Replaced old with new duet2 wifi, cant get nozzle heater working
@brian People are going to ask for your complete config.g as well as the results from M98 P"config.g" and M122
@alankilian ok here's the complete config.g;
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 11:48:28 GMT-0800 (Pacific Standard Time); General preferences
M550 P"Brian's Build 3" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation
M92 X320.00 Y320.00 Z2500.00 E420.00 ; set steps per mm
M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X430 Y410 Z650 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grida
M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
@brian It looks like you are currently missing all your heater definitions.
Maybe just a cut-n-paste error?
Also, click on the </> button and paste your config.g in there and it will look
like this!
@alankilian sorry, here's the M122
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S8-6JKF6-3S86R-1A7GL
Used output buffers: 3 of 24 (12 max)
Static ram: 23876
Dynamic ram: 74956 of which 176 recycled
Never used RAM 15408, free system stack 184 words
Tasks: NETWORK(ready,14.0%,229) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.9%,383) IDLE(ready,0.0%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:12 ago, cause: power up
Last software reset at 2022-02-02 11:23, reason: User, GCodes spinning, available RAM 12464, slot 2
Error status: 0x08
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 28.9, current 30.4, max 30.7
Supply voltage: min 11.2, current 11.5, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-02-02 12:09:14
Slowest loop: 4.30ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 200.14ms; fastest: 0.09ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.23
WiFi MAC address e0:98:06:22:8f:44
WiFi Vcc 3.43, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22920
WiFi IP address 192.168.1.67
WiFi signal strength -37dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
- WiFi -
@brian and the config.g again
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
@brian 2/2/2022, 12:14:04 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
@brian sorry , i dont follow this " click on the </> button and paste your config.g in there"
@brian I think you need to PID tune the heater. You have disabled bang bang mode but there are no PID parameters in your M307.
Edit. Unless you are using config-overide and have missed out the command to read those stored values (I'm using my phone but I think it's M501 that you need in config.g to read config-overide.g).
See at the top of the posting entry window where there are a bunch of symbols like:
Click the </> button and you'll get something in the posting entry window.
code_text
```Then if you replace the code_text with your config.g it will be formatted nicely.
Here's my config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 09 2021 13:21:24 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"alan" ; set printer name M665 R132.5 L291.06 B132.5 H400 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards ; Testing external driver ;M569 P5 S1 T4:4:4:4 ; physical drive 5 goes forwards ;M584 X0 Y1 Z2 E3 U5 ; set drive mapping ;M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation ;M92 X100.00 Y100.00 Z100.00 U100.00 E91.00 ; set steps per mm ;M566 X1200.00 Y1200.00 Z1200.00 U1200 E1200.00 ; set maximum instantaneous speed changes (mm/min) ;M203 X18000.00 Y18000.00 Z18000.00 U18000E1200.00 ; set maximum speeds (mm/min) ;M201 X1000.00 Y1000.00 Z1000.00 U1000E1000.00 ; set accelerations (mm/s^2) ;M906 X1000 Y1000 Z1000 E800 U1000I30 ; set motor currents (mA) and motor idle factor in per cent M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z100.00 E91.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop ; Z-Probe M558 P1 C"zprobe.in" H10 F3000 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height M557 R132 S40 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4385 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0.7 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M501 ; Load config-overrides.g ;T0 ; Select tool zero ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M912 P0 S3.5 ; MCU temperature calibration M591 D0 P3 C"e0_stop" S1 ; Configure filament monitor
After I boot, I can see the heaters like this:
If I click on Tool 0 and then enter a temperature, it starts to heat up like this:
What happens when you do that?
Are you selecting the tool first before trying to heat it?
Add
T0
to the end of your config.g to select the tool automatically at startup. -
@phaedrux No i was not selecting tool first. But now it is heating up when i send a print. However, now its not homing z properly. Have added the T0 at end, no result as yet.
@brian ok i see that i have to click the tool to make it active, who wouldnt thunk it?
@alankilian said in Replaced old with new duet2 wifi, cant get nozzle heater working:
config.g
config.g Thanks, found it.
@brian So this is now working.
Config.g ; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 14:20:11 GMT-0800 (Pacific Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Brian's Build 3" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation M92 X320.00 Y320.00 Z2500.00 E1050.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X430 Y410 Z650 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe M558 P1 C"zprobe.in+!pson" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z0.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Hot End" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M501 ; Load config-overrides.g ;T0
@brian thanks for everyone's help
