Prusa new kitchen sink XL printer
3dprintingnerd has a video on YouTube that shows the bed a bit better. It's basically individual pcb heaters with their own thermistors hooked up to a central "hub" that's under the bed. It also allowed things like segmented heating, hotspot measurement and compensation and heating only specific areas of the bed.
It's a pretty neat concept, albeit a complex one.
@roiki11 Too complex if you ask me. Imagine having to troubleshoot and maintain 16 heaters and thermistors. It's also 16 potential fire sources. They should have gone with max 4.
@techni said in Prusa new kitchen sink XL printer:
Well, at least they didn't include a per segment independent leveling.
Reminds me of this Unnecessary Invention https://youtu.be/NvyMAfeoDOs?t=268
@o_lampe said in Prusa new kitchen sink XL printer:
The heatsink with inbuild load cell falls in the same category. Strain gauge and Piezo sensors were already there, something different had to be made...
A load cell is a device based on a strain gauge, isn't it? I'm not sure that a strain gauge can be used without mounting it onto a load cell of some sort...
@jens55 said in Prusa new kitchen sink XL printer:
How do individual heaters help if the bed is a big heat conductor unless it is fairly thin?
It is fairly thin. The video shows very clearly that the ordinary magnetic flexible bed goes onto the heater panels. It's thin.
@deckingman said in Prusa new kitchen sink XL printer:
The real reason for that is to save Prusa the cost of a switch and an bit of wire on all their machines
I think that you're being unnecessarily grumpy.
A simple switch is simple, sure, but it is likely much cheaper than a load cell. The load cell arrangement measures (analog) more and different than a switch. For example, Prusa says that the load cell allows them to detect changes in the extrusion pressure and thus they expect to be able to not only detect clogs, but to detect them in advance.
Surely the software will be able to report any problems with individual heaters and sensors and so troubleshooting will not be difficult.
I have not had any problem with a bed heater or sensor on my 8 year old printer, or on my one year old printer. Are they common on a printer with proper wire strain control?
@mjlew said in Prusa new kitchen sink XL printer:
True - but at my age, I'm entitled to be grumpy
You are conflating two different things by selectively snipping a part of my post to try and make it appear that I said something that I did not. I made no mention of load cells, nor did I make any mention of extruders, extrusion pressure, or anything related to the extrusion system. What I did say was quote ......(the important words that you omitted are in bold)
" Just like sensor less homing. The real reason for that is to save Prusa the cost of a switch and an bit of wire on all their machines."
Sensor less homing is exactly that - it uses no sensors - load cells or otherwise for homing the printer. Given that sensor less homing relies on motor stall detection, which can be affected by temperature and other factors, I stand by my comment that it will never be as reliable or repeatable as a simple switch and so the only reason why one would want to use it is to save cost ( and a small cost at that).
@deckingman OK, I see that now. Sorry.
Your post was just saying in general that Prusa gets more kudos than they may deserve, whereas I read it as if it was saying something specific about the new printer.
There is a great documentary on this topic: https://www.imdb.com/title/tt0107050/
@hackinistrator said in Prusa new kitchen sink XL printer:
I agree that 2 idler wheels will probably cause issues with flexible filaments , maybe there is something i don't see
The idler wheels should be coupled by gears for flexible filament, but it would require a third gear to make them run in the same direction.
See the Duet3d Smart Effector, it has a strain gauge built into the PCB. Sadly, they never made an inline version to mount it between extruder and heatsink.
This post is deleted! -
@o_lampe see the Creality CR-6SE which has a loadcell integrated. So even if you're looking at consumer printers, this is hardly innovation.
@arnold_r_clark said in Prusa new kitchen sink XL printer:
Messer Prusa is not the messiah.
Good to know. Thanks.
