Mini 5 IP 10.0.0.14
How do I get rid of this IP 10.0.0.14?? Should and have been 192.168.1.xxx
Found the solution, I parameter is poorly documented.
@tecno please let me know what would make the documentation clearer.
I think it was in getting started with WiFi the I is mentioned but no explanation
@tecno The M587 I parameter is mentioned here https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s50 with a link to M587 in the Gcode dictionary straight after:
If you have a Duet 2 WiFi or Duet 3 Mini 5+ WiFi, this is sufficient to enable networking and let your network router assign an IP address via DHCP. If you need to assign a static IP address, use M587 with the I parameter when setting up the SSID in Step 9. See M587 in the G-code dictionary.
I guess you had set this before with M587 ... I10.0.0.14 ? Sending M587 on it's own lists the saved SSIDs, including any fixed IP address. Unfortunately the Guide format doesn't give much space for a long explanation of this, and it is covered in the Gcode dictionary, so I'm not planning any changes.
