rrf 3.4 beta update on ODROID sbc not possible
@pcr and apt update
@pcr said in rrf 3.4 beta update on ODROID sbc not possible:
@joeko can you post the output of apt upgrade
hmm, at the moment i dont use this combination but there are no error message. apt update show that the unstable list is loading and apt upgrade also that the duet files "hold back" i have all tried what i have found to fix that but always the same. but !! no problem with the stable rrf 3.3
but if you have an idea i try it again of course and post the output
Try unholding the packages:
# sudo apt-mark unhold \ duetsoftwareframework \ duetcontrolserver \ duetruntime \ duetsd \ duetsoftwareframework \ duettools \ duetwebcontrol \ duetwebserver \ reprapfirmware # sudo apt update # sudo apt upgrade
@nurgelrot said in rrf 3.4 beta update on ODROID sbc not possible:
i will do it
do you use your odroid c4 with the latest beta ?
if so, which os and did you do this on this way ? -
here the apt-update and upgrade
OK:1 http://ppa.launchpad.net/hardkernel/ppa/ubuntu bionic InRelease OK:2 http://archive.canonical.com/ubuntu focal InRelease OK:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease OK:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease OK:5 https://pkg.duet3d.com unstable InRelease OK:6 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease OK:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease Holen:8 http://deb.odroid.in/c4 focal InRelease [1.697 B] Es wurden 1.697 B in 2 s geholt (733 B/s). Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Aktualisierung für 8 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
and upgrade
sudo apt upgrade Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Fertig Die folgenden Pakete sind zurückgehalten worden: duetcontrolserver duetpluginservice duetruntime duettools duetwebcontrol duetwebserver reprapfirmware 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
but apt list --upgradable
apt list --upgradable Listing... Done duetcontrolserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] duetpluginservice/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] duetruntime/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] duetsoftwareframework/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] duettools/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] duetwebcontrol/unstable 3.4-b5 all [upgradable from: 3.3.0] duetwebserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0] reprapfirmware/unstable 3.4-b6-1 all [upgradable from: 3.3.0-1]
is there a mix of beta version and make the problem ?
thank you but the same like before. still hold back and update not possible. please look at my post one back
@joeko said in rrf 3.4 beta update on ODROID sbc not possible:
Have to tried to upgrade to beta5 first, and if successful, go for beta6?
@o_lampe said in rrf 3.4 beta update on ODROID sbc not possible:
no, fresh and new install this morning on duet3 mini.
first with rf 3.3 (all fine) and update to the beta -
hmm, if didnt try it but if possible i will.
but how i can do this ? as far as i know i can only update to the latest beta. -
@joeko So is this issue solved? I'm on 3.4 beta6 on both a Duet3d mini5 and a BTT GTR board using the STM32 port of RRF.
using Armbian (debian 10.11 aka buster)
no way, always the same.
updates hold back and it seems that the betas are mixed....
witch gpiochip and pinnumber did you set in the json ?witch way you have used for install, first stable and than beta ?
@joeko I'm always following unstable on these so I went from 3.4 Beta somthing to Beta 6
I did have an issue with the STM32 version not patching right away it complained about a dependency problem with duetsoftwareframework requiring <= reprapfirmware 3.4-b5-999. I removed all the duet packages and reinstalled latest unstable and it worked.
My transfer pin is 67 on /dev/gpiochip0. But these are different on different versions of linux on the odroid C4. I remember that the ubuntu version shipped with the Odroid had it at pin 68 on chip1
if any version is installed but nothing is running (or you have shut it down) try running:
sudo /opt/dsf/bin/DuetControlServer -ud
that will produce errors on screen if you have any sort of communication problem. ^D or ^C to exit.
with armbian buster it works. i also did it with buster from hardkernel (meveric from forum) but this was not possible. now it works.sudo /opt/dsf/bin/DuetControlServer -ud
give me
Duet Control Server v3.4-b6 Written by Christian Hammacher for Duet3D Licensed under the terms of the GNU Public License Version 3 [info] Settings loaded [fatal] Another instance is already running. Stopping.
i think that is ok because it is running
thank you for your help
@chrishamm
it would make it easier when it offer the choice to modify the json for the tfr pin while the installation...much easier. -
@joeko I've updated our DSF on armbian instructions here
https://teamgloomy.github.io/dsf_on_armbian.html -
@joeko Yes a opportunity to override the default pin locations in the post-install script would be very handy. Also when you upgrade make sure you do not override your existing config.json. I've done that a couple times now getting annoying
@jay_s_uk said in rrf 3.4 beta update on ODROID sbc not possible:
https://teamgloomy.github.io/dsf_on_armbian.htmlfirst i have used armbian buster with kernel 4.9. with that version i got boot problems. after change to buster with kernel 5.1 is this gone. i spend many hours to fix that.....
do i realy set
Then you have to add the following lines in /boot/armbianEnv.txt : extraargs=apparmor=1 security=apparmor
because here is it also possible without this.
@joeko if you want to use 3rd party plugins (and the duetpimanagement plugin), then yes, you need apparmor installed
installed yes but also ?
i have it installed and running but i am not sure if this is needed. here is it running without
@joeko check with sudo aa-status, it'll tell you if its running.
I had to add it on the armbian build i'm using though as I don't think its installed by default -
apparmor module is loaded. 9 profiles are loaded. 9 profiles are in enforce mode. /opt/dsf/plugins/EndstopsMonitor/** /opt/dsf/plugins/InputShaping/** /usr/bin/man /usr/sbin/chronyd /usr/sbin/haveged man_filter man_groff nvidia_modprobe nvidia_modprobe//kmod 0 profiles are in complain mode. 2 processes have profiles defined. 2 processes are in enforce mode. /usr/sbin/chronyd (2569) /usr/sbin/chronyd (2570) 0 processes are in complain mode. 0 processes are unconfined but have a profile defined.
looks good ?
