepper driver" and we'll talk there.
It's going to be a long conversation I bet.
