Duet3 mini voron gantry level problem
Hello guys, I'm new here and from Germany. I switched from Klipper to RRF. So far I am very happy that I did. I love it and the panel due 7 inch. But i have a gantry level problem with the duet mini in my voron 2.4 350mm. I have a IR probe to probe Z. With the G32, to measure, it first moves to the middle and then all 4 corners. Then this error message comes up.
Error: Bed calibration : 4 factor calibration requested but only 0 points provided
bed.g
4 M561
5 G28
6 G30 P1 X15 X5 z-99999
7 G30 P2 X15 Y315 z-99999
8 G30 P3 X300 X315 z-99999
9 G30 P4 X300 X5 z-99999 S4How do I continue? I've searched the internet for hours but just can't find the solution. I would be very grateful for tips.
Greetings Marc
@jamaicarasta in all but one probe point you have 2 X axis coordinates, change it too -
bed.g
4 M561
5 G28
6 G30 P1 X15 Y5 z-99999
8 G30 P3 X300 Y315 z-99999
9 G30 P4 X300 Y5 z-99999 S4 -
@jamaicarasta your probe points to start at 0
So P0, P1, P2 and P3, not P1, P2, P3 and P4 -
@jay_s_uk
ok thanks i thought i have to start at p1 because my 4z motors are plugged into 1,2,3,4.
I will Try it in a few Hours when I'm back at the printer.
I'll let you know
It's amazing how quickly you get an answer here. -
@jumpedwithbothfeet
where do i have 2 times x? don't quite understand. I gave correct points 4 times in my opinion.
Thanks -
@jay_s_uk
and one more question if i may. it does not go to my specified coordinates exactly. X15 stays at X40 on rehearsal. but if I drive normally with g1 then it drives exactly to x15. only at g32 is it off by 25. -
@jamaicarasta it applies the G31 offsets to that, so if your probe is -25 in X, the nozzle has to be at 40 for the probe to be at 15
@jay_s_uk
ok i will check that i took a config from the internet from the beginning and maybe the value there is wrong for my probe -
@jay_s_uk
So the error is gone, now I have the next error. is that something in the config file?
G32
Error: This kinematics does not support auto-calibration
Config:General preferences -------------------------------------------------------
M550 P"Duet Voron" ; set printer name
M669 K1 ; select CoreXY mode; Network --------------------------------------------------------------------
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; Drives ---------------------------------------------------------------------
; ----+---- Z-Drives
; | 2 | 3 |
; | 1 | 4 |
; FrontM584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
M569 P0 S1 ; extruder motor direction
M569 P1 S1 ; Z1 motor direction
M569 P2 S0 ; Z2 motor direction
M569 P3 S1 ; Z3 motor direction
M569 P4 S0 ; Z4 motor direction
M569 P5 S1 ; X motor direction
M569 P6 S1 ; Y motor directionM350 X16 Y16 Z16 E16 I1 ; set microstepping
M92 X80 Y80 Z400 E426 ; set microsteps per mm
M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; thermal section ------------------------------------------------------------
M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K); Axis Limits ----------------------------------------------------------------
M208 X350 Y350 Z340 S0 ; set axis maxima; Endstops -------------------------------------------------------------------
M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in; Z-Probe --------------------------------------------------------------------
M558 K0 P8 A2 S0.05 C"^io1.in" H5 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
G31 P500 X0 Y10 Z1.590 ; set Z probe trigger value, offset and trigger height
M557 X15:335 Y15:335 S20 ; define mesh grid; Heaters --------------------------------------------------------------------
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans -----------------------------------------------------------------------
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off; Tools ----------------------------------------------------------------------
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings are not defined --------------------------------------------
M501 -
@jamaicarasta You need an M671 to set the pivot points of the gantry.
I would probably go with the point where it the belts attach -
@jay_s_uk
ok m671… i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there? -
@jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
@jay_s_uk
Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
You are my hero
I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand. -
@jay_s_uk
I measured and found the values. Should I measure the values from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him. -
@jamaicarasta the locations are in relation to X0 Y0
@jay_s_uk
Ok perfect
it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape... -
@jamaicarasta you had the X listed twice in each line instead of one X and one Y
however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning
@jumpedwithbothfeet
Sorry that was a old file
I don’t saw this. Now is not x and x in one line -
@jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well -
@jay_s_uk
Thanks for the tip bro.
Now I will make my mesh.g file.with an error: Push(): stack overflow
; mesh.g
; called to perform automatic bedmesh via G29M561 ; clear any bed...
G29 ; bed mesh
G1 X175 Y175 Z50 F20000 ; go to bed middle; bed.g
; called to perform automatic bed compensation via G32M561 ; clear any bed transform
G30 P0 X15 Y20 Z-99999 ; Probe links vorne
G30 P1 X15 Y315 Z-99999 ; Probe links hinten
G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
G1 X175 Y175 Z5 F20000; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
G91 ; relative positioning
G1 H1 X355 F6000 ; home X axis
G1 X-5 F6000 ; go back a few mm
G1 H1 X355 F360 ; move slowly to X axis endstop
G1 H1 Y355 F6000 ; home y axis
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y355 F360 ; move slowly to Y axis endstop
G90 ; absolute positioning
G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
G90 ; absolute positioning; Z-Probe --------------------------------------------------------------------
M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
M557 X15:335 Y35:315 S10 ; define mesh grid
