Hotend FAN1 stops running when Print starts
Since some hours try to figgure out what the faliure is i made
I'm using Cura and RFF3Here my Config...may someone can help me because I'm out of ideas.
Thanks a lot
; Heatbed
M143 H0 S110 ; set temperature limit for heater 0 to 110C; Hotend
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M308 S1 P"e1temp" Y"thermistor" T100000 B4100 ; define E0 temperature sensor
M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S0.85 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S351 ; set temperature limit for heater 1 to 300°C; Fans
M106 P0 C"PartCooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned on
M106 P1 C"HotendSink" S0.95 H-1 ; set fan 1 name and value. Thermostatic control is turned off
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 C"Elect" S0.85 H1 T30 ; set fan 2 name and value. Thermostatic control is turned on -
@topenga post your M563 line from your config
@topenga Best include your entire config.g, what do you have listed under M563? have you checked your wiring?
Thanks for that fast replay......hmmmm M563 is i guess the key?!?
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 05:49:28 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"Dan's WonderMachine" ; set printer name; Network
M551 P"1945" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 D2 S1 ; physical drive 1 goes forwards
M569 P1 D2 S1 ; physical drive 2 goes forwards
M569 P2 D2 S1 ; physical drive 3 goes forwards
M569 P3 D2 S0 ; physical drive 3 goes forwards
M350 X64 Y64 Z256 I1 ; configure microstepping wit interpolation
M350 E16 I0 ; configure microstepping wit interpolation
M92 X320.00 Y320.00 Z6400.00 E693.69435 ;set steps per mm
M566 X700.00 Y500.00 Z100.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min)
M201 X900.00 Y800.00 Z700.00 E600.00 ; set accelerations (mm/s^2)
M906 X2000 Y2000 Z600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X305 Y305 Z360 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; BLTouch
M950 S0 C"exp.heater3"
M558 P9 C"^zprobe.in" H2.5 F500:100 T12000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z3.35 P25 ; set Z probe trigger value, offset and trigger height
M557 X5:295 Y50:300 S29:25 ; define mesh grid; Heatbed
M106 P2 C"Elect" S0.85 H1 T30 ; set fan 2 name and value. Thermostatic control is turned on; Tools
M563 P0 S"0.4er Nozzle" D0 H1 F0:1 ; define tool 0
T0 ; select first tool7 -
@topenga and can you confirm that fans 0 and 1 are part cooling fans and fan 2 is your heatsink fan?
@jay_s_uk
Auch ..... No..... part cooling FAN0, Hotend FAN1: and electronic FAN2 -
@topenga then you have both your fans and M563 setup incorrectly.
You should haveM308 S2 Y"mcu-temp" A"MCU" ; configure sensor 2 as on-chip MCU temperature sensor
That monitors the MCU-Temp for the electronics fan. You could use something else for the electronics fan but thats a good shout.
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"PartCooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"HotendSink" S0.95 H1 T45 ; set fan 1 name and value. Thermostatic control is turned off M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 C"Elect" S0.85 H2 T30 ; set fan 2 name and value. Thermostatic control is turned on
That sets fan1 to come on when the heater comes on and fan2 to come on if the MCU temp is above 30 degrees (you may need to increase that value)
And then changeM563 P0 S"0.4er Nozzle" D0 H1 F0 ; define tool 0
i.e. remove the :1 from F0 as you only map non thermostatically controlled fans to a tool
Thanks a lot... Will fix this afternoon and have feedback
Best wishes
Danijel
@jay_s_uk said in Hotend FAN1 stops running when Print starts:
Hello jay_s_uk said,
thanks a lot....it works....I wonder how long it will take until I'm relly fit due to configuration knowledge!
Great Forum dute to very kind and supportive member!
Danijel
