Unreliable Z height calibration on V-Core 3 w/BLtouch & Mini 5+
Sorry for the delay, I did a lot of tests! After applying all the tweaks you gave me the Z height improved a lot, I have a new printer!
There is just one specific and persistent issue which is only present after powering on the printer.
Its behaviour is the following:
- The printer is already calibrated and all previous prints were perfectly fine.
- Power off and power on the printer
- I try to print anything and the first layer is much more closer to the bed that usual.
- Cancel that print (Emergency stop on DWC) and clean the bed
- so I print again the same file without touching any setting and now the first layer is perfect again.... (and of course I can continue printing without issues)
What I am missing?
Thanks a lot for all the help!
Julián. -
Well clearly something is being done under those circumstances that is not being done on power up and thus some setting is not getting set correctly.
Do you have any of the following files in your Sys folder:
- cancel.g
- pause.g
- stop.g
If you do please post them here using the </> tag.
Thank you very much Frederick!
No, I don't have any of these files in my system folder.
Julián.
@juliann said in Unreliable Z height calibration on V-Core 3 w/BLtouch & Mini 5+:
Julián.
Hmm...
I don't know all the "side effects" of hitting "Emergency Stop".
It's possible that, in the code executed at the start of a print, the order of execution is incorrect.
Here is a very simple, artificial example of what I am getting at using just two commands:
M703 T0
The command M703 will fail if a tool is not selected but the tool is not selected by the T0 command until after the M703 command has already failed.
If I execute that same pair of commands a second time the M703 will work since the tool is now selected.
So if you could post the first 20 lines or so of a file that doesn't print after power on but prints the second time perhaps we can see something.
Hi Frederick,
This is a fragment of the file I am printing today, of course the behaviour is still the same, after cancelling the first try now it is printing perfectly.
About M703 and T0, I executed them but I didn't get any event or error.
Thanks again!
Julián.; ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.42mm ; solid infill extrusion width = 0.42mm ; top infill extrusion width = 0.40mm ; first layer extrusion width = 0.42mm M140 S80 ; set bed temperature G10 P0 R265 ; sets the standby temperature G10 P0 S267 ; set temperature ;TYPE:Custom G28 ; home all axes G1 Z5 F5000 ; lift nozzle M107 G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; Filament gcode G1 X250 Y250 G30 M290 R0 S-0.12 G29 S1 G10 P0 S267 ; set temperature M116 ; wait for temperature to be reached M190 S80 ; set bed temperature and wait for it to be reached M107 ;LAYER_CHANGE ;Z:0.25 ;HEIGHT:0.25 ; 0.2mm layer, 8 bands 5mm each, total height 40mm ; G1 Z0.25 F18000 G1 E-0.3 F3600 G1 X225.081 Y213.029 F18000 G1 E0 F3000 ;TYPE:Skirt ;WIDTH:0.42 G1 F600 G1 X226.211 Y211.864 E0.05129 G1 X226.84 Y211.385 E0.07628 G1 X227.733 Y210.982 E0.10725 G1 X228.699 Y210.814 E0.13823 G1 X271.124 Y210.809 E1.47905 G1 X271.771 Y210.864 E1.49958 G1 X272.401 Y211.025 E1.52011
I didn't mean for you to do anything with the T0 and M703 commands, it was just to illustrate that the order of code can lead to things failing the first time but working after that.
Thanks for the code you posted.
Since that code executed G28 could you post your homeall.g file.
Where did the setup code (the code before the layer change comment) come from? It's a bit unusual.
That code also includes a M290 to set baby-stepping. What is that there?
Oh I got it, sorry, I am still in the beginner area of 3d printing
Superslicer Filament start and end gcodes:
Superslicer end gcode
; Filament-specific end gcode ;END gcode for filament
Superslicer Printer Custom gcodes:
Start gcode
End gcode
M104 S0 ; turn off temperature M140 S0 ; turn off bed G28 X0 ; home X axis M84 ; disable motors M999
As I can't find all other commands on the settings pages of the SuperSlicer 2.3.57, honestly I am not sure if they were generated by the slicer itself.
homeall.g
; BLTouch ;M280 P0 S160 ; Precautionary alarm release M280 P0 S160 ; Ensure the pin is raised G91 ; relative positioning G1 H2 Z10 F6000 ; lift Z relative to current position ;G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-505 Y505 F3600 ; move quickly to X and U axis endstops and stop there (first pass) G1 H1 X-505 F1800 ; move quickly to X and U axis endstops and stop there (first pass) G1 H1 Y505 F1800 ; move quickly to X and U axis endstops and stop there (first pass) ;G1 H2 X5 Y-5 F6000 ; go back a few mm G1 H1 X-505 Y505 F360 ; move slowly to X and U axis endstops once more (second pass) G1 H1 X-505 F360 ; move slowly to X and U axis endstops once more (second pass) G1 H1 Y505 F360 ; move slowly to X and U axis endstops once more (second pass) G90 ; absolute positioning G1 X250 Y250 F10000 ; go to first probe point G30 ; home Z by probing the bed G91 ; relative positioning G1 Z10 F1800 ; lift Z relative to current position G90 ; absolute positioning G1 X0 Y35 F10000 ;G29 S1
Thank you very much!
Julián. -
Now I am even more confused.
Where did that code come from? Did you create it yourself?
You mentioned different sections of SuperSlicer code. Did you decide what code went into what section?
The code in the Filament Start and Start sections doesn't seem right.
This is what I think your homeall.g file should look like but it's hard to be sure as what you posted was a mixture of approaches to homing.
M402 ; Ensure pin is raised - when you use M402 the firmware knows the pin should be raised G91 ; relative positioning G1 H2 Z10 F6000 ; lift Z relative to current position G1 H1 X-505 F1800 ; move to X endstop (fast) G1 X5 ; backup a bit G1 H1 X-10 F360 ; move to X endstop (slow) G1 H1 Y505 F1800 ; move to Y endstop (fast) G1 Y-5 ; backup a bit G1 H1 Y10 F360 ; move to Y endstop (slow) G90 ; absolute positioning G1 X250 Y250 F10000 ; move probe to XY position for probing G30 ; home Z by probing the bed G1 Z10 F1800 ; move Z to "done homing" position G1 X0 Y35 F10000 ; move X and Y to "done homing" positions
Thank you @fcwilt
All slicer configurations were created based on findings that I came across on forums and Internet, I mean, they are there just by doing copy and paste...
Where should I start fixing or organising it?
Thank you @fcwilt
I'm about to have lunch. So give me a bit of time and I will create some basic code you can put into the slicer as a starting point.
Thank you so much Frederick for taking the time, please enjoy your lunch
There has been a bit of disruption of my work as the local authorities have been out and about near my home looking for a missing person. They asked if I would review my security camera recordings to see if anything was picked up.
They are gone now and I am back to work.
Sorry for the delay.
I installed SuperSlicer and had it slice a simple cube object so I could set what code it generated with default settings.
I have posted the code below with all generated "junk" removed.
; SuperSlicer print start code using RepRap setting M140 S60 ; set bed temperature G10 P0 R190 ; sets the standby temperature G10 P0 S190 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle *** THE POSITIONING MODE (absolute or relative) IS NOT KNOWN *** M107 ; disable fan G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion G10 P0 S190 ; set temperature M116 ; wait for temperature to be reached M190 S60 ; set bed temperature and wait for it to be reached M107 ; disable fan
; SuperSlicer print end code using RepRap setting M486 S-1 ; object cancelation M107 ; disable fan M104 S0 ; turn off temperature G28 X0 ; home X axis M84 ; disable motors
With the updated homeall.g file I posted earlier this SuperSlicer generated code is basically OK and should work - although it does have a a minor flaw or two.
So I would update your homeall.g file and make sure it works.
Then slice a simple file and see if the start/end code matches what I posted here.
If it does try to print with it.
Hi Frederick @fcwilt
No problem at all, thanks again for taking all this time helping me.
I am checking and updating all the settings following your instructions and I will try another print. I will let you know the results tomorrow for sure.
Julián. -
Hi Frederick
Sorry for the delay, but the tests didn't result very well, basically I am getting a similar issues.
Just to re-confirm: have I to remove the previous start/ end code on the slicer?So the right configuration should be based on a combination between homeall.g and the slicer settings?
Thank you very much
Julián. -
Hi Frederick
Thank you very much
Julián.Aside from the homeall.g file I posted the other code was generated by SuperSlicer. I posted here as it was other than removing lines that were just comments.
The file you are trying to print should have code that looked like what I posted.
Please post as before up until "layer 1" starts.
@juliann you have too many balls in the air. rule one of diganostics and trouble shooting is simplify.
from your your bedmap, i suspect that your rails are not in alignment- i think that your back right (Xmax,Ymax) rail is HIGH. It appears high in the map because the Z is inverted. re-read the v-core docs on rail alignment and see if its right. if we know that its off, we can take that into account.
In your start gode, you are settin z-o, then adjusting the nozzle -0.12mm realtive, then mesh the bed?? what is the purpose of that?
M290 R0 S-0.12
in the fragment of what you were printing, you had a standby temp of 265 and print temp of 267. What are you printing with? -
Consider tramming you bed with 4 points, not 3. save your beg.g and make a SIMPLER one. you have to crawl before you can run. once you see this works, then go back and add in the iteration stuff if yo want it. i dont think you do if you have a quality bed that is made well.
bed.g-
M290 R0 S0 ; clear baby stepping M561 ; reset all bed adjustments M400 ; flush move queue if !move.axes[0].homed or !move.axes[1].homed or !move.axes[2].homed echo "not all axes homed, homing axes first" G28 G30 X250 Y250 ; set middle of bed G30 P0 X10 Y10 Z-99999 ; Front Left G30 P1 X10 Y470 Z -9999 ; BL G30 P2 X460 Y470 Z-99999 ; BR G30 P3 X460 Y10 Z-99999 S3 ; FR autolevel 3 screws G30 X250 Y250 ; reprobe middle of bed in case it shifted
prove to yourself that it level - move Z to a height you can check you nozzle with a feeler gauge of some kind. paper, cardboard, anything. jog the nozzle till you can just feel it dragging on the feeler and move the head around. you can use a M18 X Y to disable the steppers but keep power to the Z motors.
print something WITHOUT the heightmap, only bed tram. this want to be like 4 squares, 1 layer thick, 50x50 x0.3mm high, one at each corner and one in the middle.
Aftter you print something w/o heightmap, THEN perform a height map and reprint.
if you want to slice a simple cube in superslicer and save the config bundle, you should be able to zip it and attach to this thread. those of us who use super slicer can open it and see exactly what is in there for gcodes and settings.
sinneD
Hi Frederick & sinneD & @T3P3Tony @fcwilt @sinned6915
Sorry for the delay in my response.
I rechecked everything in my printer included mechanical and the frame assembly as well.
Everything seems to be fine, no issues found.Frederick @fcwilt
I did several tests following your instructions but I am afraid the behaviour is always de same I described before:- The printer is already calibrated and all previous prints were perfectly fine.
- Power off and power on the printer.
- Then I print again the same file without touching any setting and now the first layer is perfect again.... (and of course I can continue printing without issues).
I am attaching "30 mm cube.gcode " file.
@sinned6915
Thank you very much for taking the time analysing my problem. Please see below my answers-
After rechecking the frame, belts, carriage many times I can confirm you that there is no problem there.
Just to clarify, I think the issue I am experiencing is not precisely what you are suggesting, please see the behaviour I mentioned before.
I mean, I am able to get perfectly fine prints, first layer included but always considering the behaviour/ issue I previously described. -
To be honest, it is probably inexperience from my side :-)... I am still new in 3d printing and many of my settings are there just for someone's advice.
If you know a better way to do that I will appreciate if you share it with me.
I am printing PETG-CF, that temp is working very well to me. -
Done! thanks so much for this, it seems to be better now.
I did that but the results are conditioned by the behaviour I described before.
After powering on the printer the nozzle is very close to the bed, so if I do this test I probably scratch the bed.
but...
if I press emergency stop then the test result is perfectly fine (and of course any print I do) -
I did it, same results as response 4.
Pressing emergency stop after powering on and then printing w/o heightmap I got the expected results based on the height map showed in DWC.
If I don't press the emergency stop after power on, the nozzle is too close to the bed (with or without heightmap).
If press emergency stop and then I print with the heightmap the print is perfectly fine. -
SuperSlicer_config_bundle.ini & 30 mm cube.gcode
[print:JEN 0.4 PETG Filamentive Carbon F] allow_empty_layers = 0 avoid_crossing_not_first_layer = 1 avoid_crossing_perimeters = 1 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = rectilinear bottom_solid_layers = 6 bottom_solid_min_thickness = 0 bridge_acceleration = 0 bridge_angle = 0 bridge_flow_ratio = 60% bridge_overlap = 145% bridge_speed = 15 bridge_speed_internal = 15 bridged_infill_margin = 200% brim_ears = 0 brim_ears_detection_length = 1 brim_ears_max_angle = 125 brim_ears_pattern = concentric brim_inside_holes = 0 brim_offset = 0 brim_width = 0 brim_width_interior = 0 clip_multipart_objects = 0 compatible_printers = compatible_printers_condition = complete_objects = 1 complete_objects_one_brim = 0 complete_objects_one_skirt = 1 complete_objects_sort = object curve_smoothing_angle_concave = 0 curve_smoothing_angle_convex = 0 curve_smoothing_cutoff_dist = 2 curve_smoothing_precision = 0 default_acceleration = 0 dont_support_bridges = 1 draft_shield = 0 duplicate_distance = 6 enforce_full_fill_volume = 1 ensure_vertical_shell_thickness = 0 exact_last_layer_height = 0 external_infill_margin = 150% external_perimeter_cut_corners = 0% external_perimeter_extrusion_spacing = external_perimeter_extrusion_width = 0.45 external_perimeter_overlap = 100% external_perimeter_speed = 50% external_perimeters_first = 0 external_perimeters_hole = 1 external_perimeters_nothole = 1 external_perimeters_vase = 0 extra_perimeters = 1 extra_perimeters_odd_layers = 0 extra_perimeters_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_spacing = extrusion_width = 0.45 fill_angle = 45 fill_angle_increment = 0 fill_density = 0% fill_pattern = gyroid fill_smooth_distribution = 10% fill_smooth_width = 50% fill_top_flow_ratio = 125% first_layer_acceleration = 0 first_layer_extrusion_spacing = first_layer_extrusion_width = 0.42 first_layer_flow_ratio = 100% first_layer_height = 0.25 first_layer_infill_speed = 15 first_layer_min_speed = 0 first_layer_size_compensation = -0.2 first_layer_size_compensation_layers = 1 first_layer_speed = 10 gap_fill = 1 gap_fill_last = 1 gap_fill_min_area = 25% gap_fill_overlap = 100% gap_fill_speed = 20 gcode_comments = 0 gcode_label_objects = 0 hole_size_compensation = 0 hole_size_threshold = 100 hole_to_polyhole = 0 hole_to_polyhole_threshold = 0.01 hole_to_polyhole_twisted = 1 infill_acceleration = 0 infill_anchor = 600% infill_anchor_max = 50 infill_connection = connected infill_connection_bottom = connected infill_connection_solid = connected infill_connection_top = connected infill_dense = 1 infill_dense_algo = enlarged infill_every_layers = 1 infill_extruder = 1 infill_extrusion_spacing = infill_extrusion_width = 0.42 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 35% infill_speed = 20 inherits = interface_shells = 0 ironing = 0 ironing_angle = -1 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.2 max_print_speed = 20 max_volumetric_speed = 0 milling_after_z = 200% milling_extra_size = 150% milling_post_process = 0 milling_speed = 30 min_skirt_length = 20 min_width_top_surface = 100% model_precision = 0.0001 no_perimeter_unsupported_algo = none notes = only_one_perimeter_first_layer = 0 only_one_perimeter_top = 1 only_one_perimeter_top_other_algo = 0 only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode over_bridge_flow_ratio = 125% overhangs_reverse = 0 overhangs_reverse_threshold = 250% overhangs_speed = 10 overhangs_width = 50% overhangs_width_speed = 1% perimeter_acceleration = 0 perimeter_bonding = 0% perimeter_extruder = 1 perimeter_extrusion_spacing = perimeter_extrusion_width = 0.45 perimeter_loop = 0 perimeter_loop_seam = rear perimeter_overlap = 100% perimeter_round_corners = 0 perimeter_speed = 20 perimeters = 3 post_process = print_extrusion_multiplier = 100% print_retract_length = -1 print_retract_lift = -1 print_settings_id = print_temperature = 0 raft_layers = 0 resolution = 0.002 seam_angle_cost = 100% seam_position = aligned seam_travel_cost = 100% single_extruder_multi_material_priming = 1 skirt_brim = 0 skirt_distance = 3 skirt_distance_from_brim = 1 skirt_extrusion_width = 0 skirt_height = 1 skirts = 2 slice_closing_radius = 0.049 small_perimeter_max_length = 20 small_perimeter_min_length = 10 small_perimeter_speed = 15 solid_fill_pattern = rectilineargapfill solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_spacing = solid_infill_extrusion_width = 0.42 solid_infill_speed = 20 solid_over_perimeters = 2 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_auto = 1 support_material_buildplate_only = 1 support_material_contact_distance_bottom = 0.2 support_material_contact_distance_top = 0.2 support_material_contact_distance_type = plane support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.35 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear support_material_solid_first_layer = 0 support_material_spacing = 2.5 support_material_speed = 15 support_material_synchronize_layers = 0 support_material_threshold = 0 support_material_with_sheath = 1 support_material_xy_spacing = 50% thin_perimeters = 1 thin_perimeters_all = 0 thin_walls = 0 thin_walls_merge = 1 thin_walls_min_width = 33% thin_walls_overlap = 50% thin_walls_speed = 10 threads = 8 top_fill_pattern = monotonic top_infill_extrusion_spacing = top_infill_extrusion_width = 0.4 top_solid_infill_speed = 20 top_solid_layers = 6 top_solid_min_thickness = 0 travel_acceleration = 1500 travel_speed = 300 travel_speed_z = 0 wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim = 150% wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_inner_size_compensation = 0 xy_size_compensation = 0 [filament:V-CORE 3 Carbon F] bed_temperature = 80 bridge_fan_speed = 100 bridge_internal_fan_speed = -1 chamber_temperature = 0 compatible_printers = compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 1 end_filament_gcode = "" external_perimeter_fan_speed = 20 extrusion_multiplier = 0.81 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #29B2B2 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cooling_zone_pause = 0 filament_cost = 0 filament_density = 0 filament_deretract_speed = 50 filament_diameter = 1.75 filament_dip_extraction_speed = 70 filament_dip_insertion_speed = 33 filament_enable_toolchange_part_fan = 0 filament_enable_toolchange_temp = 0 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_overlap = 100% filament_max_speed = 0 filament_max_volumetric_speed = 0 filament_max_wipe_tower_speed = 0 filament_melt_zone_pause = 0 filament_minimal_purge_on_wipe_tower = 15 filament_notes = "" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 0.3 filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_speed = 60 filament_seam_gap = nil filament_settings_id = "" filament_shrink = 100% filament_skinnydip_distance = 31 filament_soluble = 0 filament_spool_weight = 0 filament_toolchange_delay = 0 filament_toolchange_part_fan_speed = 50 filament_toolchange_temp = 200 filament_type = PET filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_use_fast_skinnydip = 0 filament_use_skinnydip = 0 filament_vendor = (Unknown) filament_wipe = nil filament_wipe_advanced_pigment = 0.5 filament_wipe_extra_perimeter = nil filament_wipe_speed = nil first_layer_bed_temperature = 80 first_layer_temperature = 267 full_fan_speed_layer = 0 inherits = max_fan_speed = 15 max_speed_reduction = 90% min_fan_speed = 15 min_print_speed = 10 slowdown_below_layer_time = 5 start_filament_gcode = "; Filament gcode\nG1 X250 Y250 \nG30\n\nM290 R0 S0.09 \n\nG29 S1\n" temperature = 262 top_fan_speed = 15 [printer:V-CORE 3 Frederick] bed_custom_model = bed_custom_texture = bed_shape = 0x0,500x0,500x500,0x500 before_layer_gcode = ; 0.2mm layer, 8 bands 5mm each, total height 40mm\n;{if layer_num== 1}M572 D0 S0.13\n;{elsif layer_num== 20}M572 D0 S0.14\n;{elsif layer_num== 40}M572 D0 S0.15\n;{elsif layer_num== 60}M572 D0 S0.16\n;{elsif layer_num== 80}M572 D0 S0.17\n;{elsif layer_num== 100}M572 D0 S0.18\n;{elsif layer_num== 120}M572 D0 S0.19\n;{elsif layer_num== 150}M572 D0 S0.20\n;{endif} between_objects_gcode = color_change_gcode = M600 cooling_tube_length = 5 cooling_tube_retraction = 91.5 default_filament_profile = default_print_profile = deretract_speed = 50 end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; turn off bed\nG28 X0 ; home X axis\nM84 ; disable motors\nM999 extra_loading_move = -2 extruder_colour = "" extruder_fan_offset = 0% extruder_offset = 0x0 extruder_temperature_offset = 0 fan_kickstart = 0 fan_percentage = 0 fan_speedup_overhangs = 1 fan_speedup_time = 0 feature_gcode = gcode_filename_illegal_char = gcode_flavor = reprapfirmware gcode_precision_e = 5 gcode_precision_xyz = 3 high_current_on_filament_swap = 0 host_type = octoprint inherits = layer_gcode = machine_limits_usage = time_estimate_only machine_max_acceleration_e = 10000,5000 machine_max_acceleration_extruding = 1500,1250 machine_max_acceleration_retracting = 1500,1250 machine_max_acceleration_travel = 1500,1250 machine_max_acceleration_x = 9000,1000 machine_max_acceleration_y = 9000,1000 machine_max_acceleration_z = 500,200 machine_max_feedrate_e = 120,120 machine_max_feedrate_x = 500,200 machine_max_feedrate_y = 500,200 machine_max_feedrate_z = 12,12 machine_max_jerk_e = 2.5,2.5 machine_max_jerk_x = 10,10 machine_max_jerk_y = 10,10 machine_max_jerk_z = 0.2,0.4 machine_min_extruding_rate = 0,0 machine_min_travel_rate = 0,0 max_gcode_per_second = 1500 max_layer_height = 0.3 max_print_height = 200 milling_diameter = milling_toolchange_end_gcode = milling_toolchange_start_gcode = milling_z_lift = min_layer_height = 0.07 min_length = 0.035 nozzle_diameter = 0.4 parking_pos_retraction = 92 pause_print_gcode = M601 print_host = printer_model = printer_notes = printer_settings_id = printer_technology = FFF printer_variant = printer_vendor = printhost_apikey = printhost_cafile = printhost_port = remaining_times = 0 retract_before_travel = 3 retract_before_wipe = 0% retract_layer_change = 0 retract_length = 0.3 retract_length_toolchange = 10 retract_lift = 0 retract_lift_above = 0.3 retract_lift_below = 0 retract_lift_first_layer = 0 retract_lift_top = "All surfaces" retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 60 seam_gap = 15% silent_mode = 1 single_extruder_multi_material = 0 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n start_gcode_manual = 0 template_custom_gcode = thumbnails = 0x0,0x0 thumbnails_color = #018aff thumbnails_custom_color = 0 thumbnails_with_bed = 1 time_estimation_compensation = 100% tool_name = 0 toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 variable_layer_height = 1 wipe = 0 wipe_advanced = 0 wipe_advanced_algo = linear wipe_advanced_multiplier = 60 wipe_advanced_nozzle_melted_volume = 120 wipe_extra_perimeter = 0 wipe_speed = 0 z_offset = 0 z_step = 0.005 [physical_printer:Printer 1] host_type = duet preset_name = VCoreNeu - PrusaSlicer_config_bundle.ini print_host = duet.fritz.box printer_technology = FFF printhost_apikey = vcore2019 printhost_authorization_type = key printhost_cafile = printhost_password = printhost_port = printhost_user = [presets] print = JEN 0.4 PETG Filamentive Carbon F sla_print = - default - sla_material = - default - printer = V-CORE 3 F filament = V-CORE 3 Carbon F physical_printer =
Julián. -
I will take a look at the file but the situation you are describing still seems to me like something "corrects" the configuration during the first print, but doesn't affect the first print, but does cause the second print to be ok.
I have noticed something odd.
I gave you a very simple, edited version of the homeall.g file you first posted.
I did not cancel baby-stepping in the code I posted for you.
Homing does not cancel baby-stepping unless the homing code has the command to do that.
In your example print file you have this:
G1 X250 Y250 ; move to the XY reference point for G30 G30 ; set the Z-0 Datum M290 R0 S0.09 ; set baby-stepping
So the first print after power up sets baby-stepping (from 0.00 to 0.09) but it does so after the G30.
For the next print I am thinking baby-stepping is still in effect (it remains at 0.09) which changes the results of G30 and the nozzle ends up farther away from the bed on the next print(s).
And that is consistent with what you are reporting.
Normally you don't want to set baby-stepping in a print file. To fix first layer Z issues you would adjust the Z Trigger Height parameter in G31 which would cause the G30 to set things so the Z position is correct for printing the first layer.
Remove the M290 from your print code and adjust the Z Trigger Height parameter in G31 to get the Z height correct.
If I had put M290 R0 S0 in the homeall code I posted you wouldn't be seeing this issue - my bad - all attempts to print would have been too close to the bed.
