Just for fun why did I buy this?
@fcwilt hmmmm. probing is a vague term. I hope you're not thinking of placing anything in any dark places.
@bot said in Just for fun why did I buy this?:
Nope - nothing like that - but was not your first word "probing"? The second item mentioned as tool alignment using a camera.
Did I misunderstand your post?
@fcwilt said in Just for fun why did I buy this?:
OK, it is used to move something out of the way so when printing no print area is lost but still allows the something to perform it's intended purpose.
My answer below, encrypted with Google translate
Brosse de nettoyage de buse
Pebble wiper setup
@zapta said in Just for fun why did I buy this?:
I like that I idea - I may just try that as well.
@jens55 said in Just for fun why did I buy this?:
Pebble wiper setup
What is a "pebble wiper"?
@fcwilt, a device for cleaning printing nozzles. The purged filament is formed into a pebble for easy separation from the nozzle (no curling around of loose filament), disconnected from the nozzle and then wiped away to ready for the next purge operation. In the context of a tool changing printer, the height of the wiper assembly is adjusted based on the tool being purged which is why you have a very short reach adjustable stage.
Interesting.
How is the filament formed into a "pebble"?
@fcwilt, it is extruded onto a flat surface just underneath the extruder
https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193 -
https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193Well the link is interesting because it is also a clue to what I am experimenting with.
@fcwilt A cheaper, mechanical way of doing things
https://www.bigbrain3d.com/product/retractable-purge-mechanism/ -
@yveske said in Just for fun why did I buy this?:
https://www.bigbrain3d.com/product/retractable-purge-mechanism/That is rather neat.
Well I finished the first experimental setup and it is working, although with a limitation I believe is related to the 12 volt power supplies I used on this printer.
I will make a quick video Wednesday and post a link to it here.
Here is a link to a quick-and-dirty video showing the mini linear guide at work.
It was hard to get a good view - sorry.
