Home Y, and it moves X- with PI4 3.4b7+7
Duet 6hc w/1LC on a Pi4.
6HC:v3.4.0beta7+7
1LC:v3.4.0beta+4
DWC:3.4.0beta7Home Y: Expecting Y-, getting X-
Home X works fine.Moved the steppers to different drivers, no change. Original 0.0, 0.1. Tried 0.1,0.2 and 0.0,0.2. Full shutdown, reset, reload config.g, it doesn't change.
Set up in standalone mode and it works.
Made a new boot with buster and added RRF stuff and unstable, no change.
Set up in standalone mode again and it works.
Only change to config.g is to add the networking.It worked fine two days ago.
G1 H2 X10 F3000 moves X+ Y+
G1 H2 Y10 F3000 moves X+ Y-
Which are the correct directions.; homey.g ; called to home the Y axis ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-305 F6000 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 H1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CoreXY-MS" ; set printer name M669 S1 ; select CoreXY mode ; Drives M569 P0.0 S1 M569 P0.1 S0 M569 P0.3 S1 M569 P0.4 S1 M569 P0.5 S1 M569 P121.0 S1 ; physical drive 121.0 goes forwards M584 X0.0 Y0.1 Z0.3:0.4:0.5 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.0 Y80.0 Z800.0 E420.00 ; set steps per mm M566 X600.00 Y600.00 Z30.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y15000.00 Z250.00 E1200.00 ; set maximum speeds (mm/min) M201 X4000.00 Y4000.00 Z50.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-7 Y0 Z0 S1 ; set axis minima M208 X400 Y280 Z210 S0 ; set axis maxima ; Endstops M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 121.io1.in M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-30 Y0 Z0 ; set Z probe trigger value, offset and trigger height M557 X5:350 Y5:300 S40 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M376 H5 ; taper bed compensation M572 D0 S0.05 ; pressure advance M207 S1.5 F6000 R0 Z0.03 ; firmware retraction M143 H1 S300 ; set temperature limit for heater 1 to 300C ;M566 P1 ; Jerk policy, 1 allows jerk to be applied between any pair of moves. M912 P0 S-9 ; set mcu temp offset G10 P0 S0 R0 ; set T0 heater off M150 B0 U0 R0 P128 S10 F0 ; all neopixels off M912 P0 S4 ; calibrate MPU temp M955 P121.0 I10 ; Accelerometer on Toolboard 1LC 1.1 M593 P"ei2" F36.91 ; Configure Input Shaping M671 X200:280:20 Y290:380:20 S2.0 ; leadscrews at rear middle, front left and front right, correct up to 2mm if !exists(global.RunDaemon) global RunDaemon=true ; create variable for use in daemon.g else set global.RunDaemon=true ; reset variable for use in daemon.g if !exists(global.XHotendOffset) global XHotendOffset=-30 ; create variable for use in daemon.g else set global.XHotendOffset=-30 ; reset variable for use in daemon.g if !exists(global.YHotendOffset) global YHotendOffset=0 ; create variable for use in daemon.g else set global.YHotendOffset=0 ; reset variable for use in daemon.g M308 S10 Y"mcu-temp" P"121.dummy" A"1LC MCU" M308 S11 Y"drivers" P"121.dummy" A"1LC Stepper" M308 S12 Y"drivers" P"0.dummy" A"6HC Stepper" ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
undefined Phaedrux moved this topic from Using Duet Controllers
Can you try adding a G4 S4 delay to the start of your config.g to give the toolboard some time to start up?
Can you send M98 P"config.g" when in SBC move and report any errors?
If you step through the gcode commands from the homing files manually does it behave differently?
@phaedrux Added the G4. It used to be in there, looks like it took a vacation. No change.
In standalone, it works. It homes correctly.
Reattached PI4. Home Y, and it moved X-, nothing on Y.
PI4 is running off a Meanwell RS-15-5, along with a PI0 W for the webcam.
Ran each line in homey.g. G91 and the G1 H2 Z5 F6000 worked fine.
G1 H1 Y-305 moved X- and nothing on Y.
Sent G92 X0 Y0 in console.
In dashboard: Move X10, it move X + Y+. Y10 Y+ X-.
Sending those H2 test moves, it moves only once for each one now. Even after a emergency stop in DWC.Switched back to standalone, and it works. Y homes.
In dashboard: homes correctly and X and Y move as expected..What is the PI doing to mess that up? I thought the PI didn't affect the gcode.
Don't have another PI.
@stephen6309 Shouldn't:
have a K1 parameter to set the operating mode to CoreXY? At the moment you are just selecting the default cartesian kinematics with a segments per second parameter of 1. See: https://duet3d.dozuki.com/Wiki/M669
@gloomyandy @phaedrux
That fixed it. It works correctly in standalone mode with M669 S1, but not with the PI, strange. -
undefined Stephen6309 marked this topic as a question
undefined Stephen6309 has marked this topic as solved
