output problem
Hello
I have a problem with my duet 3...
I can't turn on any output with M42 or for my heaters...
FYI This is the first use of the board. And for the first test I'have just connect motor and end-stop heaters and temp
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.0beta5 (2021-10-12 13:53:56) running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-9P63L-DJMSS-6J9D6-3SN6S-KUHZB
Used output buffers: 3 of 40 (20 max)
Static ram: 151104
Dynamic ram: 96916 of which 44 recycled
Never used RAM 102608, free system stack 206 words
Tasks: NETWORK(ready,21.0%,211) ETHERNET(notifyWait,0.1%,183) HEAT(notifyWait,0.0%,347) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,92) MAIN(running,54.6%,1095) IDLE(ready,16.1%,30), total 100.0%
Owned mutexes:
Last reset 00:01:51 ago, cause: reset button
Last software reset at 2021-10-18 17:33, reason: User, GCodes spinning, available RAM 103116, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Step timer max interval 129
MCU temperature: min 42.5, current 46.2, max 46.3
Supply voltage: min 25.7, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
Driver 0: pos 0, standstill, SG min/max 0/0, reads 30865, writes 16 timeouts 0
Driver 1: pos 0, standstill, SG min/max 0/0, reads 30867, writes 14 timeouts 0
Driver 2: pos 0, standstill, SG min/max 0/0, reads 30867, writes 14 timeouts 0
Driver 3: pos 0, standstill, SG min/max 0/0, reads 30867, writes 14 timeouts 0
Driver 4: pos 0, standstill, SG min/max 0/0, reads 30868, writes 14 timeouts 0
Driver 5: pos 0, standstill, SG min/max 0/0, reads 30871, writes 11 timeouts 0
Date/time: 2021-10-18 17:38:38
Slowest loop: 7.25ms; fastest: 0.05ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 932, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 48), ts 557/0/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 11.54ms; fastest: 0.02ms
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 1 0 0
- Ethernet -
@tom33 post your config.g and some more information about whats connected where
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.4 on Wed Oct 13 2021 14:06:51 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"ISA" ; set printer name; Network
M552 P192.168.1.70 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; physical drive 0.0 goes forwards
M569 P1 S0 ; physical drive 0.1 goes forwards
M569 P2 S1 ; physical drive 0.1 goes forwards
M569 P3 S1 ; physical drive 0.3 goes forwards
M569 P4 S1 ; physical drive 0.1 goes forwards
M569 P5 S1 ; physical drive 0.5 goes forwards
;M569.7 P3 C"out8" ; driver 0 on board 40 uses port out1 on board 40 to control the brakeM584 X0 Y1:2 V2 Z3 W4 E5 ; set drive mapping M584 X0.0 Y0.1:0.2 V0.2 Z0.3:0.4 W0.4 E0.5
M350 X16 Y16 V16 Z16 W16 E16 I1 ; configure microstepping with interpolation
M92 X320.00 Y640.00 V640.00 Z640.00 W640.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 V900.00 Z60.00 W60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 V6000.00 Z180.00 W180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 V500.00 Z20.00 W20.00 E250.00 ; set accelerations (mm/s^2)
M906 X2800 Y2800 V2800 Z2800 W2800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X1000 Y500 Z400 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
M574 Y2 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
M574 Z2 S1 P"!io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in; Z-Probe
M558 P5 C"!io4.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X15:950 Y15:450 S50 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out3" T0 ; create bed heater output on out0 and map it to sensor 0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M563 P0 S"E0" D0 H1 F0 ; define tool 0
;Input
M950 J0 C"io0.in" ; Arret d'urgence
M581 T0 P0 S1 R0 ; T0 --> M112 Arret d'urgenceM950 P0 C"out8"
M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
;T0 ; select first tool -
@tom33 what commands are you sending that do not work?
@tom33 which LED? please show how you are wiring it.
@t3p3tony this led
When I turn on the output nothing append
@tom33 if you have nothing connected it won't turn on
@jay_s_uk even if nothing is wired the led turned on, I tried with another duet 3 and the same config
@tom33 Thanks, no I understand what you mean. Just to make 1005 sure we are on the same page, you can't control a heater with M42 if you have already mapped it to a heater. Can you send the following (with nothing plugged into out2 and out2 not used in the config.g
M950 P20 C"out2" M42 P20 S1 ; LED on out 2 should come on M42 P20 S0 ; LED on out 2 should go off
@t3p3tony said in output problem:
M950 P20 C"out2"
I tried and nothing append, the problem is just with the output because I can run the motor for exemple...
@tom33 thanks for confirming that. It looks like this impacts multiple outputs. Can you test Out0 to see if the LED lights on that please.
@t3p3tony The same with out0. I think the problem come from the board because I tried the same config.g in another duet3 3
@tom33 thanks for bearing with the testing. please can you contact warrant@duet3d.com to initiate a warranty return, referencing this forum post.
