Z AXES DOUBLE SETUP
Hi every one I' want remind the procedure that I used for understanding missing steps (if there are).
- M584 X0.0 Y0.0 Z0.2:0.4 E0.3
"for selecting the 2 and 3 driver for the z axes". - M574 Z1 S1 P"io3.in"
"for selecting the microswitch z for the two motors"
Can I have a confirmation by someone that is better then me with the duet mini 5 plus?
Is there anything that should I change ? I ' m setting up a Prusa i3 modified.
regards
Giuseppe - M584 X0.0 Y0.0 Z0.2:0.4 E0.3
@giuseprap said in Z AXES DOUBLE SETUP:
"for selecting the microswitch z for the two motors"You have used output zero twice, I suspect Y should be 0.1
For two motors with separate limits, you need two inputs?
This is what I have (on a Duet 6HC):M574 Z1 S1 P"io3.in+io4.in" ; configure active-high endstop for low end on Z via pin io3.in
