Solved FYSETC 12864
@oliof Hi, tried. Different screen and different board. Same result.....
@oliof said in FYSETC 12864:
@reefwarrior values of E1 to E4 (or E-1 to E-4) are expected and used. I have a FYSETC 12864 2.1 running on a Duet 3 mini 5+, with the following at the end of config.g
; enable display M918 P2 E-4 G4 S1 ; pause M918 P2 E-4 M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white
Also I get the M150 command not supported.
CONFIRM the FYSETC mini12864 V2.1 is supported on Duet2 Wifi?
@reefwarrior X2 is not a valid command for standard RRF and its only valid on the STM port of RRF. Use X1
@jay_s_uk Even die x1 causes it to complain about the command. Been an uphill battle to get this screen to work...
@reefwarrior which firmware version? I think neopixel support was only added to the duet 2 in recent beta builds
@jay_s_uk Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta2 (2021-03-10)
@reefwarrior yea, you need to update
@jay_s_uk cool. Any specific version? Or just the latest BETA?
@reefwarrior I would probably go 3.4b6 or 3.4b7+4 from here https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/18
@jay_s_uk Cool thanx, downloading and will give it a try!
@reefwarrior yep, you need the IAP from the 3.3 release. best to update to that first
@jay_s_uk cool
@jay_s_uk Thank you! Got it working 100%
Can you perhaps mark this post as SOLVED?
Click on the Topic Tools icon (the little gear) and select "ask as question". Then click on it again and select "mark as solved".
undefined Reefwarrior marked this topic as a question
undefined Reefwarrior has marked this topic as solved
