Fan stopped during M303, doesn't restart
Did it pop at the effector or at the Duet board?
Has to be at the main board, none of the fans are working on any port
ok, always on fans work, and fan 0 works, fan 1 does not and fan 2 I can't seem to test even though I enabled in the config there is no slider for it in the DWC
In settings you can find a place to allow fan 2 slider to show.
where at, I have all three listed in there
If you tried all three, then that is it.
found it, Doh!
all fans terminal work except for F1. I'm leery of just putting it on a different one until I know why it happened to start with. need to track this down.
Does it look like it blew the mofset on the duet?
Yeah thats it, I think I found a replacement but small electrics aren't my thing.
https://www.digikey.com/product-detail/en/nexperia-usa-inc/PMV40UN2R/1727-1900-1-ND/5056345
